SIP/2.0 404 Not Found - no succesfull incoming calls
monasir
Hi everyone,
We are in the middle of testing incoming callings numbers with (testnumbers) which we received from the ISP.
However we are not able to make successfull incoming calls.
I'm getting SIP/2.0 404 Not Found  when i do " debug ccsip message"
Its hitting the cube but its not reaching the final destination number
Please find below attached output.
I'm a little bit lost
p.s you can ignore the XXX, i have replaced the ip numbers and ISP info with XXX due to private reasons.
Nov 20 09:18:55: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:XXXXXXX@190.123.18.242:5060 SIP/2.0
Via: SIP/2.0/UDP XX.XX.XX.XX:5060;branch=z9hG4bK+d9290d30e1066bd3d8b3129a49c2688a1+sip+1+a6c01676
From: "Anonymous" <sip:anonymous@voip.XXX.XXX>;tag=XX.XX.XX.XX+1+c29caf4a+ad086cdd
To: <sip:XXXXXXX@voip.XXX.XXX>
CSeq: 71923967 INVITE
Expires: 180
Content-Length: 175
Call-Info: <sip:XX.XX.XX.XX:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Supported: resource-priority,siprec, 100rel
Contact: <sip:ddbd52d2c3c6c68463c77b294e9cf81d@XX.XX.XX.XX:5060>
Content-Type: application/sdp
Allow-Events: message-summary, refer, dialog, line-seize, presence, call-info, as-feature-event, calling-name
Call-ID: 0gQAAC8WAAACBAAALxYAACoiknDbZYaoFR3vpS0/I/JzSZeDyZ7EXNp1OlLZ9FIj@XX.XX.XX.XX
Organization: Metaswitch Networks
Max-Forwards: 63
Accept: application/sdp, application/dtmf-relay
v=0
o=- 118704951517250 118704951517250 IN IP4 XX.XX.XX.XX
s=-
c=IN IP4 XX.XX.XX.XX
t=0 0
m=audio 30908 RTP/AVP 8 101
a=rtpmap:101 telephone-event/8000
a=ptime:20
Nov 20 09:18:55: //4101/AA9C3E42902C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 20 Nov 2018 09:18:55 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.5.3.S4b
Content-Length: 0
Nov 20 09:18:55: //4102/AA9C3E42902C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:XXXXXXX@XX.XX.XX.XX SIP/2.0
Via: SIP/2.0/UDP 10.22.31.14:5060;branch=z9hG4bK5AE216A
Remote-Party-ID: "Anonymous" <sip:anonymous@10.22.31.14>;party=calling;screen=no;privacy=full
From: "anonymous" <sip:anonymous@voip.XXX.XXX>;tag=4D478B2-267
To: <sip:XXXXXXX@XX.XX.XX.XX>
Call-ID: AA9D0128-EBFD11E8-90328B52-134233CD@10.22.31.14
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2862366274-3959230952-2418838354-0323105741
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S4b
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1542719935
Contact: <sip:anonymous@10.22.31.14:5060>
Call-Info: <sip:10.22.31.14:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: kpml, telephone-event
Max-Forwards: 62
Content-Disposition: session;handling=required
Content-Length: 243
v=0
o=CiscoSystemsSIP-GW-UserAgent 9531 4628 IN IP4 10.22.31.14
s=SIP Call
c=IN IP4 10.22.31.14
t=0 0
m=audio 8060 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-15
a=ptime:20
Received:
SIP/2.0 100 Trying
Date: Tue, 20 Nov 2018 13:18:55 GMT
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Received:
To: <sip:XXXXXXX@XX.XX.XX.XX>;tag=20851~8eaa9458-4704-4a2a-b676-2e79543f0091-28338493
CSeq: 101 INVITE
Reason: Q.850;cause=1
Server: Cisco-CUCM12.0
Session-ID: 00000000000000000000000000000000;remote=81f3f5158816b3dcc94601e50ab20851
Content-Length: 0
Sent:
ACK sip:XXXXXXX@XX.XX.XX.XX SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
INVITE sip:XXXXXXX@10.22.93.20 SIP/2.0
Via: SIP/2.0/UDP 10.22.31.14:5060;branch=z9hG4bK5AFAED
From: "anonymous" <sip:anonymous@voip.XXX.XXX>;tag=4D478B7-E1D
To: <sip:XXXXXXX@10.22.93.20>
Min-SE:  1800
CSeq: 102 INVITE
Expires: 180
Max-Forwards: 62
Content-Length: 243
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
Received:
To: <sip:XXXXXXX@10.22.93.20>;tag=20635~8eaa9458-4704-4a2a-b676-2e79543f0091-45115694
