I need to deploy CUCM (5 nodes), Unity Connection (1 Pair) and Unified Presence server (1 Pair) in a virtualised environment. Approximately 5000 users and 10000 end devices. How do I select a UCS server type and model?
Thank you,
Fawaz
You work out how many CPUs and how much memory/disk each VM needs (CUCM may need 2 or 4 procs depending on node size for example).
Then you add that up.
And select a UCS platform that has the appropriate CPU/memory count and disk space etc.
Google UC on UCS to get the Cisco wiki with all the design information.
The only non-intuitive one is Unity Conn - you need to leave 1 CPU core spare on any host that runs this app, for reasons I don't pretend to understand properly :-)
Aaron
