02-06-2020 10:17 AM
I have a User who wants line 2 ext to flash only, not ring.
I can put the phone in DND in CUCM, but cant find where to specify line 2 only.
using a 7942.
Solved! Go to Solution.
02-06-2020 10:30 AM
On the Directory Number Configuration, under Line2 you can set the Ring settings to "Flash Only", please check the example below:
Then press Save and Reset the phone,
George
02-06-2020 10:30 AM
George
02-06-2020 11:25 AM
Thank you very much George