CSeq: 102 INVITE
Session-ID: 00000000000000000000000000000000;remote=81f3f5158816b3dcc94601e50ab20635
Content-Length: 0
Sent:
ACK sip:XXXXXXX@10.22.93.20 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Sent:
To: <sip:XXXXXXX@voip.XXX.XXX>;tag=4D478BF-1DE3
Warning: 399 190.123.18.242 "No matching outgoing dial-peer"
Content-Length: 0
Received:
ACK sip:XXXXXXX@190.123.18.242:5060 SIP/2.0
CSeq: 71923967 ACK
Content-Length: 0
Max-Forwards: 63
Nov 20 09:19:01: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.22.31.14:5060 SIP/2.0
Via: SIP/2.0/UDP 10.22.93.20:5060;branch=z9hG4bK3d47708d59fc
To: <sip:10.22.31.14>
Date: Tue, 20 Nov 2018 13:19:01 GMT
Call-ID: d6ff9600-bf4109c5-3d2b-145d160a@10.22.93.20
User-Agent: Cisco-CUCM12.0
CSeq: 101 OPTIONS
Contact: <sip:10.22.93.20:5060>
Max-Forwards: 0
Content-Length: 0
Nov 20 09:19:01: //4103/AE5A30119033/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.22.31.14>;tag=4D49133-171F
Date: Tue, 20 Nov 2018 09:19:01 GMT
CSeq: 101 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 8071 2281 IN IP4 10.22.31.14
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Nov 20 09:19:10: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP XX.XX.XX.XX:5060;branch=z9hG4bK42635009ef02
Date: Tue, 20 Nov 2018 13:19:10 GMT
Call-ID: dc5ce080-bf4109ce-3fa8-a5d160a@XX.XX.XX.XX
CSeq: 101 OPTIONS
Contact: <sip:XX.XX.XX.XX:5060>
Max-Forwards: 0
Content-Length: 0
Nov 20 09:19:10: //4104/B3A3CB429034/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.22.31.14>;tag=4D4B3DA-1B40
Date: Tue, 20 Nov 2018 09:19:10 GMT
CSeq: 101 OPTIONS
Content-Length: 369
v=0
o=CiscoSystemsSIP-GW-UserAgent 8921 723 IN IP4 10.22.31.14
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
8 Replies 8
Rajan
CUBE receives call from ISP and send the invite to your CUCM. CUCM responds back with cause code 1 which is unallocated/unassigned number. YOu need to check whether the number sent in the invite is proper extension configured in CUCM and whether the digits received are correct and as required in CUCM.
Rajan
Pls rate all useful posts
Hi, from logs I can see the following messages exchange:
your cisco recevices a call from a Metaswitch:
Nov 20 09:18:55
Received:
your cisco sends a call other party (Cisco-CUCM12.0)
Nov 20 09:18:55
Sent voip.XXX.XXX:
your cisco receives the 404 from other (Cisco-CUCM12.0)
Nov 20 09:18:55:
Received:
You must investigate inside the CUCM. Is the number omitted (INVITE sip:XXXXXXX) configured in the CUCM?
Regards.
Hi guys,
To make things clear...
Ive created a dial-peer like this which will match calls from outbound :
dial-peer voice 21 voip
 description Outbound to CUCM
 destination-pattern 1234567
 session protocol sipv2
 session transport udp
 session server-group 1
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0/1
 voice-class sip bind media source-interface GigabitEthernet0/0/1
 dtmf-relay rtp-nte sip-notify sip-kpml
 fax rate 14400
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
 ip qos dscp cs3 signaling
 no vad
Ive created a translation pattern in cucm with 1234567 which contains a partition.
This partition is a member of a CSS which is also created , and which is also defined in the sip trunk of the " inbound calls"
Are you seeing the configured number (For ex. 1234567 ) sent in the Invite to CUCM ?
In the SIP trunk inbound call config, significant digits selected correctly ?
The number TP will be translated to in CUCM is a valid number ? you can check this by dialing the TP from any internal extension
Hi ,
Ive got it fixed, by translating the number (translation pattern) directly to a fixed number .
The phone rings, but im facing a new problem.
