Settings on phone using BAT-cannot update
satish rawat
I am on CM 8.6 and trying to do a bulk task that would change settings button access from enabled to restricted as i dont like end user to be able to see anything except user prefernces,i am pretty sure i have done this kind of change using BAT on previous versions of CM but i just dont see this when i go to BAT>update phones>select all phones>next....i see all other phone parameters like CSS,DP etc...but no settings...has Cisco moved this to somewhere else ?
any ideas??
2 Accepted Solutions
Rob Huffman
Hi Satish,
To get to the Product Specific settings via Bat, I think it would be via
an Update with the use of a specific phone model query
So, you would query (for example) 7942's or 7965's and then you can
update the settings you need to. 1 query per phone model.
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Rob Huffman
Hi Satish,
You are most welcome my friend
The thought here would be that not all Device Models have the exactly
= Product Specific Configuration settings. So although many of the settings
are = because they are not all = the changes cannot be done in a 'blanket"
type update.
Cheers!
Rob
Rob Huffman
Hi Satish,
Cheers!
Rob
You are the Man Rob !
Thanks again
its strange since "settings" exists on all phone types irrespective of model so it should ideally be search all update field.
Rob Huffman
Hi Satish,
type update.
Cheers!
Rob
