Highlighted
Beginner
Self Provisioning - CTI Route Point not registering
Hi all,
Iam trying to set up self provisioning in my cluster. But I can not get registering my CTI Route Point. do you what is going on?. I did:
Device
CTI Route Point
Device Name: CTI_SelfProv
Description : CTI for Self Provisioning
Device Pool:none
Calling Search Space: z_autoregistered
Line
Directory Number : 1015 (colud be anyting free extension)
Route Partition: z_autoregistered
Description, Alerting Name, ASCII Alerting Name : Self Provision Phones
Application user
User ID : User_SelfProv
Password : 11111
Controlled Devices : CTI_SelfProv
Groups : Standard CTI enable
But my CTI RP show next status:
Registration: Unknown
IPv4 Address: None
2 ACCEPTED SOLUTIONS
Highlighted
Advisor
what is exact CUCM version u
what is exact CUCM version u are using ?
check for the bug:
Self Provisioning IVR shows Active instead of Inactive
CSCun67427
Description
Symptom:
Conditions:
In subscriber node, Self provisioning IVR service is not available. It is available only in Publisher node.
Go to CM admin- system- service parameter- select subscriber- Self Provisioning IVR service
There Self Provisioning IVR shows active. It must be Inactive.
Highlighted
Advisor
Hi Oscar,
Hi Oscar,
You are correct.
After I shared the bug, I called up one of my colleagues who  has got CUCM cluster 10.5.1.10000-7  with Pub and Sub  to find the resolution as per bug but could not find "Self provisioning IVR " under Subscriber.
 I suggest opening TAC case and share the resolution.
thanks for  ratings.
regds,
aman
21 REPLIES 21
Highlighted
Rising star
Have you selected that ctl
Have you selected that ctl route point under IVR settings of self provisioning (user management -> self-provisioning) ?
Suresh
Highlighted
Beginner
Yes I did it a couple of times. also I re-restarted manually the service on publisher. but still not registered. check picture atached. Usually CTI Route point is registered from outside component like Unity Connection, CCx, etc. on this self provisioninng whom do this?.
FYI. We have implemented "publisher server" (this have service self provisioning enabled, and with "start" status) and "cti server" (all my cti route point are registered on this server.).
Highlighted
Advisor
check for the Role and
check for the Role and permissions under UserId [user_selfprov] which u have cerated.
Standard CCM End User
Standard CTI Allow Control of All Devices
Standard CTI Enabled
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118910-technote-cucm-00.html
regds,
aman
Highlighted
Beginner
as far as i understand only
as far as i understand only Standard CTI Enabled is required. any way i add it the others. but still not registering. Usually CTI Route point is registered from outside component like Unity Connection, CCx, etc. on this self provisioninng whom do this?.
Highlighted
Rising star
Self provisioning application
Self provisioning application do take care of it itself.
Suresh
Highlighted
Advisor
Can u reset the CTI route
Can u reset the CTI route point ?
also, check for Self provisioning IVR service under serviceability?
regds,
aman
Highlighted
Beginner
I've reset the CTI Route
I've reset the CTI Route point but still not registering status. I also restart the Self provisioning IVR service (this the 3rd time i did it). Be aware "Self provisioning IVR service" is not in same virtual server than CTI server.
FYI. We have implemented "publisher server" (this have service self provisioning enabled, and with "start" status, is mean up) and "cti server" (all my cti route point are currenlty registered on this server and up).
Highlighted
Advisor
this means u have two servers
this means u have two servers: one which has Self -provisioning enabled and CTI Manager: Not running while the second server has Self-Provisioning as "Not running" but CTI Manager "Running".
can try activating  "Self -provisioning " on server which has CTI route points already registered?
regds,
aman
Highlighted
Beginner
Yes you right, I have two
Yes you right, I have two virtual machines (on reality we have Two TFTP servers, two CTI Managers, Two Call Managers, One Publisher).
On  machine "CTI Manager server" dosen't exist "Self -provisioning " service. check picture. only exist on publisher.
Highlighted
Advisor
Surprisingly,"Self
Surprisingly,"Self provisioning IVR " is not appearing under CTI services.
Is it appearing under  other services in cluster?
regds,
aman
Highlighted
Advisor
can u check by running
can u check by running command "utils service list " from putty  as attached.
Highlighted
Advisor
check for the bug:
CSCun67427
Description
Symptom:
Conditions:
Beginner
Our Cluster version is.
Our Cluster version is. System version: 10.5.2.13900-12.
"Self provisioning IVR " dosent exist in any location into subscriber.
CSCun67427 said exactly what i have. but i canot find : "Go to CM admin- system- service parameter- select subscriber- Self Provisioning IVR service". i've check it on publisher also but with same result, not find "Self Provisioning IVR service" into service parameter. So there isnt work around to solve this bug?.
So just for understand. "Cisco CTI manager" service and "Self provisioning IVR" service must be enabled/started on same virtual machine?.
Highlighted
Advisor
Hi Oscar,
Hi Oscar,
You are correct.
thanks for  ratings.
regds,
aman
Content for Community-Ad
FusionCharts will render here
