SIP/2.0 488 Not Acceptable Media
bkhanal1971
Level 3
Level 3
I have a cucm cluster and a cube1 router as pstn gateway. in the same network I have a fax server and its own dedicated cube2 router. I have a few DIDs in the cube1 router that I want to use in the fax server. Here cube1 is used to handle calls to/from CUCM cluster but I've been asked to test if I can use the same CUBE1 router to route fax calls to the fax server through dial peer. Currently I forward the fax numbers coming to CUBE1 to CUCM and then from CTI RP to another DID in the fax server. It is working just fine. But I am trying to avoid using 2 numbers which would, otherwise be possible with a single number if I can use cube1 to route the calls to fax server through the dial peer. The CUBE1 is in production and don't have much luxury to make changes that would impact the calls to in the CUCM environment.
I configured the dialpeer with the destination pattern of the number that I would like to send to fax server and session target as the IP address of the fax server as well. The DID has been programmed in the fax server. Now, when I call that number, it hits the fax server and I get the fax tone. However, it disconnects after a few seconds. I have captured the debugs and pasted here for your review and see what is going wrong here. It contains ccsip messages and cacapi inout debugs.
Calling number is 2024655568 and called number 4033131776
call flow : 2024655568-BellCanada-CUBE1-FaxServer
Any help would be really appreciated.
Thank you, Khanal
076453: *Oct 17 2017 21:30:13.380: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4033131776@sbc-tr2.livingstonintl.com;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.30.1.4:5060;branch=z9hG4bKjcedt7304odckohmdbv0.1
From: <sip:+12024655568@siptrunking.bell.ca;user=phone>;tag=1432350286-1508273775718-
To: "Livingston Intl"<sip:4033131776@sbc-tr2.livingstonintl.com>
Call-ID: BW165615718171017-1416679017@10.92.24.43
CSeq: 370127412 INVITE
Contact: <sip:172.30.1.4:5060;transport=udp>
Supported: 100rel
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Recv-Info: x-broadworks-client-session-info
Accept: application/btbc-session-info,application/media_control+xml,application/sdp,multipart/mixed
Max-Forwards: 19
Content-Type: application/sdp
Content-Length: 167
v=0
o=- 3305155623 1 IN IP4 172.30.1.4
s=-
c=IN IP4 172.30.1.4
t=0 0
m=audio 50194 RTP/AVP 0 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
076454: *Oct 17 2017 21:30:13.381: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=4033131776, Called Number=4033131776, Peer Info Type=DIALPEER_INFO_SPEECH
076455: *Oct 17 2017 21:30:13.381: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=4033131776
076456: *Oct 17 2017 21:30:13.381: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
076457: *Oct 17 2017 21:30:13.381: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=4033131776, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
076458: *Oct 17 2017 21:30:13.381: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=3285
2: Dial-peer Tag=302
076459: *Oct 17 2017 21:30:13.381: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=+12024655568, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
076460: *Oct 17 2017 21:30:13.382: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=301
076461: *Oct 17 2017 21:30:13.382: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
076462: *Oct 17 2017 21:30:13.382: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
076463: *Oct 17 2017 21:30:13.383: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
076464: *Oct 17 2017 21:30:13.383: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076465: *Oct 17 2017 21:30:13.383: //-1/31E3DB13B7F0/DPM/dpAssociateIncomingPeerCore:
Calling Number=+12024655568, Called Number=4033131776, Voice-Interface=0x0,
076466: *Oct 17 2017 21:30:13.383: //-1/31E3DB13B7F0/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_VIA_URI; Incoming Dial-peer=100
076467: *Oct 17 2017 21:30:13.383: //-1/31E3DB13B7F0/DPM/dpMatchSafModulePlugin:
076468: *Oct 17 2017 21:30:13.383: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Tag=100
076469: *Oct 17 2017 21:30:13.383: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Result=0 Bitmap=0x0
076470: *Oct 17 2017 21:30:13.385: //-1/31E3DB13B7F0/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=+12024655568
----- ccCallInfo IE subfields -----
cisco-ani=+12024655568
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=4033131776
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
076471: *Oct 17 2017 21:30:13.385: //-1/31E3DB13B7F0/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7FF404FF9F70, Call Info(
Calling Number=+12024655568,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=4033131776(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=6590918
076472: *Oct 17 2017 21:30:13.385: //-1/31E3DB13B7F0/CCAPI/ccCheckClipClir:
In: Calling Number=+12024655568(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
076473: *Oct 17 2017 21:30:13.385: //-1/31E3DB13B7F0/CCAPI/ccCheckClipClir:
Out: Calling Number=+12024655568(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
076474: *Oct 17 2017 21:30:13.385: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
076475: *Oct 17 2017 21:30:13.385: :cc_get_feature_vsa malloc success
076476: *Oct 17 2017 21:30:13.385: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
076477: *Oct 17 2017 21:30:13.385: cc_get_feature_vsa count is 31
076478: *Oct 17 2017 21:30:13.385: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
076479: *Oct 17 2017 21:30:13.385: :FEATURE_VSA attributes are: feature_name:0,feature_time:140686110087692,feature_id:581663
076480: *Oct 17 2017 21:30:13.387: //6590918/31E3DB13B7F0/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=+12024655568(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=4033131776(TON=Unknown, NPI=Unknown))
076481: *Oct 17 2017 21:30:13.388: //6590918/31E3DB13B7F0/CCAPI/cc_process_call_setup_ind:
Event=0x7FF4099FFD88
076482: *Oct 17 2017 21:30:13.388: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 4033131776
076483: *Oct 17 2017 21:30:13.388: //6590918/31E3DB13B7F0/CCAPI/ccCallSetContext:
Context=0x7FF40E7BC9C0
076484: *Oct 17 2017 21:30:13.388: //6590918/31E3DB13B7F0/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 6590918 with tag 100 to app "_ManagedAppProcess_Default"
076485: *Oct 17 2017 21:30:13.388: //6590918/31E3DB13B7F0/CCAPI/ccCallProceeding:
076486: *Oct 17 2017 21:30:13.389: //-1/31E3DB13B7F0/DPM/dpMatchPeersCore:
Calling Number=, Called Number=4033131776, Peer Info Type=DIALPEER_INFO_SPEECH
076487: *Oct 17 2017 21:30:13.389: //-1/31E3DB13B7F0/DPM/dpMatchPeersCore:
076488: *Oct 17 2017 21:30:13.389: //-1/31E3DB13B7F0/DPM/dpMatchPeersCore:
076489: *Oct 17 2017 21:30:13.389: //-1/31E3DB13B7F0/DPM/dpMatchSafModulePlugin:
dialstring=4033131776, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
076490: *Oct 17 2017 21:30:13.389: //-1/31E3DB13B7F0/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
076491: *Oct 17 2017 21:30:13.389: //-1/31E3DB13B7F0/DPM/dpMatchPeersCore:
076492: *Oct 17 2017 21:30:13.389: //-1/31E3DB13B7F0/DPM/dpMatchPeersCore:
076493: *Oct 17 2017 21:30:13.389: //-1/31E3DB13B7F0/DPM/dpMatchPeersCore:
076494: *Oct 17 2017 21:30:13.389: //-1/31E3DB13B7F0/DPM/dpMatchSafModulePlugin:
076495: *Oct 17 2017 21:30:13.389: //-1/31E3DB13B7F0/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
076496: *Oct 17 2017 21:30:13.389: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076497: *Oct 17 2017 21:30:13.390: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076498: *Oct 17 2017 21:30:13.390: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076499: *Oct 17 2017 21:30:13.390: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076500: *Oct 17 2017 21:30:13.390: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
076501: *Oct 17 2017 21:30:13.390: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=4033131776, Called Number=, Voice-Interface=0x0,
076502: *Oct 17 2017 21:30:13.390: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=3285
076503: *Oct 17 2017 21:30:13.390: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076504: *Oct 17 2017 21:30:13.390: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
076505: *Oct 17 2017 21:30:13.390: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
076506: *Oct 17 2017 21:30:13.390: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076507: *Oct 17 2017 21:30:13.391: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076508: *Oct 17 2017 21:30:13.391: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076509: *Oct 17 2017 21:30:13.391: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076510: *Oct 17 2017 21:30:13.391: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076511: *Oct 17 2017 21:30:13.391: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
076512: *Oct 17 2017 21:30:13.391: //-1/31E3DB13B7F0/DPM/dpMatchPeersCore:
076513: *Oct 17 2017 21:30:13.391: //-1/31E3DB13B7F0/DPM/dpMatchPeersCore:
076514: *Oct 17 2017 21:30:13.392: //-1/31E3DB13B7F0/DPM/dpMatchPeersCore:
076515: *Oct 17 2017 21:30:13.392: //-1/31E3DB13B7F0/DPM/dpMatchSafModulePlugin:
076516: *Oct 17 2017 21:30:13.392: //-1/31E3DB13B7F0/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
076517: *Oct 17 2017 21:30:13.392: //6590918/31E3DB13B7F0/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=3285, Params=0x7FF40F60EA30, Progress Indication=NULL(0)
076518: *Oct 17 2017 21:30:13.392: //6590918/31E3DB13B7F0/CCAPI/ccCheckClipClir:
076519: *Oct 17 2017 21:30:13.392: //6590918/31E3DB13B7F0/CCAPI/ccCheckClipClir:
076520: *Oct 17 2017 21:30:13.392: //6590918/31E3DB13B7F0/CCAPI/ccCallSetupRequest:
Destination Pattern=4033131776, Called Number=4033131776, Digit Strip=FALSE
076521: *Oct 17 2017 21:30:13.392: //6590918/31E3DB13B7F0/CCAPI/ccCallSetupRequest:
Redirect Number=, Display Info=
Account Number=+12024655568, Final Destination Flag=TRUE,
Guid=31E3DB13-B2B9-11E7-B7F0-EA970D6A08AF, Outgoing Dial-peer=3285
076522: *Oct 17 2017 21:30:13.392: //6590918/31E3DB13B7F0/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=4033131776