I can hear the caller but the caller does not hear me.
so im having " one way audio"
are there things that i can check to have a proper call?
Hi, in which direction is the audio? From CUCM to provider or from provider to CUCM?
Can you add a new debug ccsip messages from CUBE?
Regards.
Hi Daniele,
I can hear the caller but he can not hear me, i'm dialing with a mobile to the test number.
please find below the output of the test call with one way audio
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.11.20 15:42:19 =~=~=~=~=~=~=~=~=~=~=~=
Nov 20 10:45:53: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1234567@190.123.18.242:5060 SIP/2.0
Via: SIP/2.0/UDP 12.34.56.78:5060;branch=z9hG4bK+10f90b56c97612764c70cc4ce6096ca31+sip+1+a6c05856
From: "Anonymous" <sip:anonymous@voip.xx.xx>;tag=12.34.56.78+1+1cecff76+225bfec
To: <sip:1234567@voip.xx.xx>
CSeq: 76167071 INVITE
Expires: 180
Content-Length: 177
Call-Info: <sip:12.34.56.78:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Contact: <sip:ddbd52d2c3c6c68463c77b294e9cf81d@12.34.56.78:5060>
Call-ID: 0gQAAC8WAAACBAAALxYAAMQcOCHvDI8b+937Jj2Jkqr/I2ybyqV29fdaSuun4HI1@12.34.56.78
Max-Forwards: 69
v=0
o=- 110054892600497 110054892600497 IN IP4 12.34.56.78
s=-
c=IN IP4 12.34.56.78
t=0 0
m=audio 31002 RTP/AVP 2 8 101
a=ptime:20
Nov 20 10:45:53: //4390/D06A7A449184/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 20 Nov 2018 10:45:53 GMT
Content-Length: 0
Nov 20 10:45:53: //4391/D06A7A449184/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1234567@xx.xx.xx.xx SIP/2.0
Via: SIP/2.0/UDP 10.22.31.14:5060;branch=z9hG4bK62616C
From: "anonymous" <sip:anonymous@voip.xx.xx>;tag=524151E-23DB
To: <sip:1234567@xx.xx.xx.xx>
Call-ID: D06B166C-EC0911E8-918A8B52-134233CD@10.22.31.14
Min-SE:  1800
Cisco-Guid: 3496639044-3960017384-2441382738-0323105741
CSeq: 101 INVITE
Timestamp: 1542725153
Expires: 180
Max-Forwards: 68
Content-Length: 242
v=0
o=CiscoSystemsSIP-GW-UserAgent 490 4803 IN IP4 10.22.31.14
s=SIP Call
t=0 0
m=audio 8108 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
Received:
SIP/2.0 100 Trying
Date: Tue, 20 Nov 2018 14:45:53 GMT
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 180 Ringing
To: <sip:1234567@xx.xx.xx.xx>;tag=21622~8eaa9458-4704-4a2a-b676-2e79543f0091-28338523
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-ID: 282c2d0a00105000a00000451d6e3d77;remote=81f3f5158816b3dcc94601e50ab21622
P-Asserted-Identity: "Test Test" <sip:9902@xx.xx.xx.xx>
Remote-Party-ID: "Test Test" <sip:9902@xx.xx.xx.xx>;party=called;screen=yes;privacy=off
Contact: <sip:1234567@xx.xx.xx.xx:5060>;+u.sip!devicename.ccm.cisco.com="SEP00451D6E3D77"
Content-Length: 0
Sent:
SIP/2.0 180 Ringing
To: <sip:1234567@voip.xx.xx>;tag=524175B-8E8
Require: 100rel
RSeq: 2447
Remote-Party-ID: "Test Test" <sip:9902@190.123.18.242>;party=called;screen=yes;privacy=off
Contact: <sip:1234567@190.123.18.242:5060>
Content-Length: 0
Received:
PRACK sip:1234567@190.123.18.242:5060 SIP/2.0
Via: SIP/2.0/UDP 12.34.56.78:5060;branch=z9hG4bK+00aeeba2f89c920f7e626860fd74439b1+sip+1+a6c05857
CSeq: 76167072 PRACK
RAck: 2447 76167071 INVITE
Content-Length: 0
Supported: resource-priority, siprec, 100rel
Max-Forwards: 69
Sent:
SIP/2.0 200 OK
Content-Length: 0
Nov 20 10:45:55: //4391/D06A7A449184/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow-Events: presence, kpml
Supported: replaces
Session-Expires:  1800;refresher=uas
