Show Caller-ID instead of Caller-Numbr
Andre Lahl
Hi all,
i have a C2921 with CME9.5 and some CP-6921 phones. My problem is, that on internal calls the phone only shows the directory number (1010) instead of the configured line name.
All phones are configured as SIP devices.
My config is attached below:
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  h225 timeout t302 3
 modem passthrough nse codec g711alaw redundancy maximum-sessions 15
 sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  registrar server expires max 3600 min 1800
voice register global
 mode cme
 source-address 192.168.11.1 port 5060
 timeouts interdigit 3
 max-dn 400
 max-pool 110
 load 9971 sip9971.9-3-2SR1-1
 load 8961 sip8961.9-3-2SR1-1
 load ATA-187 ATA187.9-2-3-1
 load 6921 SIP69xx.9-4-1-3
 authenticate register
 authenticate realm all
 timezone 23
 time-format 24
 date-format D/M/Y
 mwi stutter
 mwi reg-e164
 voicemail 88000
 url directory http://192.168.11.1/localdirectory
 url authentication http://192.168.11.1/CCMCIP/authenticate.asp User Password
 tftp-path flash:
 file text
 create profile sync 0292646025374671
 network-locale DE
 user-locale DE
 camera
 video
voice register dn  2
 number 1010
 call-forward b2bua busy 1000
 call-forward b2bua noan 1000 timeout 22
 call-forward b2bua unregistered 1038
 allow watch
 pickup-group 7
 name Caller Name
 label C.Name
telephony-service
 srst mode auto-provision none
 srst ephone description CCME-SRST MODE: : Jan 14 2013 12:37:38
 authentication credential User Password
 authentication credential evs tzgevs
 em keep-history
 pin 12345
 max-ephones 100
 max-dn 400
 ip source-address 192.168.11.1 port 2000
 service phone webAccess 0
 service directed-pickup gpickup
 system message Plasmatreat GmbH
 url services http://192.168.11.3/voiceview/common/login.do
 cnf-file location flash:
 user-locale DE
 network-locale DE
 time-zone 26
 time-format 24
 date-format dd-mm-yy
 voicemail 88000
 max-conferences 8 gain -6
 call-park system application
 call-forward system redirecting-expanded
 hunt-group logout HLog
 moh "flash:music-on-hold.au"
 web admin system name evs password tzgevs
 dn-webedit
 transfer-system full-consult
Does someone recognize the configuration issue?
Just a stupid question after the initial configs have you done no create profile and create profile again under voice register global?
I have even less config than you and my iphone on sip on the cme shows the calling name when dialing internal to another device.
Best Regards
Thank you for your quick reply.
Yes, i deleted and created the profiles, but nothing happened. I can't figure it out
Brian Meade
Level 7
Level 7
The phone should be sending the calling name in the SIP Invite.  If that's not happening, it's an issue with the phone not getting the correct info in the config files.
Try grabbing a "debug ccsip messages" for a test call.