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
076523: *Oct 17 2017 21:30:13.392: //6590918/31E3DB13B7F0/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7FF404FF9F70, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=+12024655568,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=4033131776(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3285, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
076524: *Oct 17 2017 21:30:13.392: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
076525: *Oct 17 2017 21:30:13.392: :cc_get_feature_vsa malloc success
076526: *Oct 17 2017 21:30:13.392: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
076527: *Oct 17 2017 21:30:13.392: cc_get_feature_vsa count is 32
076528: *Oct 17 2017 21:30:13.392: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
076529: *Oct 17 2017 21:30:13.392: :FEATURE_VSA attributes are: feature_name:0,feature_time:140686110094188,feature_id:581664
076530: *Oct 17 2017 21:30:13.394: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076531: *Oct 17 2017 21:30:13.394: cc_api_get_xcode_stream : 4983
076532: *Oct 17 2017 21:30:13.394: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076533: *Oct 17 2017 21:30:13.394: cc_api_get_xcode_stream : 4983
076534: *Oct 17 2017 21:30:13.394: //6590918/31E3DB13B7F0/CCAPI/cc_api_event_indication:
Event=101, Call Id=6590918
076535: *Oct 17 2017 21:30:13.394: //6590918/31E3DB13B7F0/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
076536: *Oct 17 2017 21:30:13.394: //6590919/31E3DB13B7F0/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
076537: *Oct 17 2017 21:30:13.394: //6590919/31E3DB13B7F0/CCAPI/ccCallSetContext:
Context=0x7FF40F60E9B0
076538: *Oct 17 2017 21:30:13.394: //6590918/31E3DB13B7F0/CCAPI/ccSaveDialpeerTag:
076539: *Oct 17 2017 21:30:13.395: //6590919/31E3DB13B7F0/CCAPI/ccGetMediaClassTag:
media class tag 0
076540: *Oct 17 2017 21:30:13.395: //6590919/31E3DB13B7F0/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
076541: *Oct 17 2017 21:30:13.395: //6590918/31E3DB13B7F0/CCAPI/ccGetMediaClassTag:
media class tag 0
076542: *Oct 17 2017 21:30:13.395: //6590918/31E3DB13B7F0/CCAPI/ccSetMediaclassIp2ipTags:
076543: *Oct 17 2017 21:30:13.395: //6590919/31E3DB13B7F0/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
076544: *Oct 17 2017 21:30:13.395: //6590918/31E3DB13B7F0/CCAPI/ccGet_xc_nr_asp_info:
076545: *Oct 17 2017 21:30:13.395: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 6590918
076546: *Oct 17 2017 21:30:13.397: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076547: *Oct 17 2017 21:30:13.397: cc_api_get_xcode_stream : 4983
076548: *Oct 17 2017 21:30:13.398: //6590919/31E3DB13B7F0/CCAPI/cc_api_call_proceeding:
Interface=0x7FF404FF9F70, Progress Indication=NULL(0)
076549: *Oct 17 2017 21:30:13.399: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076550: *Oct 17 2017 21:30:13.399: cc_api_get_xcode_stream : 4983
076551: *Oct 17 2017 21:30:13.399: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076552: *Oct 17 2017 21:30:13.399: cc_api_get_xcode_stream : 4983
076553: *Oct 17 2017 21:30:13.400: //6590918/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 17 Oct 2017 21:30:13 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.5.3.S2
Content-Length: 0
076554: *Oct 17 2017 21:30:13.400: //6590919/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4033131776@10.253.129.52:5060 SIP/2.0
Via: SIP/2.0/UDP 172.29.200.33:5060;branch=z9hG4bK25EA321D0C
From: <sip:+12024655568@lii01.livun.com>;tag=56E55DB8-AC
To: <sip:4033131776@10.253.129.52>
Call-ID: 31E69A60-B2B911E7-B7F6EA97-D6A08AF@lii01.livun.com
Supported: 100rel,timer,resource-priority,replaces,histinfo,sdp-anat
Min-SE: 1800
Cisco-Guid: 0837016339-2998473191-3086019223-0225052847
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1508275813
Contact: <sip:+12024655568@172.29.200.33:5060>
Call-Info: <sip:172.29.200.33:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
History-Info: <sip:4033131776@10.253.129.52:5060>;index=1
Expires: 180
Allow-Events: kpml, telephone-event
Max-Forwards: 18
P-Asserted-Identity: <sip:+12024655568@lii01.livun.com>
Content-Disposition: session;handling=required
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 198 7666 IN IP4 172.29.200.33
s=SIP Call
c=IN IP4 172.29.200.33
t=0 0
m=audio 43206 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-15
a=ptime:20
076555: *Oct 17 2017 21:30:13.406: //6590919/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:4033131776@10.253.129.52>;tag=8e28930-0-13c4-55013-b8555b-71de78c1-b8555b
CSeq: 101 INVITE
Supported: timer
User-Agent: Brktsip/6.2.8B19 (Dialogic)
Contact: <sip:10.253.129.52>
Content-Length: 0
076556: *Oct 17 2017 21:30:13.406: //6590919/31E3DB13B7F0/CCAPI/cc_api_call_alert:
Interface=0x7FF404FF9F70, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
076557: *Oct 17 2017 21:30:13.406: //6590919/31E3DB13B7F0/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
076558: *Oct 17 2017 21:30:13.406: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076559: *Oct 17 2017 21:30:13.407: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076560: *Oct 17 2017 21:30:13.407: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076561: *Oct 17 2017 21:30:13.407: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076562: *Oct 17 2017 21:30:13.407: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
076563: *Oct 17 2017 21:30:13.407: //6590918/31E3DB13B7F0/CCAPI/ccCallAlert:
076564: *Oct 17 2017 21:30:13.407: //6590918/31E3DB13B7F0/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
076565: *Oct 17 2017 21:30:13.407: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=+12024655568, Peer Info Type=DIALPEER_INFO_SPEECH
076566: *Oct 17 2017 21:30:13.407: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=+12024655568
076567: *Oct 17 2017 21:30:13.407: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076568: *Oct 17 2017 21:30:13.407: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076569: *Oct 17 2017 21:30:13.407: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=301
2: Dial-peer Tag=200
076570: *Oct 17 2017 21:30:13.407: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
076571: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
076572: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076573: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076574: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076575: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076576: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076577: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
076578: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076579: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076580: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076581: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076582: *Oct 17 2017 21:30:13.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
076583: *Oct 17 2017 21:30:13.408: //6590918/31E3DB13B7F0/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=6590918
076584: *Oct 17 2017 21:30:13.409: //6590918/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "Livingston Intl"<sip:4033131776@sbc-tr2.livingstonintl.com>;tag=56E55DC2-1286
Require: 100rel
RSeq: 4258
P-Asserted-Identity: <sip:4033131776@lii01.livun.com>
Contact: <sip:4033131776@172.21.121.130:5060>
Content-Length: 0
076585: *Oct 17 2017 21:30:13.409: //6590919/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: timer
Content-Length: 150
v=0
o=- 2221343829 0873552000 IN IP4 10.253.129.52
s=no_session_name
t=0 0
m=audio 56872 RTP/AVP 0
c=IN IP4 10.253.129.52
076586: *Oct 17 2017 21:30:13.410: //6590919/31E3DB13B7F0/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6590919,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
Modem=0x0, Codec Bytes=160, Signal Type=2)
076587: *Oct 17 2017 21:30:13.410: //6590919/31E3DB13B7F0/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
076588: *Oct 17 2017 21:30:13.411: //6590918/31E3DB13B7F0/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6590918,
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Fax Version:=0, Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1189)
076589: *Oct 17 2017 21:30:13.411: //6590918/31E3DB13B7F0/CCAPI/cc_api_caps_ack:
076590: *Oct 17 2017 21:30:13.411: //6590919/31E3DB13B7F0/CCAPI/cc_api_event_indication:
Event=103, Call Id=6590919
076591: *Oct 17 2017 21:30:13.411: //6590919/31E3DB13B7F0/CCAPI/cc_api_event_indication:
076592: *Oct 17 2017 21:30:13.411: //6590919/31E3DB13B7F0/CCAPI/cc_api_call_connected:
Interface=0x7FF404FF9F70, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
076593: *Oct 17 2017 21:30:13.411: //6590919/31E3DB13B7F0/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
076594: *Oct 17 2017 21:30:13.411: //6590919/31E3DB13B7F0/CCAPI/cc_api_event_indication:
Event=111, Call Id=6590919
076595: *Oct 17 2017 21:30:13.411: //6590919/31E3DB13B7F0/CCAPI/cc_api_event_indication:
076596: *Oct 17 2017 21:30:13.412: //6590919/31E3DB13B7F0/CCAPI/cc_api_event_indication:
Event=213, Call Id=6590919
076597: *Oct 17 2017 21:30:13.412: //6590919/31E3DB13B7F0/CCAPI/cc_api_event_indication:
076598: *Oct 17 2017 21:30:13.412: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076599: *Oct 17 2017 21:30:13.412: cc_api_get_xcode_stream : 4983
076600: *Oct 17 2017 21:30:13.412: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076601: *Oct 17 2017 21:30:13.412: cc_api_get_xcode_stream : 4983
076602: *Oct 17 2017 21:30:13.412: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076603: *Oct 17 2017 21:30:13.412: cc_api_get_xcode_stream : 4983
076604: *Oct 17 2017 21:30:13.413: //6590919/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:10.253.129.52 SIP/2.0
Via: SIP/2.0/UDP 172.29.200.33:5060;branch=z9hG4bK25EA3315D0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
076605: *Oct 17 2017 21:30:13.413: //6590918/31E3DB13B7F0/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID1=0x6491C6, gcid=31E4507E-B2B911E7-B7F3EA97-D6A08AF, tag=0x0)
