show diag
how diag
Platform mid-plane:
PCB Serial Number : FOC16384XB1
Hardware Revision : 1.0
Part Number : 73-12223-02
Top Assy. Part Number : 800-29789-02
Board Revision : E0
Deviation Number : 0
Fab Version : 02
Product (FRU) Number : CISCO3925-CHASSIS
Version Identifier : V02
CLEI Code : IPMN610DRA
Chassis Serial Number : FGL164212XB
Manufacturing Test Data : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 36 33 38 34 58 42 31 40
0x10: 06 48 41 01 00 82 49 2F BF 02 C0 46 03 20 00 74
0x20: 5D 02 42 45 30 88 00 00 00 00 02 02 CB 91 43 49
0x30: 53 43 4F 33 39 32 35 2D 43 48 41 53 53 49 53 89
0x40: 56 30 32 00 C6 8A 49 50 4D 4E 36 31 30 44 52 41
0x50: C2 8B 46 47 4C 31 36 34 32 31 32 58 42 C4 08 00
0x60: 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- Slot 0:
--More-- Cisco Services Performance Engine 100 for Cisco 3900 ISR Port adapter, 7 ports
--More-- Port adapter is analyzed
--More-- Port adapter insertion time 00:58:38 ago
--More-- EEPROM contents at hardware discovery:
--More-- PCB Serial Number : FOC16376PUA
--More-- Hardware Revision : 1.1
--More-- Part Number : 73-11838-08
--More-- Top Assy. Part Number : 800-32330-04
--More-- Board Revision : A0
--More-- Deviation Number : 0
--More-- Fab Version : 04
--More-- Product (FRU) Number : C3900-SPE100/K9
--More-- Version Identifier : V05
--More-- CLEI Code : IPUCA1WBAC
--More-- Processor type : C3
--More-- Chassis Serial Number : FGL164212XB
--More-- Chassis MAC Address : e4d3.f147.0580
--More-- MAC Address block size : 128
--More-- Manufacturing Test Data : 00 00 00 00 00 00 00 00
--More-- EEPROM format version 4
--More-- EEPROM contents (hex):
--More-- 0x00: 04 FF C1 8B 46 4F 43 31 36 33 37 36 50 55 41 40
--More-- 0x10: 06 13 41 01 01 82 49 2E 3E 08 C0 46 03 20 00 7E
--More-- 0x20: 4A 04 42 41 30 88 00 00 00 00 02 04 CB 8F 43 33
--More-- 0x30: 39 30 30 2D 53 50 45 31 30 30 2F 4B 39 89 56 30
--More-- 0x40: 35 20 D9 03 40 C1 CB C6 8A 49 50 55 43 41 31 57
--More-- 0x50: 42 41 43 09 C3 C2 8B 46 47 4C 31 36 34 32 31 32
--More-- 0x60: 58 42 C3 06 E4 D3 F1 47 05 80 43 00 80 C4 08 00
--More-- 0x70: 00 00 00 00 00 00 00 F3 00 03 40 01 99 FF FF FF
--More-- 0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- 0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- 0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- 0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- 0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- 0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- 0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- 0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- Internal power Supply 1 information
--More-- Top Assy. Part Number : 341-0238-03
--More-- PCB Serial Number : FPS1633008H
--More-- RMA Test History : 00
--More-- RMA Number : 0-0-0-0
--More-- RMA History : 00
--More-- Version Identifier : V03
--More-- Product (FRU) Number : PWR-3900-AC
--More-- CLEI Code : COUPAEFBAC
--More-- 0x00: 04 FF 40 05 E8 DF 45 01 55 00 EE 03 88 00 00 00
--More-- 0x10: 00 C1 8B 46 50 53 31 36 33 33 30 30 38 48 03 00