Require:  timer
P-Asserted-Identity: <sip:9902@xx.xx.xx.xx>
Remote-Party-ID: <sip:9902@xx.xx.xx.xx>;party=called;screen=yes;privacy=off
Content-Length:220
v=0
o=CiscoSystemsCCM-SIP 21622 1 IN IP4 10.22.32.1
s=SIP Call
c=IN IP4 10.22.32.1
b=TIAS:64000
b=AS:64
t=0 0
m=audio 22280 RTP/AVP 8 101
a=fmtp:101 0-15
Sent:
ACK sip:1234567@xx.xx.xx.xx:5060 SIP/2.0
Via: SIP/2.0/UDP 10.22.31.14:5060;branch=z9hG4bK6273AA
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Nov 20 10:45:55: //4390/D06A7A449184/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Remote-Party-ID: <sip:9902@190.123.18.242>;party=called;screen=yes;privacy=off
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 252
v=0
o=CiscoSystemsSIP-GW-UserAgent 6531 1070 IN IP4 190.123.18.242
s=SIP Call
c=IN IP4 190.123.18.242
t=0 0
m=audio 8106 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
Nov 20 10:45:55: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 12.34.56.78:5060;branch=z9hG4bK+a25dd747758f11d3ed701106ad34dd4f1+sip+1+a6c05859
CSeq: 76167071 ACK
Content-Length: 0
Max-Forwards: 69
Nov 20 10:46:10: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:anonymous@10.22.31.14:5060 SIP/2.0
Via: SIP/2.0/UDP xx.xx.xx.xx:5060;branch=z9hG4bK44996b319433
From: <sip:1234567@xx.xx.xx.xx>;tag=21622~8eaa9458-4704-4a2a-b676-2e79543f0091-28338523
To: "anonymous" <sip:anonymous@voip.xx.xx>;tag=524151E-23DB
Date: Tue, 20 Nov 2018 14:45:55 GMT
Max-Forwards: 70
CSeq: 101 BYE
Reason: Q.850;cause=16
Content-Length: 0
Nov 20 10:46:10: //4390/D06A7A449184/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:ddbd52d2c3c6c68463c77b294e9cf81d@12.34.56.78:5060 SIP/2.0
Via: SIP/2.0/UDP 190.123.18.242:5060;branch=z9hG4bK628106F
To: "Anonymous" <sip:anonymous@voip.xx.xx>;tag=12.34.56.78+1+1cecff76+225bfec
Date: Tue, 20 Nov 2018 10:45:55 GMT
Max-Forwards: 70
Timestamp: 1542725170
CSeq: 101 BYE
Content-Length: 0
Nov 20 10:46:10: //4391/D06A7A449184/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 20 Nov 2018 10:46:10 GMT
CSeq: 101 BYE
Content-Length: 0
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
Server: DC-SIP/2.0
Nov 20 10:46:20: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP xx.xx.xx.xx:5060;branch=z9hG4bK449b3aea954d
Date: Tue, 20 Nov 2018 14:46:20 GMT
Call-ID: 9af8b80-bf411e3c-41b4-a5d160a@xx.xx.xx.xx
CSeq: 101 OPTIONS
Contact: <sip:xx.xx.xx.xx:5060>
Max-Forwards: 0
Content-Length: 0
Nov 20 10:46:20: //4392/E0C9C190918B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.22.31.14>;tag=5248065-21E8
Date: Tue, 20 Nov 2018 10:46:20 GMT
CSeq: 101 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 4752 4311 IN IP4 10.22.31.14
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Received:
Via: SIP/2.0/UDP 10.22.93.20:5060;branch=z9hG4bK3f2912cb986d
Call-ID: 9af8b80-bf411e3c-3f0d-145d160a@10.22.93.20
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Nov 20 10:46:20: //4393/E0EA1A9B918C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.22.31.14>;tag=5248139-14DD
CSeq: 101 OPTIONS
Content-Length: 369
v=0
o=CiscoSystemsSIP-GW-UserAgent 5105 882 IN IP4 10.22.31.14
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
This issue is also fixed.
Ive asked the firewall engineer to disable sip inspection.
And it seemed that RTP traffic was blocked:
16384 - 32767 / UDP
Real-Time Protocol (RTP), Secure Real-Time Protocol (SRTP)
continuing with testing outgoing test calls