076606: *Oct 17 2017 21:30:13.413: //6590919/31E3DB13B7F0/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID2=0x6491C7, gcid=31E4507E-B2B911E7-B7F3EA97-D6A08AF, tag=0x0)
076607: *Oct 17 2017 21:30:13.413: //6590918/31E3DB13B7F0/CCAPI/ccConferenceCreate:
Conference Id=0xFFFFFFFFFFFFFFFF, Call Id1=6590918, Call Id2=6590919, Tag=0x0
076608: *Oct 17 2017 21:30:13.413: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076609: *Oct 17 2017 21:30:13.413: cc_api_get_xcode_stream : 4983
076610: *Oct 17 2017 21:30:13.413: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076611: *Oct 17 2017 21:30:13.413: cc_api_get_xcode_stream : 4983
076612: *Oct 17 2017 21:30:13.413: //6590918/31E3DB13B7F0/CCAPI/ccConferenceCreate:
076613: *Oct 17 2017 21:30:13.413: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=0,
tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
076614: *Oct 17 2017 21:30:13.413: //6590918/31E3DB13B7F0/CCAPI/ccGetMediaClassTag:
media class tag 0
076615: *Oct 17 2017 21:30:13.413: //6590918/31E3DB13B7F0/CCAPI/ccSetMediaclassIp2ipTags:
076616: *Oct 17 2017 21:30:13.413: //6590919/31E3DB13B7F0/CCAPI/ccGetMediaClassTag:
media class tag 0
076617: *Oct 17 2017 21:30:13.413: //6590919/31E3DB13B7F0/CCAPI/ccSetMediaclassIp2ipTags:
076618: *Oct 17 2017 21:30:13.413: //6590918/31E3DB13B7F0/CCAPI/ccGet_xc_nr_asp_info:
076619: *Oct 17 2017 21:30:13.413: //6590919/31E3DB13B7F0/CCAPI/ccGet_xc_nr_asp_info:
076620: *Oct 17 2017 21:30:13.413: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076621: *Oct 17 2017 21:30:13.413: cc_api_get_xcode_stream : 4983
076622: *Oct 17 2017 21:30:13.413: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076623: *Oct 17 2017 21:30:13.413: cc_api_get_xcode_stream : 4983
076624: *Oct 17 2017 21:30:13.413: //6590918/31E3DB13B7F0/CCAPI/ccConferenceCreate:
Total Gain: Originating Party Direction=0dB, Terminating Party Direction=0dB
076625: *Oct 17 2017 21:30:13.413: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 6590918
076626: *Oct 17 2017 21:30:13.413: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 6590919
076627: *Oct 17 2017 21:30:13.414: //6590918/31E3DB13B7F0/CCAPI/ccConferenceCreate:
dtmf call is allowed to proceed w/o xcoder
076628: *Oct 17 2017 21:30:13.414: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076629: *Oct 17 2017 21:30:13.414: cc_api_get_xcode_stream : 4983
076630: *Oct 17 2017 21:30:13.414: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076631: *Oct 17 2017 21:30:13.414: cc_api_get_xcode_stream : 4983
076632: *Oct 17 2017 21:30:13.414: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076633: *Oct 17 2017 21:30:13.414: cc_api_get_xcode_stream : 4983
076634: *Oct 17 2017 21:30:13.414: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076635: *Oct 17 2017 21:30:13.414: cc_api_get_xcode_stream : 4983
076636: *Oct 17 2017 21:30:13.414: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076637: *Oct 17 2017 21:30:13.414: cc_api_get_xcode_stream : 4983
076638: *Oct 17 2017 21:30:13.414: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076639: *Oct 17 2017 21:30:13.414: cc_api_get_xcode_stream : 4983
076640: *Oct 17 2017 21:30:13.414: //6590918/31E3DB13B7F0/CCAPI/cc_api_bridge_done:
Conference Id=0x3CEA6, Source Interface=0x7FF404FF9F70, Source Call Id=6590918,
Destination Call Id=6590919, Disposition=0x0, Tag=0x0
076641: *Oct 17 2017 21:30:13.414: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076642: *Oct 17 2017 21:30:13.414: cc_api_get_xcode_stream : 4983
076643: *Oct 17 2017 21:30:13.414: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076644: *Oct 17 2017 21:30:13.414: cc_api_get_xcode_stream : 4983
076645: *Oct 17 2017 21:30:13.414: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076646: *Oct 17 2017 21:30:13.414: cc_api_get_xcode_stream : 4983
076647: *Oct 17 2017 21:30:13.414: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076648: *Oct 17 2017 21:30:13.414: cc_api_get_xcode_stream : 4983
076649: *Oct 17 2017 21:30:13.415: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076650: *Oct 17 2017 21:30:13.415: cc_api_get_xcode_stream : 4983
076651: *Oct 17 2017 21:30:13.415: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076652: *Oct 17 2017 21:30:13.415: cc_api_get_xcode_stream : 4983
076653: *Oct 17 2017 21:30:13.415: //6590919/31E3DB13B7F0/CCAPI/cc_api_bridge_done:
Conference Id=0x3CEA6, Source Interface=0x7FF404FF9F70, Source Call Id=6590919,
Destination Call Id=6590918, Disposition=0x0, Tag=0x0
076654: *Oct 17 2017 21:30:13.415: //6590918/31E3DB13B7F0/CCAPI/cc_generic_bridge_done:
076655: *Oct 17 2017 21:30:13.415: //6590918/31E3DB13B7F0/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x3CEA6, Destination Call Id=6590919)
076656: *Oct 17 2017 21:30:13.415: //6590919/31E3DB13B7F0/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x3CEA6, Destination Call Id=6590918)
076657: *Oct 17 2017 21:30:13.415: //6590918/31E3DB13B7F0/CCAPI/ccConferenceCreate:
076658: *Oct 17 2017 21:30:13.415: confID:0x3CEA6; callEntry1 callID1:0x6491C6, type:3; callEntry2 callID2:0x6491C7, type:3
076659: *Oct 17 2017 21:30:13.415: //6590918/31E3DB13B7F0/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x3CEA6, Call Id1=6590918, Call Id2=6590919
076660: *Oct 17 2017 21:30:13.415: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
076661: *Oct 17 2017 21:30:13.415: call_info mainst_callID:0x6491C7, peer_callID:0x6491C6, confID:0x3CEA6, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
076662: *Oct 17 2017 21:30:13.415: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
076663: *Oct 17 2017 21:30:13.415: stream[0]: callid:0x6491C7, media_passthrough:1
076664: *Oct 17 2017 21:30:13.416: //6590918/31E3DB13B7F0/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
076665: *Oct 17 2017 21:30:13.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076666: *Oct 17 2017 21:30:13.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076667: *Oct 17 2017 21:30:13.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
076668: *Oct 17 2017 21:30:13.416: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076669: *Oct 17 2017 21:30:13.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
076670: *Oct 17 2017 21:30:13.416: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
076671: *Oct 17 2017 21:30:13.416: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
076672: *Oct 17 2017 21:30:13.416: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076673: *Oct 17 2017 21:30:13.417: //6590918/31E3DB13B7F0/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
076674: *Oct 17 2017 21:30:13.456: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:4033131776@172.21.121.130:5060 SIP/2.0
Via: SIP/2.0/UDP 172.30.1.4:5060;branch=z9hG4bKvkamki005oouj17193f0.1
CSeq: 370127413 PRACK
RAck: 4258 370127412 INVITE
Max-Forwards: 19
Content-Length: 0
076675: *Oct 17 2017 21:30:13.458: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
076676: *Oct 17 2017 21:30:13.458: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
076677: *Oct 17 2017 21:30:13.458: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
076678: *Oct 17 2017 21:30:13.459: //6590918/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Content-Length: 0
076679: *Oct 17 2017 21:30:13.459: //6590918/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 253
v=0
o=CiscoSystemsSIP-GW-UserAgent 8348 2571 IN IP4 172.21.121.130
s=SIP Call
c=IN IP4 172.21.121.130
t=0 0
m=audio 44548 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
076680: *Oct 17 2017 21:30:13.486: //6590919/xxxxxxxxxxxx/CCAPI/ccapi_ha_active_data_collection:
076681: *Oct 17 2017 21:30:13.486: from_ptr callInfo.xcode_app_id:0, callInfo.xcode_codec:4294967295, callInfo.xcodeStreamID:0, callInfo.videoXcodeStreamID:0, insert_by_prefFeatures:0
076682: *Oct 17 2017 21:30:13.486: Called Num:4033131776, Calling Num:+12024655568, Called Name:4033131776, Calling Name:, incoming:0, call_count_on:0, spi_type:3, appType:1, swmtpmsp_present:0, app_name:_ManagedAppProcess_Default, rpmAppID:0, xcode_codec:4294967295, xcodeStreamID:0, videoXcodeStreamID:0, xcoder_insert_by_prefFeatures:0
076683: *Oct 17 2017 21:30:13.507: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.30.1.4:5060;branch=z9hG4bK5tbapc306gaaje1ajp60.1
CSeq: 370127412 ACK
Max-Forwards: 19
Content-Length: 0
076684: *Oct 17 2017 21:30:13.508: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
076685: *Oct 17 2017 21:30:13.508: call_info mainst_callID:0x6491C6, peer_callID:0x6491C7, confID:0x3CEA6, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
076686: *Oct 17 2017 21:30:13.508: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
076687: *Oct 17 2017 21:30:13.508: stream[0]: callid:0x6491C6, media_passthrough:1
076688: *Oct 17 2017 21:30:13.508: //6590918/31E3DB13B7F0/CCAPI/cc_api_event_indication:
Event=111, Call Id=6590918
076689: *Oct 17 2017 21:30:13.508: //6590918/31E3DB13B7F0/CCAPI/cc_api_event_indication:
076690: *Oct 17 2017 21:30:13.508: //6590918/31E3DB13B7F0/CCAPI/cc_api_event_indication:
Event=213, Call Id=6590918
076691: *Oct 17 2017 21:30:13.508: //6590918/31E3DB13B7F0/CCAPI/cc_api_event_indication:
076692: *Oct 17 2017 21:30:13.704: //6590918/xxxxxxxxxxxx/CCAPI/ccapi_ha_active_data_collection:
076693: *Oct 17 2017 21:30:13.704: from_ptr callInfo.xcode_app_id:0, callInfo.xcode_codec:4294967295, callInfo.xcodeStreamID:0, callInfo.videoXcodeStreamID:0, insert_by_prefFeatures:0
076694: *Oct 17 2017 21:30:13.704: Called Num:4033131776, Calling Num:+12024655568, Called Name:, Calling Name:, incoming:1, call_count_on:0, spi_type:3, appType:1, swmtpmsp_present:0, app_name:_ManagedAppProcess_Default, rpmAppID:0, xcode_codec:4294967295, xcodeStreamID:0, videoXcodeStreamID:0, xcoder_insert_by_prefFeatures:0
076695: *Oct 17 2017 21:30:16.427: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+12024655568@172.29.200.33:5060 SIP/2.0
From: <sip:4033131776@10.253.129.52>;tag=8e28930-0-13c4-55013-b8555b-71de78c1-b8555b
To: <sip:+12024655568@lii01.livun.com>;tag=56E55DB8-AC
CSeq: 1 INVITE
Via: SIP/2.0/UDP 10.253.129.52:5060;branch=z9hG4bK-b8555e-d00d7801-18f2e55
Supported: timer
