06-27-2007 02:16 AM - edited 03-14-2019 10:17 PM
I've read some infos that there are 2 "SFTP" protocol :
- The FTP over SSH refers to the practice of tunneling a normal FTP session over an SSH connection
- The SSH File Transfer Protocol or SFTP is a network protocol that provides file transfer and manipulation functionality over any reliable data stream
(infos from wikipedia)
Is the second protocol used in the CCM backup and restore features ??
Thx !
Solved! Go to Solution.
06-27-2007 05:59 AM
The second is the one used by CM5.
Aaron
Please rate helpful posts...
06-27-2007 05:59 AM
Aaron