--More-- 0x20: 81 00 00 00 00 04 00 89 56 30 33 20 CB 8B 50 57
--More-- 0x30: 52 2D 33 39 30 30 2D 41 43 C6 8A 43 4F 55 50 41
--More-- 0x40: 45 46 42 41 43 F3 00 59 41 02 53 42 00 05 F8 00
--More-- 0x50: 50 01 F4 1D 03 02 EE 1F 7A 03 E8 20 59 04 E2 20
--More-- 0x60: D6 05 DC 21 66 06 D6 21 F3 07 D0 22 06 08 CA 22
--More-- 0x70: 2D 09 C4 22 4B 0A BE 22 57 0B B8 22 69 0D AC 22
--More-- 0x80: 87 0F A0 22 9B 11 94 22 B0 13 88 22 B2 17 70 22
--More-- 0x90: AA 1B 58 22 93 1F 40 22 70 23 28 22 47 27 10 22
--More-- 0xA0: 18 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
--More-- Internal power Supply 2 information
--More-- Unknown or unpowered PSU is installed
--More--
--More--
--More-- PVDM Slot 0:
--More-- 64-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
--More-- Hardware Revision : 1.0
--More-- Part Number : 73-11809-03
--More-- Board Revision : C0
--More-- Fab Version : 03
--More-- PCB Serial Number : FOC163908FL
--More-- Processor type : 00
--More-- Product (FRU) Number : PVDM3-64
--More-- Version Identifier : V01
--More-- 0x00: 04 FF 40 05 DB 41 01 00 82 49 2E 21 03 42 43 30
--More-- 0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 33 39
--More-- 0x20: 30 38 46 4C 03 00 81 00 00 00 00 04 00 09 00 CB
--More-- 0x30: 8F 50 56 44 4D 33 2D 36 34 20 20 20 20 20 20 20
--More-- 0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
--More-- 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More--
--More-- PVDM Slot 1:
--More-- PCB Serial Number : FOC163908FT
--More-- 0x20: 30 38 46 54 03 00 81 00 00 00 00 04 00 09 00 CB
--More--
--More-- WIC Slot 0:
--More-- 4 port clear channel T1/E1 HWIC
--More-- Hardware Revision : 0.0
--More-- Top Assy. Part Number : 800-32858-01
--More-- Part Number : 73-12947-01
--More-- Fab Version : 05
--More-- PCB Serial Number : FOC16314GM7
--More-- Version Identifier : V02
--More-- Product (FRU) Number : HWIC-4T1/E1
--More-- CLEI Code : COUIAKGCAB
--More-- 0x00: 04 FF 40 05 2B 41 00 00 C0 46 03 20 00 80 5A 01
--More-- 0x10: 82 49 32 93 01 42 43 30 88 00 00 00 00 02 05 C1
--More-- 0x20: 8B 46 4F 43 31 36 33 31 34 47 4D 37 03 00 81 00
--More-- 0x30: 00 00 00 04 00 89 56 30 32 20 CB 8B 48 57 49 43
--More-- 0x40: 2D 34 54 31 2F 45 31 C6 8A 43 4F 55 49 41 4B 47
--More-- 0x50: 43 41 42 D9 02 40 C1 FF FF FF FF FF FF FF FF FF
--More--
--More-- Slot 1:
--More-- SM-NM-ADPTR
--More-- Port Adapter is analyzed
--More-- Port Adapter insertion time 00:58:52 ago
--More-- PCB Serial Number : FOC16381L4T
--More-- Part Number : 73-12434-04
--More-- Top Assy. Part Number : 800-32481-01
--More-- Board Revision : G0
--More-- Deviation Number : 129133
--More-- Product (FRU) Number : SM-NM-ADPTR
--More-- 0x00: 04 FF C1 8B 46 4F 43 31 36 33 38 31 4C 34 54 40
--More-- 0x10: 05 F4 41 01 00 82 49 30 92 04 C0 46 03 20 00 7E
--More-- 0x20: E1 01 42 47 30 88 00 01 F8 6D 02 05 03 00 81 00
--More-- 0x30: 00 00 00 04 00 CB 8B 53 4D 2D 4E 4D 2D 41 44 50
--More-- 0x40: 54 52 89 56 30 31 00 D9 03 40 C1 CB F3 00 03 40
--More-- 0x50: 0B E3 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More--
