Simultanious use handset and headset
Tom Ribbens
Is there any combination of a 794x IP Phone and headset that allows the use of both the headset and handset in the same call?
Thanks!
Tom
mshavrov
The answer is: it depends on what is your definition of "use". Generally, Speakerphone (listening) works simultaneously on both, headset and handset (or speakerphone). However microphone works only on "active device" only. So, someone may have a conversation on the handset, and another person may listen everything on the handset, and vice versa. That's another way to do analog recording on Cisco phones (for example, if you plug PC headset adapter to the headset port, and plug it back to PC for a media recorder).
Good luck,
Mike / CCVP, CCDP, CCSP, CCNP
www.headsetadapter.com
Rob Huffman
Hi Tom,
In most cases people want this capability for "training" purposes
If that is the case then there are cordless & corded options so that both
people can use their headsets;
For wireless headsets;
plantronics 03929-63 Wireless Headset Training Adapter
For corded headsets;
Plantronics Y Cord Training Adapter 27019-03
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
