04-26-2016 10:11 AM - edited 03-17-2019 06:43 AM
As long as I've supported the systems I never bothered to do this, nor have I ever been asked.
How does one send a caller from a current call directly into another employees vm byepassing the employees phone ringing? Such is the case of an admin handling calls for the business?
Thanks to all in advance.
Solved! Go to Solution.
04-26-2016 10:58 AM
Hi Ross,
In this example your associate would transfer>*star3289>transfer. This would then go straight to the 3289 mailbox.
Cheers!
Rob
04-26-2016 10:22 AM
Refer to below thread with a same kind of requirement:
https://supportforums.cisco.com/discussion/12960011/can-i-transfer-calls-users-voicemail
Deepak
04-26-2016 10:27 AM
Thank you gents, appears you both responded simultaneously.
Maybe I'm confused, isn't "Transfer>[agent DN]>Transfer:" a cold transfer? Won't their phone ring?
04-26-2016 10:32 AM
Yeah it looks like that me and Rob responded simultaneously :) Once you will hit Transfer then you will dial *XXXX where XXXX is the extension number and not simply XXXX
Deepak
04-26-2016 10:35 AM
Ha ha, no I know xxxx is the extension.
Ok, If I'm on a call and the caller says they want to be transferred to Bob Smith, and I know Bob doesn't want and calls, if I hit transfer>3564>transfer won't that ring his phone and send a cold call to him? I know if I hit transfer>3564> and wait for him to pick up I can advise the call is being transferred then hit transfer again to give it to him.
No?
04-26-2016 11:41 AM
Yes, Ross.
Former is known as blind transfer (Transfer>Extension>Transfer) and later is consult transfer (Transfer>extension>Call answered>transfer)
Sami
04-26-2016 11:48 AM
We've always called it warm and cold. Either or I guess.
04-26-2016 10:27 AM
Hi Ross,
Most people use the steps in this good "old" TechNote to set up the config for transferring directly to voicemail using Transfer>*xxxx (where xxxx is the users extension)>Transfer;
Cheers!
Rob
04-26-2016 10:32 AM
Hi Ross,
No worries my friend! With the config detailed in the Tech note you actually transfer to *xxxx not just xxxx and by doing this it goes straight to the users mailbox without ringing the phone. Really a great feature for admins :)
Cheers!
Rob
04-26-2016 10:38 AM
I just tested with my associate. I called him, he picked up, I told him to hit transfer>3289>transfer
3289 is the person who sits behind me. It rang her phone until RNA then went to vm.
04-26-2016 10:58 AM
Hi Ross,
Cheers!
Rob
04-26-2016 11:02 AM
Thanks Rob!
