Shared line off hook symbol and line botton red light does not goes off when not in use
nonattonolife
Beginner
Beginner
We have a shared line 1111 across 6 phones (7920, 7961G-GE, 7971)
It shows off-hook symbol on the display and line button lights on, even though 1111 is NOT in use by any of those phones.
I've checked if handset is off hook but nothing wrong.
Maximum numer of calls and busy trigger is set to 4/2, so no problem with making & receiving calls but it's just annoying...
Have anyone come across this kind of issue?
Any advice is appreciated. Thank you.
Call Manger version is 7.1.4
Vinay Kumar Dharmaraj
Hi Jumpei,
I had similar issue in past, issue happens when call gets terminated due to unexpected error (Mostly when calls comes from PSTN through MGCP gateway).
You can verify max line = x and busy trigger= x counters in CCM Traces to see if it shows any existing call.
Restarting CCM Service will help.
Vinay
Hi Vinay,
The issue was fixed by restarting CCM service. Thank you very much for your advice.
Jumpei
Recognize Your Peers
