04-24-2015 06:43 AM - edited 03-17-2019 02:47 AM
Hi Everyone,
I just wanna know is there any phone button key like Hunt logout for shared line to stop the flow of call when pressed.
Saif
Solved! Go to Solution.
04-24-2015 06:57 AM
Hi Saif,
As far as I know there is no feature like that for Shared line. I always like to create a hunt group with Broadcast if there's a requirement to ring multiple phones at the same time. This way If there are any changes required later on it's easy without affecting all phones.
But for your scenario if for some reason you need Shared Line only then I will suggest creating EM profiles and whichever user doesn't need his phone to ring just lot out from EM,
Hope this helps.
Vishal
04-24-2015 06:57 AM
Hi Saif,
Hope this helps.
Vishal
