Show ISDN status command is not working
ajay1komban
Beginner
Beginner
Dear all
When I try to Check show isdn command It is not working ,Every time I no shut controller interface  serial interface will be up and after some time
agan it will be down.
troller)#
Jan 26 19:57:01.895: %LINK-3-UPDOWN: Interface Serial0/0/0:0, changed state to up
Jan 26 19:57:02.895: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0:0, changed state to up
Jan 26 19:57:10.151: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Jan 26 19:57:29.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0:0, changed state to down
Ajay Jose K
Hi Ajay,
the HWIC-4T1/E1        card which u are using is used for data [high speed WAN connectivity] while the other EVM cards are used for analog voice connectivity for voice and fax which have got RJ-21 connector which could be punched on to MDF for analog DID and fax purpose.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/product_data_sheet0900aecd80710c77.html
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-density-voice-fax-network-modules/prod_qas0900aecd8016c487.html
regds,
aman
10 Replies 10
Terry Cheema
Advocate
Advocate
Is it a new setup or a working ISDN line that stopped functioning? If its a new setup (attach your sh run along the post) if not post the output of sh controller e1.
-Terry
Please rate helpful posts.
Dear All,
  It is a new set up,But Controller is not coming up
inside controller e1 0/0/0
pri group command is not available
Hi Ajay,
can u share the output of command show diag and show inventory from router?
I have been using this command for data basically for full 2MB or for channelised E1 as per time slots[ each of say 64K for one TS, 128K for 2TS as configured by TELCO]
regds,
aman
show diag
how diag
Platform mid-plane:
PCB Serial Number        : FOC16384XB1
Hardware Revision        : 1.0
Part Number              : 73-12223-02
Top Assy. Part Number    : 800-29789-02
Board Revision           : E0
Deviation Number         : 0
Fab Version              : 02
Product (FRU) Number     : CISCO3925-CHASSIS
Version Identifier       : V02
CLEI Code                : IPMN610DRA
Chassis Serial Number    : FGL164212XB
Manufacturing Test Data  : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
 0x00: 04 FF C1 8B 46 4F 43 31 36 33 38 34 58 42 31 40
 0x10: 06 48 41 01 00 82 49 2F BF 02 C0 46 03 20 00 74
 0x20: 5D 02 42 45 30 88 00 00 00 00 02 02 CB 91 43 49
 0x30: 53 43 4F 33 39 32 35 2D 43 48 41 53 53 49 53 89
 0x40: 56 30 32 00 C6 8A 49 50 4D 4E 36 31 30 44 52 41
 0x50: C2 8B 46 47 4C 31 36 34 32 31 32 58 42 C4 08 00
 0x60: 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--         Slot 0:
 --More--          Cisco Services Performance Engine 100 for Cisco 3900 ISR Port adapter, 7 ports
 --More--          Port adapter is analyzed
 --More--          Port adapter insertion time 00:58:38 ago
 --More--          EEPROM contents at hardware discovery:
 --More--          PCB Serial Number        : FOC16376PUA
 --More--          Hardware Revision        : 1.1
 --More--          Part Number              : 73-11838-08
 --More--          Top Assy. Part Number    : 800-32330-04
 --More--          Board Revision           : A0
 --More--          Deviation Number         : 0
 --More--          Fab Version              : 04
 --More--          Product (FRU) Number     : C3900-SPE100/K9
 --More--          Version Identifier       : V05
 --More--          CLEI Code                : IPUCA1WBAC
 --More--          Processor type           : C3
 --More--          Chassis Serial Number    : FGL164212XB
 --More--          Chassis MAC Address      : e4d3.f147.0580
 --More--          MAC Address block size   : 128
 --More--          Manufacturing Test Data  : 00 00 00 00 00 00 00 00
 --More--          EEPROM format version 4
 --More--          EEPROM contents (hex):
 --More--           0x00: 04 FF C1 8B 46 4F 43 31 36 33 37 36 50 55 41 40
 --More--           0x10: 06 13 41 01 01 82 49 2E 3E 08 C0 46 03 20 00 7E
 --More--           0x20: 4A 04 42 41 30 88 00 00 00 00 02 04 CB 8F 43 33
 --More--           0x30: 39 30 30 2D 53 50 45 31 30 30 2F 4B 39 89 56 30
 --More--           0x40: 35 20 D9 03 40 C1 CB C6 8A 49 50 55 43 41 31 57
 --More--           0x50: 42 41 43 09 C3 C2 8B 46 47 4C 31 36 34 32 31 32
 --More--           0x60: 58 42 C3 06 E4 D3 F1 47 05 80 43 00 80 C4 08 00
 --More--           0x70: 00 00 00 00 00 00 00 F3 00 03 40 01 99 FF FF FF
