Securing Voice Gateway, Problem with some commands (Not Exist!)
I need to secure voice gateway, but i can't use some commands to enable it as
>>voice service voip
sip
session transport tcp tls
also
>>sip-ua
crypto signaling remote-addr x.x.x.x 255.255.255.255 trustpoint VGW
both commands don't exist at all when I write "?"
the only exist >>session transport TCP
VGW is ISR 4351 v16.6.4
license boot suite advUCSuiteK9
license boot suite foundationSuiteK9
Before Activation those commands where not available.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
jlrvg(config)#sip-ua
jlrvg(config-sip-ua)#cr
jlrvg(config-sip-ua)#credentials ?
After the activation the commands you mentioned   are available.
FoundationSuiteK9     FoundationSuiteK9     EvalRightToUse FoundationSuiteK9
securityk9
appxk9
AdvUCSuiteK9          AdvUCSuiteK9          EvalRightToUse AdvUCSuiteK9
uck9
cme-srst
cube
jlrvg(conf-serv-sip)#session transport tcp tls
Response Signature
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Do you have both, uc and security, licenses enabled in the ISR?
java
if this helps, please rate
yes,
AdvUCSuiteK9
>>sh version
securityk9
appxk9
AdvUCSuiteK9 AdvUCSuiteK9 Permanent AdvUCSuiteK9
uck9
cme-srst
cube
>>sh license
Index 1 Feature: appxk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
Index 2 Feature: uck9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Suite: AdvUCSuiteK9
License Priority: Medium
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
License Count: 0/0 (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
securityk9
appxk9
uck9
cme-srst
cube
securityk9
appxk9
uck9
cme-srst
cube
Response Signature
Hi Nithin,
you are amazing.
it works now.
I really appreciate your help with all the detailed information to describe the issue and its solution.
Recognize Your Peers
