Show ISDN status command is not working
ajay1komban
Beginner
Beginner
Dear all
When I try to Check show isdn command It is not working ,Every time I no shut controller interface  serial interface will be up and after some time
agan it will be down.
troller)#
Jan 26 19:57:01.895: %LINK-3-UPDOWN: Interface Serial0/0/0:0, changed state to up
Jan 26 19:57:02.895: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0:0, changed state to up
Jan 26 19:57:10.151: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Jan 26 19:57:29.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0:0, changed state to down
Ajay Jose K
Hi Ajay,
the HWIC-4T1/E1        card which u are using is used for data [high speed WAN connectivity] while the other EVM cards are used for analog voice connectivity for voice and fax which have got RJ-21 connector which could be punched on to MDF for analog DID and fax purpose.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/product_data_sheet0900aecd80710c77.html
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-density-voice-fax-network-modules/prod_qas0900aecd8016c487.html
regds,
aman
10 Replies 10
Terry Cheema
Advocate
Advocate
Is it a new setup or a working ISDN line that stopped functioning? If its a new setup (attach your sh run along the post) if not post the output of sh controller e1.
-Terry
Please rate helpful posts.
