We have a Broadworks switch and primarily use SPA 504 and 525 phones. They support a feature to "click to answer" when running the Broadworks toolbar on your PC. Basically when a call is incomming you get the little "toaster" popup on the bottom of your screen and if you click the name or number of the caller the 504 and 525 phones will go off hook on speaker or headset depnding on what you were using last.
By default this doesn't seem to work on the 7940s. Does anyone know if this is a configuration option that I need to enable. I'm not even 100% sure what you would call this feature.
Thanks!