Max-Forwards: 70
Min-SE: 1800
Content-Length: 288
v=0
o=- 2221343829 0886621000 IN IP4 10.253.129.52
s=no_session_name
t=0 0
m=image 56872 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:72
a=T38FaxUdpEC:t38UDPRedundancy
076696: *Oct 17 2017 21:30:16.427: //6590918/31E3DB13B7F0/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Sum Network, Params=0x0, Call Id=6590918
076697: *Oct 17 2017 21:30:16.429: //6590919/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 17 Oct 2017 21:30:16 GMT
CSeq: 1 INVITE
Content-Length: 0
076698: *Oct 17 2017 21:30:16.429: //6590919/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
076699: *Oct 17 2017 21:30:16.433: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+12024655568@172.29.200.33:5060 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
076700: *Oct 17 2017 21:30:16.433: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
076701: *Oct 17 2017 21:30:16.433: call_info mainst_callID:0x6491C7, peer_callID:0x6491C6, confID:0x3CEA6, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
076702: *Oct 17 2017 21:30:16.433: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
076703: *Oct 17 2017 21:30:16.433: stream[0]: callid:0x6491C7, media_passthrough:1
076704: *Oct 17 2017 21:30:16.434: //6590919/31E3DB13B7F0/CCAPI/cc_api_event_indication:
076705: *Oct 17 2017 21:30:16.434: //6590919/31E3DB13B7F0/CCAPI/cc_api_event_indication:
076706: *Oct 17 2017 21:30:16.434: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
076707: *Oct 17 2017 21:30:16.434: call_info mainst_callID:0x6491C7, peer_callID:0x6491C6, confID:0x3CEA6, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
076708: *Oct 17 2017 21:30:16.434: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
076709: *Oct 17 2017 21:30:16.434: stream[0]: callid:0x6491C7, media_passthrough:1
076710: *Oct 17 2017 21:30:16.434: //6590919/31E3DB13B7F0/CCAPI/cc_api_event_indication:
076711: *Oct 17 2017 21:30:16.434: //6590919/31E3DB13B7F0/CCAPI/cc_api_event_indication:
076712: *Oct 17 2017 21:30:16.434: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:+12024655568@172.29.200.33:5060 SIP/2.0
CSeq: 2 BYE
Via: SIP/2.0/UDP 10.253.129.52:5060;branch=z9hG4bK-b8555e-d00d7808-20b20c43
Supported: timer
Max-Forwards: 70
Content-Length: 0
076713: *Oct 17 2017 21:30:16.434: //6590918/31E3DB13B7F0/CCAPI/ccGenerateToneInfo:
076714: *Oct 17 2017 21:30:16.435: //6590919/31E3DB13B7F0/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x7FF404FF9F70, Call Id=6590919
076715: *Oct 17 2017 21:30:16.435: //6590919/31E3DB13B7F0/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
076716: *Oct 17 2017 21:30:16.435: //6590918/31E3DB13B7F0/CCAPI/ccConferenceDestroy:
Conference Id=0x3CEA6, Tag=0x0
076717: *Oct 17 2017 21:30:16.435: //6590918/31E3DB13B7F0/CCAPI/ccConferenceDestroy:
076718: *Oct 17 2017 21:30:16.435: confID:0x3CEA6; callEntry1 callID1:0x6491C6, type:3; callEntry2 callID2:0x6491C7, type:3
076719: *Oct 17 2017 21:30:16.435: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076720: *Oct 17 2017 21:30:16.435: cc_api_get_xcode_stream : 4983
076721: *Oct 17 2017 21:30:16.435: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076722: *Oct 17 2017 21:30:16.435: cc_api_get_xcode_stream : 4983
076723: *Oct 17 2017 21:30:16.435: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076724: *Oct 17 2017 21:30:16.435: cc_api_get_xcode_stream : 4983
076725: *Oct 17 2017 21:30:16.435: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076726: *Oct 17 2017 21:30:16.435: cc_api_get_xcode_stream : 4983
076727: *Oct 17 2017 21:30:16.436: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076728: *Oct 17 2017 21:30:16.436: cc_api_get_xcode_stream : 4983
076729: *Oct 17 2017 21:30:16.436: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076730: *Oct 17 2017 21:30:16.436: cc_api_get_xcode_stream : 4983
076731: *Oct 17 2017 21:30:16.436: //6590918/31E3DB13B7F0/CCAPI/cc_api_bridge_drop_done:
076732: *Oct 17 2017 21:30:16.436: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076733: *Oct 17 2017 21:30:16.436: cc_api_get_xcode_stream : 4983
076734: *Oct 17 2017 21:30:16.436: //6590918/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076735: *Oct 17 2017 21:30:16.436: cc_api_get_xcode_stream : 4983
076736: *Oct 17 2017 21:30:16.436: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076737: *Oct 17 2017 21:30:16.436: cc_api_get_xcode_stream : 4983
076738: *Oct 17 2017 21:30:16.436: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076739: *Oct 17 2017 21:30:16.436: cc_api_get_xcode_stream : 4983
076740: *Oct 17 2017 21:30:16.436: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076741: *Oct 17 2017 21:30:16.436: cc_api_get_xcode_stream : 4983
076742: *Oct 17 2017 21:30:16.436: //6590919/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
076743: *Oct 17 2017 21:30:16.436: cc_api_get_xcode_stream : 4983
076744: *Oct 17 2017 21:30:16.436: //6590919/31E3DB13B7F0/CCAPI/cc_api_bridge_drop_done:
076745: *Oct 17 2017 21:30:16.436: //6590918/31E3DB13B7F0/CCAPI/cc_generic_bridge_done:
076746: *Oct 17 2017 21:30:16.437: //6590918/31E3DB13B7F0/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
076747: *Oct 17 2017 21:30:16.437: //6590918/31E3DB13B7F0/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
076748: *Oct 17 2017 21:30:16.437: //6590919/31E3DB13B7F0/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
076749: *Oct 17 2017 21:30:16.437: //6590919/31E3DB13B7F0/CCAPI/ccCallDisconnect:
076750: *Oct 17 2017 21:30:16.439: //6590918/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:172.30.1.4:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.21.121.130:5060;branch=z9hG4bK25EA3476D
From: "Livingston Intl"<sip:4033131776@sbc-tr2.livingstonintl.com>;tag=56E55DC2-1286
To: <sip:+12024655568@siptrunking.bell.ca;user=phone>;tag=1432350286-1508273775718-
Max-Forwards: 70
Timestamp: 1508275816
CSeq: 101 BYE
Reason: Q.850;cause=16
Content-Length: 0
076751: *Oct 17 2017 21:30:16.439: //6590919/31E3DB13B7F0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 2 BYE
Content-Length: 0
2 Accepted Solutions
Looks like we have made further progress on this now. The change you made has now allowed this gateway to send the re-INVITE for T.38 negotiation to the other gateway.
++ Here is the re-INVITE from the fax server +++
078350: *Oct 18 2017 16:39:08.493: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: <sip:4033131776@10.253.129.52>;tag=8faec70-0-13c4-55013-b96281-23228e3f-b96281
To: <sip:+12024655568@lii01.livun.com>;tag=5B012FA4-1238
Call-ID: B09E85CA-B35911E7-9D1BEA97-D6A08AF@lii01.livun.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 10.253.129.52:5060;branch=z9hG4bK-b96284-d428d48e-2fd211b7
Supported: timer
Max-Forwards: 70
Min-SE: 1800
Content-Length: 288
v=0
o=- 2221414297 0870083000 IN IP4 10.253.129.52
s=no_session_name
t=0 0
m=image 56248 udptl t38
a=T38FaxVersion:0
+++ Here we see that the re-INVITE was sent out to the far end ( earlier the call was failing here)
Sent:
INVITE sip:172.30.1.4:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.21.121.130:5060;branch=z9hG4bK2654E8261
From: "ABC Company"<sip:4033131776@sbc-tr2.livingstonintl.com>;tag=5B012FAD-4DD
To: <sip:+12024655568@siptrunking.bell.ca;user=phone>;tag=1817722164-1508342702362-
Date: Wed, 18 Oct 2017 16:39:08 GMT
Call-ID: BW120502362181017-891520762@10.92.24.43
Min-SE: 1800
Cisco-Guid: 2963008980-3008958951-2635459223-0225052847
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1508344748
Expires: 180
Content-Length: 323
v=0
o=CiscoSystemsSIP-GW-UserAgent 2986 7257 IN IP4 172.21.121.130
s=SIP Call
t=0 0
m=image 18176 udptl t38
a=T38FaxVersion:0
078393: *Oct 18 2017 16:39:08.504: //6667823/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
++ The far end rejected the call ++
Received:
SIP/2.0 488 Not Acceptable Here
CSeq: 101 INVITE
Reason: Q.850;cause=65;text="Call Terminated"
Content-Length: 0
You need to enable T.38 on the other side as well.
Please rate all useful posts
You are correct. Just found out that the telco does not support T.38.
Just out of curiosity, if i change the dial peer and send that call (403-313-1776) to CUCM CTI RP and then forwardi to the fax server (a  new DID that is programmed in the fax server side) RP, the fax works fine. I am not understanding how this is possible.
8 Replies 8
Dennis Mink
It would be interesting to compare the SIP traces of a failed call with that of a successful call, and drill into the SDP to see its contents to see where the two differ. also is your dial peer to your fax server 100% the same as the one that points to your CUCM?
Please remember to rate useful posts, by clicking on the stars below.
Ayodeji Okanlawon
Your call is failing when the fax server attempts to negotiate T.3 as shown in the logs below:
Received:
CSeq: 1 INVITE
Supported: timer
Max-Forwards: 70
Min-SE: 1800
Content-Length: 288
v=0
s=no_session_name
t=0 0
a=T38FaxVersion:0
Sent:
CSeq: 1 INVITE
Content-Length: 0
Did you configure T.38 on the inbound dial-peer 100 to cube and outbound dial-peer 3285 to fax server ?
dial-peer v 100 v
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
dial-p v 3285 v
Thank you so much for the response. I didn't have " fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none" in both dial peers which I added and tested. However, I am getting the same result as before.
dial-peer voice 100 voip
 description incoming from Bell Canada
 session protocol sipv2
 session target sip-server
 session transport udp
 incoming uri via bell
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0/0
 voice-class sip bind media source-interface GigabitEthernet0/0/0
 dtmf-relay rtp-nte
 no vad
dial-peer voice 3285 voip
 description CALCAGARY DID FOR RIGHTFAX TESTING
 destination-pattern 4033131776
 session target ipv4:10.253.129.52
 incoming called-number .
 voice-class codec 1
 voice-class sip early-offer forced
 voice-class sip bind control source-interface GigabitEthernet0/0/1
 voice-class sip bind media source-interface GigabitEthernet0/0/1
 dtmf-relay rtp-nte
 no vad
following are the ccisp messages and ccapi inout debug outputs.