 --More--           0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--           0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--           0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--           0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--           0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--           0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--           0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--           0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--          Internal power Supply 1 information
 --More--          Top Assy. Part Number    : 341-0238-03
 --More--          PCB Serial Number        : FPS1633008H
 --More--          RMA Test History         : 00
 --More--          RMA Number               : 0-0-0-0
 --More--          RMA History              : 00
 --More--          Version Identifier       : V03
 --More--          Product (FRU) Number     : PWR-3900-AC
 --More--          CLEI Code                : COUPAEFBAC
 --More--           0x00: 04 FF 40 05 E8 DF 45 01 55 00 EE 03 88 00 00 00
 --More--           0x10: 00 C1 8B 46 50 53 31 36 33 33 30 30 38 48 03 00
 --More--           0x20: 81 00 00 00 00 04 00 89 56 30 33 20 CB 8B 50 57
 --More--           0x30: 52 2D 33 39 30 30 2D 41 43 C6 8A 43 4F 55 50 41
 --More--           0x40: 45 46 42 41 43 F3 00 59 41 02 53 42 00 05 F8 00
 --More--           0x50: 50 01 F4 1D 03 02 EE 1F 7A 03 E8 20 59 04 E2 20
 --More--           0x60: D6 05 DC 21 66 06 D6 21 F3 07 D0 22 06 08 CA 22
 --More--           0x70: 2D 09 C4 22 4B 0A BE 22 57 0B B8 22 69 0D AC 22
 --More--           0x80: 87 0F A0 22 9B 11 94 22 B0 13 88 22 B2 17 70 22
 --More--           0x90: AA 1B 58 22 93 1F 40 22 70 23 28 22 47 27 10 22
 --More--           0xA0: 18 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
 --More--          Internal power Supply 2 information
 --More--          Unknown or unpowered PSU is installed
 --More--
 --More--
 --More--          PVDM Slot 0:
 --More--          64-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
 --More--          Hardware Revision        : 1.0
 --More--          Part Number              : 73-11809-03
 --More--          Board Revision           : C0
 --More--          Fab Version              : 03
 --More--          PCB Serial Number        : FOC163908FL
 --More--          Processor type           : 00
 --More--          Product (FRU) Number     : PVDM3-64
 --More--          Version Identifier       : V01
 --More--           0x00: 04 FF 40 05 DB 41 01 00 82 49 2E 21 03 42 43 30
 --More--           0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 33 39
 --More--           0x20: 30 38 46 4C 03 00 81 00 00 00 00 04 00 09 00 CB
 --More--           0x30: 8F 50 56 44 4D 33 2D 36 34 20 20 20 20 20 20 20
 --More--           0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
 --More--           0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--           0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--           0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--
 --More--          PVDM Slot 1:
 --More--          PCB Serial Number        : FOC163908FT
 --More--           0x20: 30 38 46 54 03 00 81 00 00 00 00 04 00 09 00 CB
 --More--
 --More--          WIC Slot 0:
 --More--          4 port clear channel T1/E1 HWIC
 --More--          Hardware Revision        : 0.0
 --More--          Top Assy. Part Number    : 800-32858-01
 --More--          Part Number              : 73-12947-01
 --More--          Fab Version              : 05
 --More--          PCB Serial Number        : FOC16314GM7
 --More--          Version Identifier       : V02
 --More--          Product (FRU) Number     : HWIC-4T1/E1
 --More--          CLEI Code                : COUIAKGCAB
 --More--           0x00: 04 FF 40 05 2B 41 00 00 C0 46 03 20 00 80 5A 01
 --More--           0x10: 82 49 32 93 01 42 43 30 88 00 00 00 00 02 05 C1
 --More--           0x20: 8B 46 4F 43 31 36 33 31 34 47 4D 37 03 00 81 00
 --More--           0x30: 00 00 00 04 00 89 56 30 32 20 CB 8B 48 57 49 43
 --More--           0x40: 2D 34 54 31 2F 45 31 C6 8A 43 4F 55 49 41 4B 47
 --More--           0x50: 43 41 42 D9 02 40 C1 FF FF FF FF FF FF FF FF FF
 --More--
 --More--         Slot 1:
 --More--          SM-NM-ADPTR
 --More--          Port Adapter is analyzed
 --More--          Port Adapter insertion time 00:58:52 ago
 --More--          PCB Serial Number        : FOC16381L4T
 --More--          Part Number              : 73-12434-04
