Hello Community, we setup a callamanger with a third party application and the vendor would like to know if the cucm works with SDES or MIKEY Encryption. Goog Question. I can´t really nothing in the Cisco Guides.
Anyone knows if the cucm works with SDES or MIKEY?
HTH, please rate all useful posts and right answers.
Hello Armin,
Whats the purpose of this application ? and are we trying to setup a encrypted path between CUCM and 3rd Party application.
If, I look at the Encryption/ESP algorithm in CUCM IPSEC configuation, i dont see SDES or MIKEY listed.
Amit Singh
Hi Amet, really thanks work w/ me on that. Good Question I am not the hero in Encrypten. SDES or Mikey are Ecrypten method for SRTP I believe.
http://en.wikipedia.org/wiki/SDES
http://en.wikipedia.org/wiki/MIKEY
but it seems this are different things.
SRTP relies on an external key management protocol to set up the initial master key. Two protocols specifically designed to be used with SRTP are ZRTP and MIKEY.
Bur what kind of external key management is using in CUCM?
How can I adjust SDES or Mikey in CUCM for SRTP?
Hi Amet, first time it is only to know for add the third party application, meantime I am also by myself very interesst to know wthat kind of Key management for SRTP Cisco CUCM is using, because nowhere it is describe or documented at Cisco. Also not in Security Guide.
It is a mystery
Your help will be really fine and I think it is also for the Community really helpfull because you don´t find any information on Cisco site concering cisco Products.
Hello Aamir,
•Currently only CTS supports DTLS.
You may check the following RFC: http://tools.ietf.org/html/rfc5764
Also, it should be worhwhile, checking with 3rd party product what they support.
Amit Singh
