07-09-2015 04:15 PM - edited 03-17-2019 03:36 AM
Would anyone happen to know how to send random phone number masks on outbound calls?
We own 6 different DID's from our telco. We have changed their Caller ID Name to "unkn". I'd like to somehow randomly assign one of these 6 numbers to outbound calls.
They're routing out SIP T's. I originally thought I could do this via CCM, but I can't find a way. Now I am thinking dial-peers. There are only a few phones that will have the ability to do this. It's law enforcement related.
Thoughts?
07-09-2015 05:06 PM
No native way to do what you're asking, and it's impossible in CUCM, your only option would be to develop a TCL script to do that and do the ANI change in the GW.
07-09-2015 06:23 PM
It's possible with CUCM using CURRI (https://developer.cisco.com/site/curri/overview/).
07-09-2015 06:36 PM
Thank you both! Never worked with TCL scripting before...I'll take a look at it.
07-09-2015 06:10 PM
Jaime is correct no native way in CUCM to do that. You can try to use the translation-rules on the gateway. Some thing similar to below:
1) Crate translation rules and map DID mask:
voice translation-rule 1
rule 1 // /12345/ <<< DID 1
voice translation-rule 2
rule 1 // /56789/ <<< DID 2
voice translation-rule 3
rule 1 // /0123/ <<< DID 3
2) Create Translation-profiles, translating the calling number to above DIDs
voice translation-profile CLID-1
translate calling 1
voice translation-profile CLID-2
translate calling 2
voice translation-profile CLID-3
translate calling 3
3) Apply to dial-peers:
dial-peer voice 1 voip
translation-profile outgoing CLID-1
dial-peer voice 2 voip
translation-profile outgoing CLID-2
dial-peer voice 3 voip
translation-profile outgoing CLID-3
The dial-peers should have same destination-pattern and (same preference which is default) should be picked up randomly.
-Terry
07-09-2015 06:47 PM
Thanks for the insightful way Terry (+5), and just adding to Terry's point.
If your Outgoing dial-peers are exactly same, you can make it Random Selection by the following command:
dial-peer hunt 6 (6 = random selection) by default it is 0 (longest match)
For more details please follow the link:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_d1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1100737
