SDWAN Routers - Codec Issue and Transfer Issue
Hi all
We have Analog Trunks at a SDWAN Spoke site. We noted the following issues:
1. Incoming calls on the FXO is only delivered using G729
2. Outgoing calls are only delivered using G729
3. We are not being able to transfer calls
We have tried to transfer with MTP enabled and without the MTP enabled, but problem continues. For the Incoming and Outgoing calls, we have also tried the difference codec preferences, but still the cant dialout. We can only dial if the codec is G729.
We will be most greatful for your advice. The same site on teh Autonomous IOS-XE works fine without any issues.
Adrian.
0 Replies 0
