Simulate PSTN calls with GNS3
Edson Vuma
I want to simulate PSTN calls on GNS3, is there a way I can do this?
How?
Edson Vuma
-- Regards Edson Vuma
5 Replies 5
Chris Deren
I have not tried it, but you could see if csim is available.
Edson Vuma
Sorry for my question...but....what is CSIM? :)
Sent from Cisco Technical Support Android App
vemanyam
In gns3 there is no option for voice ports... So can't make calls to PSTN.
Hi Edson,
In GNS3, it doesn't support TDM so you cant test as in actual voice-ports. but you can test calls in other aspects depending what actually you may want;
Just to give you a high-level overview, if that may be of your interest;
What you can do is as create a topology to have multiple voice-gatewayds and create some inbound and outbound voip dial-peers to test calls.
thats actually what I did to simulate some testing for translation profiles and rules, SIP/H323 gateway etc.
you can check my blog post if you may like to see more;
http://networkcity.blogspot.com/search/label/SIP
M Taha
Thanks, Chris, Veera and Muhammad.
The point of this was to pratice translate rules, profiles and dial-peers...
By the way, Im having a problem downloading IOS images for GNS3....
Can you privide a link for download?
Best regards
Edson Vuma
