single login access for multiple expressway in different cluster
rajeshpat
Beginner
Beginner
Hi All,
Need your valuable advice on this. In my current organization, we have 3 voice clusters in 3 different locations like USA, Europe, and India. Now we are implementing Expressway in all 3 locations for MRA deployment. So for this, we are planning to have a single login credential (AD users) where the user can move to one location to another and access the MRA without any changes in the authentication which means he/his should not change any login information (changing the domain name or something).
     So can you please guide me on this.
Raj
Nipun Singh Raghav
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-5/Mobile-Remote-Access-via-Expressway-Deployment-Guide-X8-5.pdf
Are all the locations using the same domain ? If yes, how do you plan to provide the correct edge to the moving users ?
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Hi Nipun,
Yes, we are planning to have the same domain in all 3 location.
Raj
