12-10-2020 10:09 AM
Like most people, we continue seeing a major influx of work from home staff, and all the CUCM work that needs to be done so they can access Jabber on cell phones, home pc's ect....
Where can I find some documentation on how to script the creation of a new phones, profiles, or any task in CUCM really, instead of creating one manually for each person that changes to WFH.
12-10-2020 10:17 AM
Go over to DevNet for all the APIs that are available and the references on how to use them.
12-10-2020 10:32 AM
Not sure what language you want to use but I would suggest Python. I would start with this blog post - https://afterthenumber.com/2018/04/16/getting-started-with-axl-programming-in-python-using-python-zeep/ -
I started with SUDS based on some Google search and did not make it very far. Start with Zeep. I then recommend you look up EURL in Webex Teams and get yourself into the DevNet Support group where others are probably working on the same thing (eurl@webex.bot). Some CCM AXL info can be found here if you already have a base understanding, https://developer.cisco.com/docs/axl/#!12-5-cucm-data-dictionary
HTH and feel free to reply if I can offer you more.