Calling number 2024655568
Called number 4033131776
077862: *Oct 18 2017 16:39:05.456: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.30.1.4:5060;branch=z9hG4bK397uc7306g3sckmnibm0.1
From: <sip:+12024655568@siptrunking.bell.ca;user=phone>;tag=1817722164-1508342702362-
To: "ABC Company"<sip:4033131776@sbc-tr2.livingstonintl.com>
CSeq: 404590734 INVITE
Supported: 100rel
Max-Forwards: 19
Content-Length: 167
v=0
o=- 4118582568 1 IN IP4 172.30.1.4
s=-
c=IN IP4 172.30.1.4
t=0 0
m=audio 40250 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
077863: *Oct 18 2017 16:39:05.456: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077864: *Oct 18 2017 16:39:05.456: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077865: *Oct 18 2017 16:39:05.457: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077866: *Oct 18 2017 16:39:05.457: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077867: *Oct 18 2017 16:39:05.457: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
077868: *Oct 18 2017 16:39:05.457: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
077869: *Oct 18 2017 16:39:05.457: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
077870: *Oct 18 2017 16:39:05.457: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077871: *Oct 18 2017 16:39:05.458: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
077872: *Oct 18 2017 16:39:05.458: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
077873: *Oct 18 2017 16:39:05.458: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077874: *Oct 18 2017 16:39:05.458: //-1/B09BEDD49D15/DPM/dpAssociateIncomingPeerCore:
077875: *Oct 18 2017 16:39:05.459: //-1/B09BEDD49D15/DPM/dpAssociateIncomingPeerCore:
077876: *Oct 18 2017 16:39:05.459: //-1/B09BEDD49D15/DPM/dpMatchSafModulePlugin:
077877: *Oct 18 2017 16:39:05.459: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Tag=100
077878: *Oct 18 2017 16:39:05.459: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Result=0 Bitmap=0x0
077879: *Oct 18 2017 16:39:05.460: //-1/B09BEDD49D15/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=4033131776
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
077880: *Oct 18 2017 16:39:05.461: //-1/B09BEDD49D15/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=6667823
077881: *Oct 18 2017 16:39:05.461: //-1/B09BEDD49D15/CCAPI/ccCheckClipClir:
077882: *Oct 18 2017 16:39:05.461: //-1/B09BEDD49D15/CCAPI/ccCheckClipClir:
077883: *Oct 18 2017 16:39:05.461: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
077884: *Oct 18 2017 16:39:05.461: :cc_get_feature_vsa malloc success
077885: *Oct 18 2017 16:39:05.461: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
077886: *Oct 18 2017 16:39:05.461: cc_get_feature_vsa count is 77
077887: *Oct 18 2017 16:39:05.461: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
077888: *Oct 18 2017 16:39:05.461: :FEATURE_VSA attributes are: feature_name:0,feature_time:140686110093292,feature_id:588346
077889: *Oct 18 2017 16:39:05.462: //6667823/B09BEDD49D15/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
077890: *Oct 18 2017 16:39:05.463: //6667823/B09BEDD49D15/CCAPI/cc_process_call_setup_ind:
077891: *Oct 18 2017 16:39:05.463: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
077892: *Oct 18 2017 16:39:05.463: //6667823/B09BEDD49D15/CCAPI/ccCallSetContext:
Context=0x7FF40F0633A8
077893: *Oct 18 2017 16:39:05.464: //6667823/B09BEDD49D15/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 6667823 with tag 100 to app "_ManagedAppProcess_Default"
077894: *Oct 18 2017 16:39:05.464: //6667823/B09BEDD49D15/CCAPI/ccCallProceeding:
077895: *Oct 18 2017 16:39:05.464: //-1/B09BEDD49D15/DPM/dpMatchPeersCore:
077896: *Oct 18 2017 16:39:05.464: //-1/B09BEDD49D15/DPM/dpMatchPeersCore:
077897: *Oct 18 2017 16:39:05.465: //-1/B09BEDD49D15/DPM/dpMatchPeersCore:
077898: *Oct 18 2017 16:39:05.465: //-1/B09BEDD49D15/DPM/dpMatchSafModulePlugin:
077899: *Oct 18 2017 16:39:05.465: //-1/B09BEDD49D15/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
077900: *Oct 18 2017 16:39:05.465: //-1/B09BEDD49D15/DPM/dpMatchPeersCore:
077901: *Oct 18 2017 16:39:05.465: //-1/B09BEDD49D15/DPM/dpMatchPeersCore:
077902: *Oct 18 2017 16:39:05.465: //-1/B09BEDD49D15/DPM/dpMatchPeersCore:
077903: *Oct 18 2017 16:39:05.465: //-1/B09BEDD49D15/DPM/dpMatchSafModulePlugin:
077904: *Oct 18 2017 16:39:05.465: //-1/B09BEDD49D15/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
077905: *Oct 18 2017 16:39:05.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077906: *Oct 18 2017 16:39:05.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077907: *Oct 18 2017 16:39:05.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077908: *Oct 18 2017 16:39:05.465: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077909: *Oct 18 2017 16:39:05.465: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
077910: *Oct 18 2017 16:39:05.465: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
077911: *Oct 18 2017 16:39:05.466: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
077912: *Oct 18 2017 16:39:05.466: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077913: *Oct 18 2017 16:39:05.466: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
077914: *Oct 18 2017 16:39:05.466: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
077915: *Oct 18 2017 16:39:05.466: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077916: *Oct 18 2017 16:39:05.466: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077917: *Oct 18 2017 16:39:05.466: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077918: *Oct 18 2017 16:39:05.467: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077919: *Oct 18 2017 16:39:05.467: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077920: *Oct 18 2017 16:39:05.467: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
077921: *Oct 18 2017 16:39:05.467: //-1/B09BEDD49D15/DPM/dpMatchPeersCore:
077922: *Oct 18 2017 16:39:05.467: //-1/B09BEDD49D15/DPM/dpMatchPeersCore:
077923: *Oct 18 2017 16:39:05.467: //-1/B09BEDD49D15/DPM/dpMatchPeersCore:
077924: *Oct 18 2017 16:39:05.467: //-1/B09BEDD49D15/DPM/dpMatchSafModulePlugin:
077925: *Oct 18 2017 16:39:05.467: //-1/B09BEDD49D15/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
077926: *Oct 18 2017 16:39:05.468: //6667823/B09BEDD49D15/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=3285, Params=0x7FF40F070010, Progress Indication=NULL(0)
077927: *Oct 18 2017 16:39:05.468: //6667823/B09BEDD49D15/CCAPI/ccCheckClipClir:
077928: *Oct 18 2017 16:39:05.468: //6667823/B09BEDD49D15/CCAPI/ccCheckClipClir:
077929: *Oct 18 2017 16:39:05.468: //6667823/B09BEDD49D15/CCAPI/ccCallSetupRequest:
077930: *Oct 18 2017 16:39:05.468: //6667823/B09BEDD49D15/CCAPI/ccCallSetupRequest:
Guid=B09BEDD4-B359-11E7-9D15-EA970D6A08AF, Outgoing Dial-peer=3285
077931: *Oct 18 2017 16:39:05.468: //6667823/B09BEDD49D15/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=4033131776
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
077932: *Oct 18 2017 16:39:05.468: //6667823/B09BEDD49D15/CCAPI/ccIFCallSetupRequestPrivate:
077933: *Oct 18 2017 16:39:05.468: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
077934: *Oct 18 2017 16:39:05.468: :cc_get_feature_vsa malloc success
077935: *Oct 18 2017 16:39:05.468: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
077936: *Oct 18 2017 16:39:05.468: cc_get_feature_vsa count is 78
077937: *Oct 18 2017 16:39:05.468: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
077938: *Oct 18 2017 16:39:05.468: :FEATURE_VSA attributes are: feature_name:0,feature_time:140686110095308,feature_id:588347
077939: *Oct 18 2017 16:39:05.470: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
077940: *Oct 18 2017 16:39:05.470: cc_api_get_xcode_stream : 4983
077941: *Oct 18 2017 16:39:05.470: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
077942: *Oct 18 2017 16:39:05.470: cc_api_get_xcode_stream : 4983
077943: *Oct 18 2017 16:39:05.470: //6667823/B09BEDD49D15/CCAPI/cc_api_event_indication:
Event=101, Call Id=6667823
077944: *Oct 18 2017 16:39:05.470: //6667823/B09BEDD49D15/CCAPI/cc_api_event_indication:
077945: *Oct 18 2017 16:39:05.470: //6667824/B09BEDD49D15/CCAPI/ccIFCallSetupRequestPrivate:
077946: *Oct 18 2017 16:39:05.470: //6667824/B09BEDD49D15/CCAPI/ccCallSetContext:
Context=0x7FF40F06FF90
077947: *Oct 18 2017 16:39:05.470: //6667823/B09BEDD49D15/CCAPI/ccSaveDialpeerTag:
077948: *Oct 18 2017 16:39:05.471: //6667824/B09BEDD49D15/CCAPI/ccGetMediaClassTag:
media class tag 0
077949: *Oct 18 2017 16:39:05.471: //6667824/B09BEDD49D15/CCAPI/ccSetMediaclassIp2ipTags:
077950: *Oct 18 2017 16:39:05.471: //6667823/B09BEDD49D15/CCAPI/ccGetMediaClassTag:
media class tag 0
077951: *Oct 18 2017 16:39:05.471: //6667823/B09BEDD49D15/CCAPI/ccSetMediaclassIp2ipTags:
077952: *Oct 18 2017 16:39:05.471: //6667824/B09BEDD49D15/CCAPI/ccGet_xc_nr_asp_info:
077953: *Oct 18 2017 16:39:05.471: //6667823/B09BEDD49D15/CCAPI/ccGet_xc_nr_asp_info:
077954: *Oct 18 2017 16:39:05.471: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 6667823
077955: *Oct 18 2017 16:39:05.473: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
077956: *Oct 18 2017 16:39:05.473: cc_api_get_xcode_stream : 4983
077957: *Oct 18 2017 16:39:05.473: //6667824/B09BEDD49D15/CCAPI/cc_api_call_proceeding:
077958: *Oct 18 2017 16:39:05.475: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
077959: *Oct 18 2017 16:39:05.475: cc_api_get_xcode_stream : 4983
077960: *Oct 18 2017 16:39:05.475: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
077961: *Oct 18 2017 16:39:05.475: cc_api_get_xcode_stream : 4983
077962: *Oct 18 2017 16:39:05.475: //6667823/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 18 Oct 2017 16:39:05 GMT
Content-Length: 0
077963: *Oct 18 2017 16:39:05.476: //6667824/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.29.200.33:5060;branch=z9hG4bK2654E01A8D
