Beginner
Setting 7975 to work with Asterisk as a SIP client
Hello experts,
We have an Asterisk server. All 30 phones are Cisco Small business SPA 502 or 504. We have only one Cisco 7975 phone which will be used by the GM.
I have setup a tftp server (using Tftpd32.exe) in the network, and put these files which I have downloaded from Cisco.com in the tftp directory:
cvm75sip.9-2-3TH1-9.sbn
jar75sip.9-2-3TH1-9.sbn
dsp75.9-2-3TH1-9.sbn
apps75.9-2-3TH1-9.sbn
cnu75.9-2-3TH1-9.sbn
term75.default.loads
SIP75.9-2-3S.loads
I have also setup option 69 in DHCP to refer to the tftp server address.
In the Tftpd.exe log, I can see the following:
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac D4:D7:48:FE:50:2D [03/05 22:39:25.462]
Previously allocated address acked [03/05 22:39:25.462]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac D4:D7:48:FE:50:2D [03/05 22:39:27.461]
Previously allocated address acked [03/05 22:39:27.461]
Connection received from 192.168.1.112 on port 53116 [03/05 22:39:31.849]
Read request for file <CTLSEPD4D748FE502D.tlv>. Mode octet [03/05 22:39:31.849]
File <CTLSEPD4D748FE502D.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:39:31.849]
Connection received from 192.168.1.112 on port 49922 [03/05 22:39:31.911]
Read request for file <ITLSEPD4D748FE502D.tlv>. Mode octet [03/05 22:39:31.911]
File <ITLSEPD4D748FE502D.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:39:31.911]
Connection received from 192.168.1.112 on port 50829 [03/05 22:39:31.974]
Read request for file <ITLFile.tlv>. Mode octet [03/05 22:39:31.974]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:39:31.990]
Connection received from 192.168.1.112 on port 49619 [03/05 22:39:32.083]
Read request for file <SEPD4D748FE502D.cnf.xml>. Mode octet [03/05 22:39:32.083]
File <SEPD4D748FE502D.cnf.xml> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:39:32.083]
Connection received from 192.168.1.112 on port 52847 [03/05 22:39:32.208]
Read request for file <XMLDefault.cnf.xml>. Mode octet [03/05 22:39:32.208]
File <XMLDefault.cnf.xml> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:39:32.208]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac D4:D7:48:FE:50:2D [03/05 22:42:57.068]
Previously allocated address acked [03/05 22:42:57.068]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac D4:D7:48:FE:50:2D [03/05 22:42:59.051]
Previously allocated address acked [03/05 22:42:59.067]
Connection received from 192.168.1.112 on port 49555 [03/05 22:43:03.424]
Read request for file <CTLSEPD4D748FE502D.tlv>. Mode octet [03/05 22:43:03.424]
File <CTLSEPD4D748FE502D.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:43:03.424]
Connection received from 192.168.1.112 on port 49764 [03/05 22:43:03.486]
Read request for file <ITLSEPD4D748FE502D.tlv>. Mode octet [03/05 22:43:03.486]
File <ITLSEPD4D748FE502D.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:43:03.502]
Connection received from 192.168.1.112 on port 52188 [03/05 22:43:03.580]
Read request for file <ITLFile.tlv>. Mode octet [03/05 22:43:03.580]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:43:03.580]
Connection received from 192.168.1.112 on port 49686 [03/05 22:43:03.720]
Read request for file <SEPD4D748FE502D.cnf.xml>. Mode octet [03/05 22:43:03.720]
File <SEPD4D748FE502D.cnf.xml> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:43:03.720]
Connection received from 192.168.1.112 on port 53116 [03/05 22:43:03.845]
Read request for file <XMLDefault.cnf.xml>. Mode octet [03/05 22:43:03.845]
File <XMLDefault.cnf.xml> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:43:03.845]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac D4:D7:48:FE:50:2D [03/05 22:46:28.737]
Previously allocated address acked [03/05 22:46:28.737]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac D4:D7:48:FE:50:2D [03/05 22:46:30.735]
Previously allocated address acked [03/05 22:46:30.735]
Connection received from 192.168.1.112 on port 52933 [03/05 22:46:35.092]
Read request for file <CTLSEPD4D748FE502D.tlv>. Mode octet [03/05 22:46:35.092]
File <CTLSEPD4D748FE502D.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:46:35.529]
Connection received from 192.168.1.112 on port 49327 [03/05 22:46:35.607]
Read request for file <ITLSEPD4D748FE502D.tlv>. Mode octet [03/05 22:46:35.607]
File <ITLSEPD4D748FE502D.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:46:35.623]
Connection received from 192.168.1.112 on port 51363 [03/05 22:46:35.670]
Read request for file <ITLFile.tlv>. Mode octet [03/05 22:46:35.670]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:46:35.701]
Connection received from 192.168.1.112 on port 49466 [03/05 22:46:35.795]
Read request for file <SEPD4D748FE502D.cnf.xml>. Mode octet [03/05 22:46:35.795]
File <SEPD4D748FE502D.cnf.xml> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:46:35.795]
Connection received from 192.168.1.112 on port 51824 [03/05 22:46:35.920]
Read request for file <XMLDefault.cnf.xml>. Mode octet [03/05 22:46:35.920]
File <XMLDefault.cnf.xml> : error 2 in system call CreateFile The system cannot find the file specified. [03/05 22:46:35.935]
The address 192.168.1.112 is the phone address.
Would anybody send me the required configuration files which should reside in the tftp server? I need a very basic configuration which will be customized later. The basic config shall contain at least the Asterisk IP ( 192.168.1.99 ) , SIP username ( 535 ) and SIP secret ( Cisco.net )
Everyone's tags (5)
1 REPLY 1
Highlighted
Haitham,
  Looks like your phone still running SCCP so you would need to convert it to SIP first before you can integrate it with Asterisk.
There are few methods but you could try the following.
1. Copy the following lines in a notepad and save it as  SEPD4D748FE502D.cnf.xml
    SIP75.9-2-3S
2. Drop it in the same folder where the phone load is.
3. Restart the phone and make sure that TFTP service is running
4. If the upgrade to SIP doesn't start then tell me what version of SCCP are you running.
Luis A.
Content for Community-Ad
August's Community Spotlight Awards
