Shared DN Ringing while in use
mdavis
I wanted to find out if there was an option on 7.x to allow a scenario where an admin has a shared DN with a VP, and normally in the past if the admin had already answered one call and so her shared DN was in use the next incoming call to that DN would only ring any shared DN's not in use, so in this example the VP's since there aren't multiple admins. I know this use to be by design, but I am unsure if this has changed or if there may be a new work around. The desired result is that she be able to still receive incoming calls on that shared DN even if it is in use. I know I can build a hunt and shared combination so that I can associate both DN's to the same phone, and if it were allowed I think she would be ok with duplicate DN's, but that cannot be configured or supported last I checked. Any suggestions would be helpful.
          Mac
Jaime Valencia
All that is explained in the CUCM help within the CCMAdmin page. Topic: Shared Line Appearance
  • Devices with shared-line appearance support the Call Forward Busy Trigger and the Maximum Number of Calls settings. You can configure Call Forward Busy Trigger per line appearance, but the configuration cannot exceed the maximum number call setting for that directory number.
  • The following example demonstrates how three Cisco Unified IP Phones with the same shared-line appearance, directory number 2000, use Call Forward Busy Trigger and Maximum Number of Calls settings. This example assumes that two calls occur. The following values configuration applies for the devices:
    • Cisco Unified IP Phone 1-Configured for a maximum call value of 1 and busy trigger value of 1
    • Cisco Unified IP Phone 2-Configured for a maximum call value of 1 and busy trigger value of 1
    • Cisco Unified IP Phone 3-Configured a for maximum call value of 2 and busy trigger value of 2
    When Cisco Unified IP Phone User 1 dials directory number 2000 for the first call, all three devices ring. The user for the Cisco Unified IP Phone 3 picks up the call, and the Cisco Unified IP Phones 1 and 2 go to remote in use. When the user for Cisco Unified IP Phone 3 puts the call on hold, user can retrieve the call from the Cisco Unified IP Phone 1 or Cisco Unified IP Phone 2. When User 2 dials directory number 2000 for the second call, only Cisco Unified IP Phone 2 and Cisco Unified IP Phone 3 ring.
    java
    If this helps, please rate
    www.cisco.com/go/pdihelpdesk
    java
    if this helps, please rate
    Rob Huffman
    Hi Mac,
    Just add a touch to the good info from Java (+5 my friend!)
    I'm not on campus right now so I can't lab this up for you to test
    but I would have thought that this behaviour could be managed
    via the "max calls" and "busy trigger" setting for the manager and
    admin phones. You could also use the method shown below which we
    use in certain situations
    Configuring a Single Dialed Number on Multiple Lines
    http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009409c.shtml
    Hope this helps!
    Rob
