Setup phones to get an outside operator
rwatson119
How do I setup my phones so that users can get an outside operator. When I say outside operator I mean at&t operator.
Jaime Valencia
CUCM? CME? version?
please always include that information when asking for assistance
basic steps would be to create a dial-peer or route patterns to outside world and use a translation pattern or translation rule to change the number to PSTN, pretty easy
java
if this helps, please rate
java
CUCM 4.1 Sorry
k, basic steps would be
decide the number they will dial for operator, if it's going to be 0 then just create a route pattern 0 and send it to the PSTN.
if something else then you can use a translation pattern or the route pattern directly, there is nothing weird on setting this. it's going to be like any other PSTN call
dial , match a route pattern, send it to PSTN
java
java
