Shared Line between VG224 and IP Phones
slongewa
Beginner
Beginner
Does anyone out there run a shared line between a VG gateway and an IP Phone?  We have about 8 phones on a shared line, one of which is an analog connected to a VG gateway.  A 224.  The VG runs SCCP as well as the IP phones.  We're running into a problem where when a user picks up a 2nd call on the shared line it hangs up on the first call.  When we remove the VG from the equation the shared line works as expected.  I can't find anywhere in the doco that we are running an unsupported configuration, but I was hoping one of you out there might have the answer.
Steve
Brad Martin
Participant
Participant
I believe that is an unsupported config although I can't find documentation for it. I've run in to multiple problems trying to share lines between analog gateways and ip phones. The only way I've been able to make it work correctly is with hunt groups. I use the DN as the pilot and hunt for the ip phone and analog port.
Recognize Your Peers