From: <sip:+12024655568@lii01.livun.com>;tag=5B012FA4-1238
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1508344745
Expires: 180
Max-Forwards: 18
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 2569 7001 IN IP4 172.29.200.33
s=SIP Call
t=0 0
m=audio 16340 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
077964: *Oct 18 2017 16:39:05.481: //6667824/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:4033131776@10.253.129.52>;tag=8faec70-0-13c4-55013-b96281-23228e3f-b96281
CSeq: 101 INVITE
Supported: timer
Content-Length: 0
077965: *Oct 18 2017 16:39:05.481: //6667824/B09BEDD49D15/CCAPI/cc_api_call_alert:
077966: *Oct 18 2017 16:39:05.481: //6667824/B09BEDD49D15/CCAPI/cc_api_call_alert:
077967: *Oct 18 2017 16:39:05.481: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077968: *Oct 18 2017 16:39:05.481: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077969: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077970: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077971: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
077972: *Oct 18 2017 16:39:05.482: //6667823/B09BEDD49D15/CCAPI/ccCallAlert:
077973: *Oct 18 2017 16:39:05.482: //6667823/B09BEDD49D15/CCAPI/ccCallAlert:
077974: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077975: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077976: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077977: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077978: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
077979: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
077980: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
077981: *Oct 18 2017 16:39:05.482: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077982: *Oct 18 2017 16:39:05.483: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077983: *Oct 18 2017 16:39:05.483: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077984: *Oct 18 2017 16:39:05.483: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077985: *Oct 18 2017 16:39:05.483: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077986: *Oct 18 2017 16:39:05.483: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
077987: *Oct 18 2017 16:39:05.483: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077988: *Oct 18 2017 16:39:05.483: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077989: *Oct 18 2017 16:39:05.483: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
077990: *Oct 18 2017 16:39:05.483: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
077991: *Oct 18 2017 16:39:05.483: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
077992: *Oct 18 2017 16:39:05.483: //6667823/B09BEDD49D15/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=6667823
077993: *Oct 18 2017 16:39:05.484: //6667823/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "ABC Company"<sip:4033131776@sbc-tr2.livingstonintl.com>;tag=5B012FAD-4DD
Require: 100rel
RSeq: 6821
Content-Length: 0
077994: *Oct 18 2017 16:39:05.484: //6667824/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: timer
Content-Length: 150
v=0
o=- 2221414297 0857851000 IN IP4 10.253.129.52
s=no_session_name
t=0 0
m=audio 56248 RTP/AVP 0
077995: *Oct 18 2017 16:39:05.485: //6667824/B09BEDD49D15/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6667824,
077996: *Oct 18 2017 16:39:05.485: //6667824/B09BEDD49D15/CCAPI/cc_api_caps_ind:
077997: *Oct 18 2017 16:39:05.485: //6667823/B09BEDD49D15/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6667823,
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=5530)
077998: *Oct 18 2017 16:39:05.485: //6667823/B09BEDD49D15/CCAPI/cc_api_caps_ack:
077999: *Oct 18 2017 16:39:05.486: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
Event=103, Call Id=6667824
078000: *Oct 18 2017 16:39:05.486: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
078001: *Oct 18 2017 16:39:05.486: //6667824/B09BEDD49D15/CCAPI/cc_api_call_connected:
Connection Handle=0
078002: *Oct 18 2017 16:39:05.486: //6667824/B09BEDD49D15/CCAPI/cc_api_call_connected:
078003: *Oct 18 2017 16:39:05.486: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
Event=111, Call Id=6667824
078004: *Oct 18 2017 16:39:05.486: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
078005: *Oct 18 2017 16:39:05.486: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
Event=213, Call Id=6667824
078006: *Oct 18 2017 16:39:05.486: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
078007: *Oct 18 2017 16:39:05.487: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078008: *Oct 18 2017 16:39:05.487: cc_api_get_xcode_stream : 4983
078009: *Oct 18 2017 16:39:05.487: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078010: *Oct 18 2017 16:39:05.487: cc_api_get_xcode_stream : 4983
078011: *Oct 18 2017 16:39:05.487: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078012: *Oct 18 2017 16:39:05.487: cc_api_get_xcode_stream : 4983
078013: *Oct 18 2017 16:39:05.488: //6667824/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.29.200.33:5060;branch=z9hG4bK2654E1181
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
078014: *Oct 18 2017 16:39:05.488: //6667823/B09BEDD49D15/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID1=0x65BE2F, gcid=B09C633E-B35911E7-9D18EA97-D6A08AF, tag=0x0)
078015: *Oct 18 2017 16:39:05.488: //6667824/B09BEDD49D15/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID2=0x65BE30, gcid=B09C633E-B35911E7-9D18EA97-D6A08AF, tag=0x0)
078016: *Oct 18 2017 16:39:05.488: //6667823/B09BEDD49D15/CCAPI/ccConferenceCreate:
Conference Id=0xFFFFFFFFFFFFFFFF, Call Id1=6667823, Call Id2=6667824, Tag=0x0
078017: *Oct 18 2017 16:39:05.488: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078018: *Oct 18 2017 16:39:05.488: cc_api_get_xcode_stream : 4983
078019: *Oct 18 2017 16:39:05.488: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078020: *Oct 18 2017 16:39:05.488: cc_api_get_xcode_stream : 4983
078021: *Oct 18 2017 16:39:05.488: //6667823/B09BEDD49D15/CCAPI/ccConferenceCreate:
078022: *Oct 18 2017 16:39:05.488: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
078023: *Oct 18 2017 16:39:05.488: //6667823/B09BEDD49D15/CCAPI/ccGetMediaClassTag:
media class tag 0
078024: *Oct 18 2017 16:39:05.488: //6667823/B09BEDD49D15/CCAPI/ccSetMediaclassIp2ipTags:
078025: *Oct 18 2017 16:39:05.488: //6667824/B09BEDD49D15/CCAPI/ccGetMediaClassTag:
media class tag 0
078026: *Oct 18 2017 16:39:05.488: //6667824/B09BEDD49D15/CCAPI/ccSetMediaclassIp2ipTags:
078027: *Oct 18 2017 16:39:05.488: //6667823/B09BEDD49D15/CCAPI/ccGet_xc_nr_asp_info:
078028: *Oct 18 2017 16:39:05.488: //6667824/B09BEDD49D15/CCAPI/ccGet_xc_nr_asp_info:
078029: *Oct 18 2017 16:39:05.488: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078030: *Oct 18 2017 16:39:05.488: cc_api_get_xcode_stream : 4983
078031: *Oct 18 2017 16:39:05.488: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078032: *Oct 18 2017 16:39:05.488: cc_api_get_xcode_stream : 4983
078033: *Oct 18 2017 16:39:05.488: //6667823/B09BEDD49D15/CCAPI/ccConferenceCreate:
078034: *Oct 18 2017 16:39:05.488: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 6667823
078035: *Oct 18 2017 16:39:05.488: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 6667824
078036: *Oct 18 2017 16:39:05.488: //6667823/B09BEDD49D15/CCAPI/ccConferenceCreate:
078037: *Oct 18 2017 16:39:05.488: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078038: *Oct 18 2017 16:39:05.488: cc_api_get_xcode_stream : 4983
078039: *Oct 18 2017 16:39:05.488: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078040: *Oct 18 2017 16:39:05.488: cc_api_get_xcode_stream : 4983
078041: *Oct 18 2017 16:39:05.489: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078042: *Oct 18 2017 16:39:05.489: cc_api_get_xcode_stream : 4983
078043: *Oct 18 2017 16:39:05.489: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078044: *Oct 18 2017 16:39:05.489: cc_api_get_xcode_stream : 4983
078045: *Oct 18 2017 16:39:05.489: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078046: *Oct 18 2017 16:39:05.489: cc_api_get_xcode_stream : 4983
078047: *Oct 18 2017 16:39:05.489: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078048: *Oct 18 2017 16:39:05.489: cc_api_get_xcode_stream : 4983
078049: *Oct 18 2017 16:39:05.489: //6667823/B09BEDD49D15/CCAPI/cc_api_bridge_done:
Conference Id=0x3D9D6, Source Interface=0x7FF404FF9F70, Source Call Id=6667823,
Destination Call Id=6667824, Disposition=0x0, Tag=0x0
078050: *Oct 18 2017 16:39:05.489: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078051: *Oct 18 2017 16:39:05.489: cc_api_get_xcode_stream : 4983
078052: *Oct 18 2017 16:39:05.489: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078053: *Oct 18 2017 16:39:05.489: cc_api_get_xcode_stream : 4983
078054: *Oct 18 2017 16:39:05.489: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078055: *Oct 18 2017 16:39:05.489: cc_api_get_xcode_stream : 4983
078056: *Oct 18 2017 16:39:05.489: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078057: *Oct 18 2017 16:39:05.489: cc_api_get_xcode_stream : 4983
078058: *Oct 18 2017 16:39:05.489: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078059: *Oct 18 2017 16:39:05.489: cc_api_get_xcode_stream : 4983
078060: *Oct 18 2017 16:39:05.489: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078061: *Oct 18 2017 16:39:05.489: cc_api_get_xcode_stream : 4983
078062: *Oct 18 2017 16:39:05.489: //6667824/B09BEDD49D15/CCAPI/cc_api_bridge_done:
Conference Id=0x3D9D6, Source Interface=0x7FF404FF9F70, Source Call Id=6667824,
Destination Call Id=6667823, Disposition=0x0, Tag=0x0
078063: *Oct 18 2017 16:39:05.489: //6667823/B09BEDD49D15/CCAPI/cc_generic_bridge_done:
078064: *Oct 18 2017 16:39:05.490: //6667823/B09BEDD49D15/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x3D9D6, Destination Call Id=6667824)
