02-26-2016 03:28 AM - edited 03-17-2019 06:02 AM
I have used self provisioning several times now and in general it works very well.
I now have a situation where we have a new system where all users will use Extension Mobility. Is there a way to use self provisioning and create automatically a UDP? Or do I have to use the good old BAT for this?
JH
02-26-2016 08:17 AM
The user profile does allow you to choose a UDT for remote destinations/device profiles, but I'm honestly not sure what would be the process to actually use it, I don't recall the documentation going over that
02-29-2016 02:52 AM
I did some checking, but it seems that UDT's have to be created manually, so I think I have to spend time in making a perfect CSV file and then using Bulk Administration
Bye
Jan
