02-17-2013 03:22 PM - edited 03-16-2019 03:46 PM
This command is showing me the following alarms in two E1 interfaces. What troubleshooting should I do? I see alarms in: slip secs, Fr Loss Secs, Line Err Secs, Degraded mins, etc, etc.
Shoul I also check something in the CUCM (ver. 8.6.2.20000-2)?
E1 0/1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK4
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (579 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
446 Line Code Violations, 522 Path Code Violations,
2 Slip Secs, 48 Fr Loss Secs, 2 Line Err Secs, 3 Degraded Mins,
134 Errored Secs, 26 Bursty Err Secs, 0 Severely Err Secs, 50 Unavail Secs
E1 0/1/1 is up.
No alarms detected.
200 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
200 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
0 Line Code Violations, 0 Path Code Violations,
29774 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
29774 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Thanks for any help.
Best,
Patricio
Solved! Go to Solution.
02-17-2013 03:40 PM
Those errors are layer 1 errors with the E1 circuit if they are still incrementing. Clear the counters, show controller a few times and if the errors are increasing then check the cable between router interface and smartjack.
Call your provider and have them
Test the circuit for issues.
02-17-2013 03:53 PM
Hi Patricio,
This errors appear generally when you have a cable problem, try to replace the E1 cable....
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
02-17-2013 03:40 PM
02-17-2013 03:47 PM
Ok, thank you for your response.
If there's any other suggestions, they are very welcomed.
Patricio
02-17-2013 03:53 PM
Hi Patricio,
02-17-2013 05:24 PM
Thank you Leo.
Replacing the cable will absolutely resolve the problem?
After 515 minutes, it's showing this info now:
E1 0/1/0 is up.
No alarms detected.
Data in current interval (99 seconds elapsed):
Total Data (last 5 15 minute intervals):
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
E1 0/1/1 is up.
Description: ## TRAMA CLARO 5551-0600 ##
No alarms detected.
35 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
35 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
1550 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1550 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Patricio
02-17-2013 05:39 PM
And now:
E1 0/1/0 is up.
No alarms detected.
Data in current interval (374 seconds elapsed):
Total Data (last 6 15 minute intervals):
211 Line Code Violations, 268 Path Code Violations,
1 Slip Secs, 23 Fr Loss Secs, 2 Line Err Secs, 1 Degraded Mins,
102 Errored Secs, 16 Bursty Err Secs, 0 Severely Err Secs, 20 Unavail Secs
E1 0/1/1 is up.
No alarms detected.
128 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
128 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
1861 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1861 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
