Seperate voicemail for different main lines
Tazio4436
Hello everyone,
I have a cisco 7975 at the reception and there is Ext 100 configured plus 3 main lines.
is there a way that the Ext 100 has its own voicemail and the other 3 lines has each a Voicemail. So in total I have 4 voicemail?
Tazio
Yes. The voice mail accounts are tied to the directory number, not the device, so as long as they are different it can match to separate voice mail accounts.
Response Signature
Response Signature
Thank you very much
As @Roger Kallberg mentioned, Voice mail are  linked with the extension and enduser  so you can have 4 voicemail accounts.
Response Signature
