Highlighted
Beginner
Show Enterprise Alternate number settings from CTI Route point lines on Callmanager CLI
does anyone know how i can display the Enterprise Alternate number settings on Callmanager CLI? I'm using Version 10.5.
I got some troubles with my SQL-statements..
How do i get the CTI route points with the CLI?
I need to set the Number Mask on the Line and to get the checkbox "Add to Local Route Partition" checked and set the route partition.
regards,
vincent
1 REPLY 1
Highlighted
VIP Advisor
Hi, CUCM CLI is used for OS
CUCM CLI is used for OS administration and basic functions. You can't configure CTI settings from CLI.
What you can do is use AXL SOAP to configure CUCM parameters.
