Shared Line
tomchan.jpn
Beginner
Beginner
We are having Cisco 8861 phones and all users are setup with shared lines with other users extensions.
If one of the users pickup the call, the rest of the users can see a pop-up a message "On xxxx" on their phones. (xxxx is the internal exts)
Is it possible to turn off that pop up message?
Manish Gogna
Hi Tomchan,
The following rules apply to shared lines:
>>Most devices with a shared-line appearance can make or receive new calls or resume held calls at the same time. Incoming calls display on all devices that share a line, and anyone can answer the call. Only one call remains active at a time on a device. For limitations, see the "Shared Line Restrictions" section.
>>Call information (such as calling party or called party) displays on all devices that are sharing a line. If one of the devices turns on the Privacy feature, other devices that share the line will not see outbound calls that are made from the device that turned on privacy. All devices will still see inbound calls to the shared line.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_0_2/ccmsys/accm-802-cm/a03dn.html#wp1100362
Manish
Recognize Your Peers
