506
jemima.spare
Beginner
Separate MOH for phones in a device pool
Is it possible for a number of devices to have separate music on hold to everyone else?  These devices are in a separate Device Pool.
Call Manager 8
1 ACCEPTED SOLUTION
Jaime Valencia
Hall of Fame Cisco Employee
Don't configure anyone else with that MOH music under any of the 4 levels where MOH music can be configured, in priority:
Line
Device
Common Device Config
Enterprise parameter
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
7 REPLIES 7
Jaime Valencia
Bear in mind that the guy that presses hold, is the one that chooses what you'll hear, the MRGL from the guy who is being put on hold, determines from where he'll get the MOH, with that in mind, what's the exact behavior you want?
java
java
Yes, Person A in the Swanky Office presses hold and the caller gets choral music.
I need to know how to get the choral music in the right place so anyone who calls the Swanky Office gets the choral music.
Jaime Valencia
Make sure the MOH server has the MOH file, and is part of the MRGL assigned to the phones that need to hear that music.
java
java
But how do I make sure that only phones in Swanky Office send out choral music and nothing else?
And how do I make sure no-one else in the Plebby offices sends out the choral music?
Jaime Valencia
Line
Device
java
java
So to clarify;
I can either edit each line or device, which could be very time consuming.
Or I could set up a Common Device Config and apply it to each device.
or I could change the Enterprise parameters and then everyone would get it?
Is that right?
And the MGRL means that there is a choice of music which could be used?
Jaime Valencia
Correct, you configure them and they have that priority.
About MRGL, read here
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmsys/CUCM_BK_C5565591_00_cucm-system-guide-91_chapter_010111.html
java
java
Create
Recognize Your Peers
Content for Community-Ad