 --More--          Top Assy. Part Number    : 800-32481-01
 --More--          Board Revision           : G0
 --More--          Deviation Number         : 129133
 --More--          Product (FRU) Number     : SM-NM-ADPTR
 --More--           0x00: 04 FF C1 8B 46 4F 43 31 36 33 38 31 4C 34 54 40
 --More--           0x10: 05 F4 41 01 00 82 49 30 92 04 C0 46 03 20 00 7E
 --More--           0x20: E1 01 42 47 30 88 00 01 F8 6D 02 05 03 00 81 00
 --More--           0x30: 00 00 00 04 00 CB 8B 53 4D 2D 4E 4D 2D 41 44 50
 --More--           0x40: 54 52 89 56 30 31 00 D9 03 40 C1 CB F3 00 03 40
 --More--           0x50: 0B E3 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--
 --More--          Voice VM-8FXS/DID  Port adapter
 --More--          Port adapter insertion time 00:58:24 ago
 --More--          Top Assy. Part Number    : 800-34451-01
 --More--          Fab Version              : 06
 --More--          PCB Serial Number        : FOC16400WV0
 --More--          Product (FRU) Number     : EVM-HD-8FXS/DID
 --More--          Longitudinal Calibration : 00 20 20 20 20 20 20 20
 --More--                                    20
 --More--          CLEI Code                : CNP5130AAE
 --More--           0x00: 04 FF 40 04 16 41 01 00 C0 46 03 20 00 86 93 01
 --More--           0x10: 42 43 30 88 00 00 00 00 02 06 C1 8B 46 4F 43 31
 --More--           0x20: 36 34 30 30 57 56 30 03 00 81 00 00 00 00 04 00
 --More--           0x30: CB 8F 45 56 4D 2D 48 44 2D 38 46 58 53 2F 44 49
 --More--           0x40: 44 89 56 30 35 20 D9 02 40 C1 D3 09 00 20 20 20
 --More--           0x50: 20 20 20 20 20 C6 8A 43 4E 50 35 31 33 30 41 41
 --More--           0x60: 45 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 --More--
 --More--          EM Slot 0:
 --More--          EM3-HDA-8FXS/DID Voice Expansion Module (8 port)
 --More--          Top Assy. Part Number    : 800-34544-01
 --More--          Fab Version              : 09
 --More--          PCB Serial Number        : FOC1634DBG5
 --More--          Product (FRU) Number     : EM3-HDA-8FXS/DID
 --More--          CLEI Code                : IPU2ALFDAC
 --More--          Longitudinal Calibration : 01 10 10 95 A1 10 10 70
 --More--                                    94 10 10 47 8C 10 10 96
 --More--                                    5F 10 10 7F 6D 10 10 6D
 --More--                                    71 10 10 7C 8B 10 10 A2
 --More--                                    7B
 --More--           0x00: 04 FF 40 05 1C 41 01 00 C0 46 03 20 00 86 F0 01
 --More--           0x10: 42 41 30 88 00 00 00 00 02 09 C1 8B 46 4F 43 31
 --More--           0x20: 36 33 34 44 42 47 35 03 00 81 00 00 00 00 04 00
 --More--           0x30: CB 90 45 4D 33 2D 48 44 41 2D 38 46 58 53 2F 44
 --More--           0x40: 49 44 89 56 30 33 20 D9 02 40 C1 C6 8A 49 50 55
 --More--           0x50: 32 41 4C 46 44 41 43 D3 21 01 10 10 95 A1 10 10
 --More--           0x60: 70 94 10 10 47 8C 10 10 96 5F 10 10 7F 6D 10 10
 --More--           0x70: 6D 71 10 10 7C 8B 10 10 A2 7B FF FF FF FF FF FF
 --More--
 --More--          EM slot 1: None
S1#show inventory
NAME: "CISCO3925-CHASSIS", DESCR: "CISCO3925-CHASSIS"
PID: CISCO3925-CHASSIS , VID: V02, SN: FGL164212XB
NAME: "Cisco Services Performance Engine 100 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 100 for Cisco 3900 ISR"
PID: C3900-SPE100/K9   , VID: V05 , SN: FOC16376PUA
NAME: "4 port clear channel T1/E1 HWIC on Slot 0 SubSlot 0", DESCR: "4 port clear channel T1/E1 HWIC"
PID: HWIC-4T1/E1       , VID: V02 , SN: FOC16314GM7
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN: FOC163908FL
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN: FOC163908FT
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR       , VID: V01, SN: FOC16381L4T
 --More--         NAME: "High Density Voice Module - 8FXS/DID on Slot 1", DESCR: "High Density Voice Module - 8FXS/DID"
 --More--         PID: EVM-HD-8FXS/DID   , VID: V05 , SN: FOC16400WV0
 --More--
 --More--         NAME: "3rd generation eight port FXS DID voice interface daughtercard on Slot 1 SubSlot 0", DESCR: "3rd generation eight port FXS DID voice interface daughtercard"
 --More--         PID: EM3-HDA-8FXS/DID  , VID: V03 , SN: FOC1634DBG5
 --More--
 --More--         NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
 --More--         PID: PWR-3900-AC       , VID: V03 , SN: FPS1633008H
 --More--
 --More--
Hi Ajay,
regds,
aman
Dear Aman,
Thank you for your great support.
