show call active voice not showing calling/called numbers
mengelm
Hi.
I have an MGCP gateway (3845) and CM6.1.2. When I do a "show call active voice" on the 3845, the output never contains the called or calling number. Is this normal behaviour, or am I missing something?
I have inherited this system and not totally across everything yet...
Matthew
Chris Deren
You will not see that info with MGCP as the D-channel is backhauled to CM, it works with H323/SIP only.
Chris
Chris Deren
Chris
Thanks.
Matthew
Glad to help, please rate post if it was helpful.
Chris