--More-- Voice VM-8FXS/DID Port adapter
--More-- Port adapter insertion time 00:58:24 ago
--More-- Top Assy. Part Number : 800-34451-01
--More-- Fab Version : 06
--More-- PCB Serial Number : FOC16400WV0
--More-- Product (FRU) Number : EVM-HD-8FXS/DID
--More-- Longitudinal Calibration : 00 20 20 20 20 20 20 20
--More-- 20
--More-- CLEI Code : CNP5130AAE
--More-- 0x00: 04 FF 40 04 16 41 01 00 C0 46 03 20 00 86 93 01
--More-- 0x10: 42 43 30 88 00 00 00 00 02 06 C1 8B 46 4F 43 31
--More-- 0x20: 36 34 30 30 57 56 30 03 00 81 00 00 00 00 04 00
--More-- 0x30: CB 8F 45 56 4D 2D 48 44 2D 38 46 58 53 2F 44 49
--More-- 0x40: 44 89 56 30 35 20 D9 02 40 C1 D3 09 00 20 20 20
--More-- 0x50: 20 20 20 20 20 C6 8A 43 4E 50 35 31 33 30 41 41
--More-- 0x60: 45 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More--
--More-- EM Slot 0:
--More-- EM3-HDA-8FXS/DID Voice Expansion Module (8 port)
--More-- Top Assy. Part Number : 800-34544-01
--More-- Fab Version : 09
--More-- PCB Serial Number : FOC1634DBG5
--More-- Product (FRU) Number : EM3-HDA-8FXS/DID
--More-- CLEI Code : IPU2ALFDAC
--More-- Longitudinal Calibration : 01 10 10 95 A1 10 10 70
--More-- 94 10 10 47 8C 10 10 96
--More-- 5F 10 10 7F 6D 10 10 6D
--More-- 71 10 10 7C 8B 10 10 A2
--More-- 7B
--More-- 0x00: 04 FF 40 05 1C 41 01 00 C0 46 03 20 00 86 F0 01
--More-- 0x10: 42 41 30 88 00 00 00 00 02 09 C1 8B 46 4F 43 31
--More-- 0x20: 36 33 34 44 42 47 35 03 00 81 00 00 00 00 04 00
--More-- 0x30: CB 90 45 4D 33 2D 48 44 41 2D 38 46 58 53 2F 44
--More-- 0x40: 49 44 89 56 30 33 20 D9 02 40 C1 C6 8A 49 50 55
--More-- 0x50: 32 41 4C 46 44 41 43 D3 21 01 10 10 95 A1 10 10
--More-- 0x60: 70 94 10 10 47 8C 10 10 96 5F 10 10 7F 6D 10 10
--More-- 0x70: 6D 71 10 10 7C 8B 10 10 A2 7B FF FF FF FF FF FF
--More--
--More-- EM slot 1: None
S1#show inventory
NAME: "CISCO3925-CHASSIS", DESCR: "CISCO3925-CHASSIS"
PID: CISCO3925-CHASSIS , VID: V02, SN: FGL164212XB
NAME: "Cisco Services Performance Engine 100 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 100 for Cisco 3900 ISR"
PID: C3900-SPE100/K9 , VID: V05 , SN: FOC16376PUA
NAME: "4 port clear channel T1/E1 HWIC on Slot 0 SubSlot 0", DESCR: "4 port clear channel T1/E1 HWIC"
PID: HWIC-4T1/E1 , VID: V02 , SN: FOC16314GM7
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64 , VID: V01 , SN: FOC163908FL
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64 , VID: V01 , SN: FOC163908FT
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR , VID: V01, SN: FOC16381L4T
--More-- NAME: "High Density Voice Module - 8FXS/DID on Slot 1", DESCR: "High Density Voice Module - 8FXS/DID"
--More-- PID: EVM-HD-8FXS/DID , VID: V05 , SN: FOC16400WV0
--More--
--More-- NAME: "3rd generation eight port FXS DID voice interface daughtercard on Slot 1 SubSlot 0", DESCR: "3rd generation eight port FXS DID voice interface daughtercard"
--More-- PID: EM3-HDA-8FXS/DID , VID: V03 , SN: FOC1634DBG5
--More--
--More-- NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
--More-- PID: PWR-3900-AC , VID: V03 , SN: FPS1633008H
--More--
--More--