Ajay Jose
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
+5 to Terry and Aman for their contributions
And to whoever rated them 2, couple of things
A) When you are asked for further information because someone is trying to help, either you DO NOT rate, or provide a nice rating
B) Doing that is the fast track on getting no answers in no time at CSC for any new posts.
Aman correctly identified the issue, not his fault the card is a WAN card and not a voice card.
java
if this helps, please rate
ajay1komban
Beginner
Beginner
Show run
Current configuration : 6487 bytes
version 15.0
hostname S-VG1
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
clock timezone GMT 4
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip host cucm8 192.168.30.12
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-326141288
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-326141288
 revocation-check none
 rsakeypair TP-self-signed-326141288
crypto pki certificate chain TP-self-signed-326141288
 certificate self-signed 01
  30820240 308201A9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33323631 34313238 38301E17 0D313530 31323631 37353034
  355A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3332 36313431
  32383830 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  AD7B4B34 F460A8F5 79E6790A 4E1D896A 97D5162B 43D3C3C5 C1157BAE 82CA5811
  D3B47AD5 F9FB3A62 711EF13E F1A39F3A 8DBC36EA B74497AC 32B1CEB3 DADAE94A
  06CE005F 62DAB48E 4727A8D0 E63F68D3 E4A5B726 829E6D41 B86F0507 B7A10A0C
  5A0CDD5F 24399357 27D4B534 F701B01A 8E7F0A6F 721850AC 787B7D63 A1477F21
  02030100 01A36A30 68300F06 03551D13 0101FF04 05300301 01FF3015 0603551D
  11040E30 0C820A53 686A6D75 6E2D5647 31301F06 03551D23 04183016 80145DC3
  518C3189 27696E72 7347418D 068E6FCC 0A34301D 0603551D 0E041604 145DC351
  8C318927 696E7273 47418D06 8E6FCC0A 34300D06 092A8648 86F70D01 01040500
  03818100 3181D3A4 47439C79 8CBA64A8 E7FED5D7 67F5A3F1 5671880F F40F4962
  D8032F5D 19037942 18003850 1A55027A 373BC266 7D126FC1 00AD0514 3F7124B4
  2BC2A6AD 4069B2B3 B7BF39C8 D92CD2D0 F7D8516A 2F9F7147 A6C3E774 35A39380
  C0192813 36C112B5 E1ABD357 C5ABCDEC 1D2AAB52 6CF69D39 EB080BBB F68CA92D A33552FF
  quit
voice-card 0
 dspfarm
 dsp services dspfarm
license udi pid C3900-SPE100/K9 sn FOC16376PUA
hw-module pvdm 0/0
hw-module pvdm 0/1
username s privilege 15 secret 5 $1$.335$WWMaslXeY7GUi6xDmYASV.
username i privilege 15 secret 5 $1$Sc4z$yQ3YU9o8SNbpbwyFLIM6C0
redundancy
controller E1 0/0/0
 framing NO-CRC4
 channel-group 0 timeslots 1-31
controller E1 0/0/1
 framing NO-CRC4
controller E1 0/0/2
 shutdown
controller E1 0/0/3
 shutdown
interface GigabitEthernet0/0
 description LAN
 ip address 192.168.36.11 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:0
 no ip address
interface Serial0/0/1:0
 no ip address
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.66.0 0.0.0.255
access-list 24 permit 192.168.36.0 0.0.0.255
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
voice-port 1/0/5
voice-port 1/0/6
voice-port 1/0/7
voice-port 1/0/8
voice-port 1/0/9
voice-port 1/0/10
voice-port 1/0/11
voice-port 1/0/12
voice-port 1/0/13
voice-port 1/0/14
voice-port 1/0/15
ccm-manager switchback immediate
ccm-manager redundant-host 192.168.36.13
ccm-manager mgcp
no ccm-manager fax protocol cisco
mgcp
mgcp call-agent 192.168.36.12 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
gatekeeper
 shutdown
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
 login local
line aux 0
line vty 0 4
 access-class 23 in
 privilege level 15
 password cisco
 login
 transport input telnet ssh
line vty 5 15
 access-class 23 in
 privilege level 15
 login local
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0
ntp master 5
ntp update-calendar
end
What are you trying to configure this gateway H323 or MGCP PRI? From the config you have got some MGCP config, so just assuming you are trying to configure this as as MGCP PRI GW, do the following:
controller e1 0/0/0
shut
no framing NO-CRC4
no channel-group 0 timeslots 1-31
pri-group timeslots 1-31 service mgcp
int s0/0/0:15
isdn bind-l3 ccm
Go to CUCM and add this gateway as MGCP PRI gateway
-Terry
Recognize Your Peers
