SHOW SIP-UA REGISTER STATUS shows ".*"
Xian Li
When I do a “SHOW SIP-UA REGISTER STATUS”, I got two records: one is showing ".*" which registered status shows no; another one is the actual SIP number which registered status shows yes. Please see attached screenshot.
I got a problem of incoming calls can't hit the correct VOIP dial-peer, it keeps hitting a POTS dial-peer instead. I think this ".*" might be the problem. Any idea how can I get rid of it?
Rajan
Hi Xian,
Can you share the below debugs for one incoming call along with "show run" to check further,
debug voip ccapi inout
debug ccsip messages
Also mention calling and called number.
Rajan
Pls rate all helpful posts
Hi Rajan,
Please see attached debug.
As you can see, it seems that the incoming call from 0215695635 hits POTS dial peer 10 for outgoing dial peer:
dial-peer voice 10 pots
tone ringback alert-no-PI
translation-profile outgoing OUT
destination-pattern .T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0:15
instead of VOIP dial peer 12 which it supposes to be as below.
dial-peer voice 12 voip
destination-pattern 95488147
session target ipv4:180.16.152.2
voice-class codec 1
The topology is like below:
ITSP ---(SIP)---- CUBE----(SIP)----CallManager---------- Cisco IP Phone
Can you please shrine some lights on?
Thank you
