Single line, two ringtones possible?
I have a unique situation where when a call comes in via an analog line, every phone in the office rings as a broadcast. We used to have two lines set up on each phone. When an outside call would come in, it would ring the "outside extension" per-se. When someone on net called it would ring a different ringtone.
We had to change the way that operated because the sidecars that everyone can only monitor one line status per person, not all available. Now we are down to one line and basically one ringtone for a broadcast call and internal/forwarded call. However, if the right ringtone(s) are set, they ring a little differently but its barely enough to notice.
Is there ANY way around this? I have CUCM 8.5.
Joseph Martini
The slight difference you notice is inside ringtone vs outside ringtone and it's very subtle.  Unfortunately you can't set more than 1 ring tone per line.
Joseph Martini
