09-01-2022 08:07 AM - edited 09-01-2022 08:07 AM
Does anyone know why when entering a username and password under a service at the self-care portal does not save the credentials at the phone service?
This is a setting is under http://cucmFQDN/ucmuser
Phone Settings > Services
Service
8841
Solved! Go to Solution.
09-03-2022 10:26 AM
If it is FIPPA that you are trying to setup have you followed all the steps in this document?
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/finesse/finesse_1251/admin/guide/cfin_b_1251-administration-guide/cfin_b_1251-administration-guide_chapter_01010.html#reference_B056C81EA937A7150B468AC4D483BAB6
09-01-2022 10:33 AM
AFAIK this works as intended. It is not expected to be possible to save that information from that UI.
09-02-2022 07:06 AM
I also entered the userid, pwd, and DN under the device sub. It never passes it to the phone.
Sub
09-03-2022 10:26 AM
10-04-2022 08:15 AM
fantastic that document helped. I had to make the service parameters lowercase. Once I did that the one touch worked for the sandbox agent. I can now continue on a production deployment. Thanks man with no hair.