078065: *Oct 18 2017 16:39:05.490: //6667824/B09BEDD49D15/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x3D9D6, Destination Call Id=6667823)
078066: *Oct 18 2017 16:39:05.490: //6667823/B09BEDD49D15/CCAPI/ccConferenceCreate:
078067: *Oct 18 2017 16:39:05.490: confID:0x3D9D6; callEntry1 callID1:0x65BE2F, type:3; callEntry2 callID2:0x65BE30, type:3
078068: *Oct 18 2017 16:39:05.490: //6667823/B09BEDD49D15/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x3D9D6, Call Id1=6667823, Call Id2=6667824
078069: *Oct 18 2017 16:39:05.490: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
078070: *Oct 18 2017 16:39:05.490: call_info mainst_callID:0x65BE30, peer_callID:0x65BE2F, confID:0x3D9D6, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
078071: *Oct 18 2017 16:39:05.490: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
078072: *Oct 18 2017 16:39:05.490: stream[0]: callid:0x65BE30, media_passthrough:1
078073: *Oct 18 2017 16:39:05.490: //6667823/B09BEDD49D15/CCAPI/ccCallConnect:
078074: *Oct 18 2017 16:39:05.490: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
078075: *Oct 18 2017 16:39:05.490: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
078076: *Oct 18 2017 16:39:05.491: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
078077: *Oct 18 2017 16:39:05.491: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
078078: *Oct 18 2017 16:39:05.491: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
078079: *Oct 18 2017 16:39:05.491: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
078080: *Oct 18 2017 16:39:05.491: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
078081: *Oct 18 2017 16:39:05.491: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
078082: *Oct 18 2017 16:39:05.491: //6667823/B09BEDD49D15/CCAPI/ccCallConnect:
078083: *Oct 18 2017 16:39:05.531: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.30.1.4:5060;branch=z9hG4bKlph1du307geci32g6m00.1
CSeq: 404590735 PRACK
RAck: 6821 404590734 INVITE
Max-Forwards: 19
Content-Length: 0
078084: *Oct 18 2017 16:39:05.532: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=+12024655568, Called Number=, Voice-Interface=0x0,
078085: *Oct 18 2017 16:39:05.533: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=301
078086: *Oct 18 2017 16:39:05.533: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
078087: *Oct 18 2017 16:39:05.533: //6667823/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Content-Length: 0
078088: *Oct 18 2017 16:39:05.534: //6667823/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Type: application/sdp
Content-Length: 253
v=0
o=CiscoSystemsSIP-GW-UserAgent 2986 7256 IN IP4 172.21.121.130
s=SIP Call
t=0 0
m=audio 18176 RTP/AVP 0 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
078089: *Oct 18 2017 16:39:05.535: //6667824/xxxxxxxxxxxx/CCAPI/ccapi_ha_active_data_collection:
078090: *Oct 18 2017 16:39:05.535: from_ptr callInfo.xcode_app_id:0, callInfo.xcode_codec:4294967295, callInfo.xcodeStreamID:0, callInfo.videoXcodeStreamID:0, insert_by_prefFeatures:0
078091: *Oct 18 2017 16:39:05.535: Called Num:4033131776, Calling Num:+12024655568, Called Name:4033131776, Calling Name:, incoming:0, call_count_on:0, spi_type:3, appType:1, swmtpmsp_present:0, app_name:_ManagedAppProcess_Default, rpmAppID:0, xcode_codec:4294967295, xcodeStreamID:0, videoXcodeStreamID:0, xcoder_insert_by_prefFeatures:0
078092: *Oct 18 2017 16:39:05.583: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.30.1.4:5060;branch=z9hG4bK22re8r108012uogq3v40.1
CSeq: 404590734 ACK
Contact: <sip:172.30.1.4:5060;transport=udp>
Max-Forwards: 19
Content-Length: 0
078093: *Oct 18 2017 16:39:05.583: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
078094: *Oct 18 2017 16:39:05.583: call_info mainst_callID:0x65BE2F, peer_callID:0x65BE30, confID:0x3D9D6, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
078095: *Oct 18 2017 16:39:05.583: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
078096: *Oct 18 2017 16:39:05.583: stream[0]: callid:0x65BE2F, media_passthrough:1
078097: *Oct 18 2017 16:39:05.583: //6667823/B09BEDD49D15/CCAPI/cc_api_event_indication:
Event=111, Call Id=6667823
078098: *Oct 18 2017 16:39:05.583: //6667823/B09BEDD49D15/CCAPI/cc_api_event_indication:
078099: *Oct 18 2017 16:39:05.583: //6667823/B09BEDD49D15/CCAPI/cc_api_event_indication:
Event=213, Call Id=6667823
078100: *Oct 18 2017 16:39:05.583: //6667823/B09BEDD49D15/CCAPI/cc_api_event_indication:
078101: *Oct 18 2017 16:39:05.768: //6667823/xxxxxxxxxxxx/CCAPI/ccapi_ha_active_data_collection:
078102: *Oct 18 2017 16:39:05.768: from_ptr callInfo.xcode_app_id:0, callInfo.xcode_codec:4294967295, callInfo.xcodeStreamID:0, callInfo.videoXcodeStreamID:0, insert_by_prefFeatures:0
078103: *Oct 18 2017 16:39:05.768: Called Num:4033131776, Calling Num:+12024655568, Called Name:, Calling Name:, incoming:1, call_count_on:0, spi_type:3, appType:1, swmtpmsp_present:0, app_name:_ManagedAppProcess_Default, rpmAppID:0, xcode_codec:4294967295, xcodeStreamID:0, videoXcodeStreamID:0, xcoder_insert_by_prefFeatures:0
Received:
CSeq: 1 INVITE
Supported: timer
Max-Forwards: 70
Min-SE: 1800
Content-Length: 288
v=0
s=no_session_name
t=0 0
a=T38FaxVersion:0
078351: *Oct 18 2017 16:39:08.493: //6667823/B09BEDD49D15/CCAPI/ccGenerateToneInfo:
Tone Direction=Sum Network, Params=0x0, Call Id=6667823
078352: *Oct 18 2017 16:39:08.494: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078353: *Oct 18 2017 16:39:08.494: cc_api_get_xcode_stream : 4983
078354: *Oct 18 2017 16:39:08.494: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078355: *Oct 18 2017 16:39:08.494: cc_api_get_xcode_stream : 4983
078356: *Oct 18 2017 16:39:08.494: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078357: *Oct 18 2017 16:39:08.494: cc_api_get_xcode_stream : 4983
078358: *Oct 18 2017 16:39:08.494: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078359: *Oct 18 2017 16:39:08.494: cc_api_get_xcode_stream : 4983
078360: *Oct 18 2017 16:39:08.495: //6667824/B09BEDD49D15/CCAPI/cc_api_caps_ind:
Destination Interface=0x7FF404FF9F70, Destination Call Id=6667823, Source Call Id=6667824,
Caps(Codec=0x10000, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
Modem=0x0, Codec Bytes=20, Signal Type=2)
078361: *Oct 18 2017 16:39:08.495: //6667824/B09BEDD49D15/CCAPI/cc_api_caps_ind:
078362: *Oct 18 2017 16:39:08.495: //6667823/B09BEDD49D15/CCAPI/cc_api_caps_ack:
Destination Interface=0x7FF404FF9F70, Destination Call Id=6667824, Source Call Id=6667823,
078363: *Oct 18 2017 16:39:08.495: //6667823/B09BEDD49D15/CCAPI/cc_api_caps_ack:
078364: *Oct 18 2017 16:39:08.495: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
Event=101, Call Id=6667824
078365: *Oct 18 2017 16:39:08.495: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
078366: *Oct 18 2017 16:39:08.495: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078367: *Oct 18 2017 16:39:08.495: cc_api_get_xcode_stream : 4983
078368: *Oct 18 2017 16:39:08.495: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078369: *Oct 18 2017 16:39:08.495: cc_api_get_xcode_stream : 4983
078370: *Oct 18 2017 16:39:08.495: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078371: *Oct 18 2017 16:39:08.495: cc_api_get_xcode_stream : 4983
078372: *Oct 18 2017 16:39:08.495: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078373: *Oct 18 2017 16:39:08.495: cc_api_get_xcode_stream : 4983
078374: *Oct 18 2017 16:39:08.495: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078375: *Oct 18 2017 16:39:08.495: cc_api_get_xcode_stream : 4983
078376: *Oct 18 2017 16:39:08.495: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078377: *Oct 18 2017 16:39:08.495: cc_api_get_xcode_stream : 4983
078378: *Oct 18 2017 16:39:08.496: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078379: *Oct 18 2017 16:39:08.496: cc_api_get_xcode_stream : 4983
078380: *Oct 18 2017 16:39:08.496: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078381: *Oct 18 2017 16:39:08.496: cc_api_get_xcode_stream : 4983
078382: *Oct 18 2017 16:39:08.497: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078383: *Oct 18 2017 16:39:08.497: cc_api_get_xcode_stream : 4983
078384: *Oct 18 2017 16:39:08.497: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078385: *Oct 18 2017 16:39:08.497: cc_api_get_xcode_stream : 4983
078386: *Oct 18 2017 16:39:08.497: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078387: *Oct 18 2017 16:39:08.497: cc_api_get_xcode_stream : 4983
078388: *Oct 18 2017 16:39:08.497: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078389: *Oct 18 2017 16:39:08.497: cc_api_get_xcode_stream : 4983
078390: *Oct 18 2017 16:39:08.499: //6667824/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
078391: *Oct 18 2017 16:39:08.499: //6667823/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 323
v=0
s=SIP Call
t=0 0
a=T38FaxVersion:0
078392: *Oct 18 2017 16:39:08.504: //6667823/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Received:
CSeq: 101 INVITE
Content-Length: 0
078394: *Oct 18 2017 16:39:08.505: //6667823/B09BEDD49D15/CCAPI/cc_api_event_indication:
Event=96, Call Id=6667823
078395: *Oct 18 2017 16:39:08.505: //6667823/B09BEDD49D15/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
078396: *Oct 18 2017 16:39:08.505: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078397: *Oct 18 2017 16:39:08.505: cc_api_get_xcode_stream : 4983
078398: *Oct 18 2017 16:39:08.506: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078399: *Oct 18 2017 16:39:08.506: cc_api_get_xcode_stream : 4983
078400: *Oct 18 2017 16:39:08.506: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078401: *Oct 18 2017 16:39:08.506: cc_api_get_xcode_stream : 4983
