255
jwtechie211
Beginner
Seeking to understand- users NEED to be in Unity to get transferred calls
Hello
Learning Call manager. I want to make sure I understand something I am troubleshooting
Caller can get calls to extension 206767 from inside the building- but when callers from outside call and dial 6 digit- they get can't transfer call. This user/extension is NOT in Unity Connection.
The extension needs a VM box created for it, correct?
1 ACCEPTED SOLUTION
Jaime Valencia
Hall of Fame Cisco Employee
Yes, if you do not use that option, CUC wil only transfer to numbers that are configured in some element within it.
java
if this helps, please rate
4 REPLIES 4
Jaime Valencia
but if we do not have this configured
Allow Transfers to Numbers Not Associated with Users or Call Handlers
the extension needs to be in Unity, correct?
Jaime Valencia
java
Thank you!
Create
Recognize Your Peers
Content for Community-Ad
