Single Number Reach (SNR)
Hi all,
I have CUCM 7.1.5
Can Create SNR "Remote Destination Profile" one time for all Uesrs?
I have around 4000 users is it needs license?
Abdul
3 Accepted Solutions
moataz_mamdouh
Beginner
Beginner
Yes , you can use BAT
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
BAT is the way and with your version you will need 1 DLU per mobility enabled user.
Chris
After I used BAT, is I need to change the "Destination Number" for each user one by one? - Or you can change it from Remote destination csv file - "DESTINATION" box in the RD csv.
Rate all useful post.
Manish
7 Replies 7
moataz_mamdouh
Beginner
Beginner
Thnak you Moataz,
because each user has different Ex. on other PBX (actually the same his Ex but begin with ## ).
Manish
Chris Deren
Hall of Fame Master
Chris
Thanks Cris,
I am going to upgrade  to V10 after couple of month. is should I keep in mind these Licences For SNR?
I contact Cisco they said that no need licenses for SNR in the UCL
Thnaks
Chris Deren
Hall of Fame Master
Correct, with version 9 and newer you will not need additional licensing.
Chris
Recognize Your Peers