078402: *Oct 18 2017 16:39:08.506: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078403: *Oct 18 2017 16:39:08.506: cc_api_get_xcode_stream : 4983
078404: *Oct 18 2017 16:39:08.506: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078405: *Oct 18 2017 16:39:08.506: cc_api_get_xcode_stream : 4983
078406: *Oct 18 2017 16:39:08.506: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078407: *Oct 18 2017 16:39:08.506: cc_api_get_xcode_stream : 4983
078408: *Oct 18 2017 16:39:08.506: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078409: *Oct 18 2017 16:39:08.506: cc_api_get_xcode_stream : 4983
078410: *Oct 18 2017 16:39:08.506: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078411: *Oct 18 2017 16:39:08.506: cc_api_get_xcode_stream : 4983
078412: *Oct 18 2017 16:39:08.506: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078413: *Oct 18 2017 16:39:08.506: cc_api_get_xcode_stream : 4983
078414: *Oct 18 2017 16:39:08.506: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078415: *Oct 18 2017 16:39:08.506: cc_api_get_xcode_stream : 4983
078416: *Oct 18 2017 16:39:08.507: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078417: *Oct 18 2017 16:39:08.507: cc_api_get_xcode_stream : 4983
078418: *Oct 18 2017 16:39:08.507: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078419: *Oct 18 2017 16:39:08.507: cc_api_get_xcode_stream : 4983
078420: *Oct 18 2017 16:39:08.507: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078421: *Oct 18 2017 16:39:08.507: cc_api_get_xcode_stream : 4983
078422: *Oct 18 2017 16:39:08.507: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078423: *Oct 18 2017 16:39:08.507: cc_api_get_xcode_stream : 4983
078424: *Oct 18 2017 16:39:08.507: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078425: *Oct 18 2017 16:39:08.507: cc_api_get_xcode_stream : 4983
078426: *Oct 18 2017 16:39:08.507: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078427: *Oct 18 2017 16:39:08.507: cc_api_get_xcode_stream : 4983
078428: *Oct 18 2017 16:39:08.507: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078429: *Oct 18 2017 16:39:08.507: cc_api_get_xcode_stream : 4983
078430: *Oct 18 2017 16:39:08.507: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078431: *Oct 18 2017 16:39:08.507: cc_api_get_xcode_stream : 4983
078432: *Oct 18 2017 16:39:08.507: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078433: *Oct 18 2017 16:39:08.507: cc_api_get_xcode_stream : 4983
078434: *Oct 18 2017 16:39:08.508: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078435: *Oct 18 2017 16:39:08.508: cc_api_get_xcode_stream : 4983
078436: *Oct 18 2017 16:39:08.509: //6667823/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:172.30.1.4:5060;transport=udp SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Content-Length: 0
078437: *Oct 18 2017 16:39:08.509: //6667824/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 488 Not Acceptable Media
CSeq: 1 INVITE
Server: Cisco-SIPGateway/IOS-15.5.3.S2
Content-Length: 0
078438: *Oct 18 2017 16:39:08.512: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Contact: <sip:10.253.129.52>
Max-Forwards: 70
User-Agent: Brktsip/6.2.8B19 (Dialogic)
Content-Length: 0
078439: *Oct 18 2017 16:39:08.512: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
078440: *Oct 18 2017 16:39:08.513: call_info mainst_callID:0x65BE30, peer_callID:0x65BE2F, confID:0x3D9D6, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
078441: *Oct 18 2017 16:39:08.513: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
078442: *Oct 18 2017 16:39:08.513: stream[0]: callid:0x65BE30, media_passthrough:1
078443: *Oct 18 2017 16:39:08.513: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
078444: *Oct 18 2017 16:39:08.513: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
078445: *Oct 18 2017 16:39:08.513: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
078446: *Oct 18 2017 16:39:08.513: call_info mainst_callID:0x65BE30, peer_callID:0x65BE2F, confID:0x3D9D6, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
078447: *Oct 18 2017 16:39:08.513: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
078448: *Oct 18 2017 16:39:08.513: stream[0]: callid:0x65BE30, media_passthrough:1
078449: *Oct 18 2017 16:39:08.513: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
078450: *Oct 18 2017 16:39:08.513: //6667824/B09BEDD49D15/CCAPI/cc_api_event_indication:
078451: *Oct 18 2017 16:39:08.514: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 2 BYE
Via: SIP/2.0/UDP 10.253.129.52:5060;branch=z9hG4bK-b96284-d428d4a1-523cc3c5
Supported: timer
Max-Forwards: 70
Content-Length: 0
078452: *Oct 18 2017 16:39:08.515: //6667823/B09BEDD49D15/CCAPI/ccGenerateToneInfo:
078453: *Oct 18 2017 16:39:08.515: //6667824/B09BEDD49D15/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x7FF404FF9F70, Call Id=6667824
078454: *Oct 18 2017 16:39:08.515: //6667824/B09BEDD49D15/CCAPI/cc_api_call_disconnected:
078455: *Oct 18 2017 16:39:08.515: //6667823/B09BEDD49D15/CCAPI/ccConferenceDestroy:
Conference Id=0x3D9D6, Tag=0x0
078456: *Oct 18 2017 16:39:08.515: //6667823/B09BEDD49D15/CCAPI/ccConferenceDestroy:
078457: *Oct 18 2017 16:39:08.515: confID:0x3D9D6; callEntry1 callID1:0x65BE2F, type:3; callEntry2 callID2:0x65BE30, type:3
078458: *Oct 18 2017 16:39:08.515: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078459: *Oct 18 2017 16:39:08.515: cc_api_get_xcode_stream : 4983
078460: *Oct 18 2017 16:39:08.515: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078461: *Oct 18 2017 16:39:08.515: cc_api_get_xcode_stream : 4983
078462: *Oct 18 2017 16:39:08.515: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078463: *Oct 18 2017 16:39:08.515: cc_api_get_xcode_stream : 4983
078464: *Oct 18 2017 16:39:08.515: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078465: *Oct 18 2017 16:39:08.516: cc_api_get_xcode_stream : 4983
078466: *Oct 18 2017 16:39:08.516: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078467: *Oct 18 2017 16:39:08.516: cc_api_get_xcode_stream : 4983
078468: *Oct 18 2017 16:39:08.516: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078469: *Oct 18 2017 16:39:08.516: cc_api_get_xcode_stream : 4983
078470: *Oct 18 2017 16:39:08.516: //6667823/B09BEDD49D15/CCAPI/cc_api_bridge_drop_done:
078471: *Oct 18 2017 16:39:08.516: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078472: *Oct 18 2017 16:39:08.516: cc_api_get_xcode_stream : 4983
078473: *Oct 18 2017 16:39:08.516: //6667823/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078474: *Oct 18 2017 16:39:08.516: cc_api_get_xcode_stream : 4983
078475: *Oct 18 2017 16:39:08.516: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078476: *Oct 18 2017 16:39:08.516: cc_api_get_xcode_stream : 4983
078477: *Oct 18 2017 16:39:08.516: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078478: *Oct 18 2017 16:39:08.516: cc_api_get_xcode_stream : 4983
078479: *Oct 18 2017 16:39:08.517: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078480: *Oct 18 2017 16:39:08.517: cc_api_get_xcode_stream : 4983
078481: *Oct 18 2017 16:39:08.517: //6667824/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
078482: *Oct 18 2017 16:39:08.517: cc_api_get_xcode_stream : 4983
078483: *Oct 18 2017 16:39:08.517: //6667824/B09BEDD49D15/CCAPI/cc_api_bridge_drop_done:
078484: *Oct 18 2017 16:39:08.517: //6667823/B09BEDD49D15/CCAPI/cc_generic_bridge_done:
078485: *Oct 18 2017 16:39:08.518: //6667823/B09BEDD49D15/CCAPI/ccCallDisconnect:
078486: *Oct 18 2017 16:39:08.518: //6667823/B09BEDD49D15/CCAPI/ccCallDisconnect:
078487: *Oct 18 2017 16:39:08.519: //6667824/B09BEDD49D15/CCAPI/ccCallDisconnect:
078488: *Oct 18 2017 16:39:08.519: //6667824/B09BEDD49D15/CCAPI/ccCallDisconnect:
078489: *Oct 18 2017 16:39:08.521: //6667823/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.21.121.130:5060;branch=z9hG4bK2654E97BB
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S2
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
078490: *Oct 18 2017 16:39:08.521: //6667824/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 2 BYE
Content-Length: 0
078491: *Oct 18 2017 16:39:08.524: //6667824/B09BEDD49D15/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7FF404FF9F70, Tag=0x0, Call Id=6667824,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
078492: *Oct 18 2017 16:39:08.524: //6667824/B09BEDD49D15/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
078493: *Oct 18 2017 16:39:08.524: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
078494: *Oct 18 2017 16:39:08.524: :cc_free_feature_vsa freeing 7FF4099DF7C0
078495: *Oct 18 2017 16:39:08.524: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
078496: *Oct 18 2017 16:39:08.524: vsacount in free is 73
078497: *Oct 18 2017 16:39:08.526: //6667823/B09BEDD49D15/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
Received:
CSeq: 1 INVITE
Supported: timer
Max-Forwards: 70
Min-SE: 1800
Content-Length: 288
v=0
s=no_session_name
t=0 0
c=IN IP4 10.253.129.52
a=T38FaxVersion:0
Sent:
P-Asserted-Identity: <sip:4033131776@lii01.livun.com>
Supported: 100rel,timer,resource-priority,replaces,histinfo,sdp-anat
Min-SE: 1800
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <sip:4033131776@172.21.121.130:5060>
Expires: 180
Content-Length: 323
v=0
s=SIP Call
t=0 0
a=T38FaxVersion:0
Received:
CSeq: 101 INVITE
Content-Length: 0
The fax server side supports T.38 so that is not an issue.
Listen, I am trying to help you here, the least you can do is take a moment to read my posts..The fax server is not the one rejecting the call, something that you will see clearly in my post if only you try to read it. This is the device rejecting your T.38 negotiation:172.30.1.4
Well, I am not sure too, my only guess is that CUCM changed the fax negotiation..it is just a guess, we can look at the logs to see what happens when you use CTI-RP. Send the logs and we will find out..
