2318
show controllers e1 - question
This command is showing me the following alarms in two E1 interfaces. What troubleshooting should I do? I see alarms in: slip secs, Fr Loss Secs, Line Err Secs, Degraded mins, etc, etc.
Shoul I also check something in the CUCM (ver. 8.6.2.20000-2)?
E1 0/1/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK4
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (579 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
    446 Line Code Violations, 522 Path Code Violations,
     2 Slip Secs, 48 Fr Loss Secs, 2 Line Err Secs, 3 Degraded Mins,
     134 Errored Secs, 26 Bursty Err Secs, 0 Severely Err Secs, 50 Unavail Secs
E1 0/1/1 is up.
  No alarms detected.
    200 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     200 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
     0 Line Code Violations, 0 Path Code Violations,
     29774 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     29774 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Thanks for any help.
Best,
Patricio
2 ACCEPTED SOLUTIONS
Erick Bergquist
Frequent Contributor
Those errors are layer 1 errors with the E1 circuit if they are still incrementing. Clear the counters, show controller a few times and if the errors are increasing then check the cable between router interface and smartjack.
Call your provider and have them
Test the circuit for issues.
Hi Patricio,
This errors appear generally when you have a cable problem, try to replace the E1 cable....
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
5 REPLIES 5
Erick Bergquist
Ok, thank you for your response.
If there's any other suggestions, they are very welcomed.
Patricio
Hi Patricio,
Thank you Leo.
Replacing the cable will absolutely resolve the problem?
After 515 minutes, it's showing this info now:
E1 0/1/0 is up.
  No alarms detected.
  Data in current interval (99 seconds elapsed):
  Total Data (last 5 15 minute intervals):
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
E1 0/1/1 is up.
  Description: ## TRAMA CLARO 5551-0600 ##
  No alarms detected.
     35 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     35 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
     1550 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     1550 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Patricio
And now:
E1 0/1/0 is up.
  No alarms detected.
  Data in current interval (374 seconds elapsed):
  Total Data (last 6 15 minute intervals):
     211 Line Code Violations, 268 Path Code Violations,
     1 Slip Secs, 23 Fr Loss Secs, 2 Line Err Secs, 1 Degraded Mins,
     102 Errored Secs, 16 Bursty Err Secs, 0 Severely Err Secs, 20 Unavail Secs
E1 0/1/1 is up.
  No alarms detected.
     128 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     128 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
     1861 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     1861 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Create
Recognize Your Peers
Content for Community-Ad
