01-30-2010 02:46 PM - edited 03-15-2019 09:15 PM
SIPGATEWAY#sh run
Building configuration...
Current configuration : 2334 bytes
version 12.4
hostname SIPGATEWAY
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.5.1 192.168.5.10
ip dhcp pool ITS
network 192.168.5.0 255.255.255.0
option 150 ip 192.168.5.1
default-router 192.168.5.1
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
voice class codec 1
interface FastEthernet0/0
ip address dhcp
duplex auto
speed auto
interface Serial0/0
no ip address
no fair-queue
interface FastEthernet0/1
ip address 192.168.5.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1
no ip address
ip route 10.3.3.0 255.255.255.0 192.168.2.50
ip http server
no ip http secure-server
control-plane
dial-peer voice 2 voip
destination-pattern 9...........
voice-class codec 1
session protocol sipv2
session target ipv4:204.11.192.36
dtmf-relay rtp-nte
no vad
sip-ua
authentication username 17772823581 password 15160A0800337A
no remote-party-id
retry invite 2
retry register 10
sip-server ipv4:204.11.192.39
telephony-service
max-ephones 10
max-dn 10
ip source-address 192.168.5.1 port 2000
auto assign 1 to 10
--More--
*Mar 8 05:33:50.732: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed sta create cnf-files version-stamp Jan 01 2002 00:00:00
dialplan-pattern 1 7705774... extension-length 4 extension-pattern 500.
max-conferences 4 gain -6
transfer-system full-consult
ephone-dn 1 dual-line
number 5001
ephone-dn 2 dual-line
number 5002
ephone-dn 3 dual-line
number 5003
ephone-dn 4 dual-line
number 5004
ephone-dn 5 dual-line
number 5005
ephone-dn 6 dual-line
number 5006
ephone-dn 7 dual-line
number 5007
ephone-dn 8 dual-line
number 5008
ephone-dn 9 dual-line
number 5009
ephone-dn 10 dual-line
number 5010
ephone 1
mac-address 000F.34EC.C959
type 7940
button 1:1
ephone 2
ephone 3
ephone 4
ephone 5
ephone 6
ephone 7
ephone 8
ephone 9
ephone 10
line con 0
line aux 0
line vty 0 4
end
*Mar 8 06:37:10.576: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:917771234567@204.11.192.36:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.5.1:5060;branch=z9hG4bKA42497
From: <sip:7705774..1@192.168.5.1>;tag=25782450-1026
To: <sip:917771234567@204.11.192.36>
Date: Fri, 08 Mar 2002 06:37:10 GMT
Call-ID: C09FFAFF-319511D6-80B8A7A1-2DFA084@192.168.5.1
Supported: 100rel,timer,replaces
Min-SE: 1800
Cisco-Guid: 3204589746-831853014-2159388577-48210052
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1015569430
Contact: <sip:7705774..1@192.168.5.1:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 266
v=0
o=CiscoSystemsSIP-GW-UserAgent 2974 638 IN IP4 192.168.5.1
s=SIP Call
c=IN IP4 192.168.5.1
t=0 0
m=audio 16526 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
*Mar 8 06:37:11.072: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 08 Mar 2002 06:37:11 GMT
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1015569431
Expires: 180
Content-Length: 266
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
*Mar 8 06:37:12.072: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 08 Mar 2002 06:37:12 GMT
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1015569432
Expires: 180
Content-Length: 266
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
520: //35/240C4CEF8052/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 84198CB4
Solved! Go to Solution.
01-31-2010 12:57 AM
Check your NAT device, as router never receives a reply.
01-31-2010 06:39 PM
as per your sip invite sent:
Sent:
looks that this is sent to a routeable IP 204.11.192.36 on the internet so you will need to include a source routable address. The one you are sending is private and more than likely your SIP provider will not reply properly:
I see no public addresses within the router so you need an interface with a public address or NAT...
let me know if it helps
Efrain
01-30-2010 03:25 PM
Take "debug ccsip message" ONLY and post relevant configuration ONLY.
Excessive verbosity doesn't help diagnising.
01-30-2010 03:43 PM
Should the 7705774... be the number the SIP Provider gave me? I actually created the 770number myself. I also deleted the debug CCSIP All info.
01-31-2010 12:57 AM
01-31-2010 06:39 PM
Sent:
Efrain
02-01-2010 06:28 AM
Thanks for your help but, my CME router is behind a another firewall. In performing some tests. I found out that the firewall was not passing the traffic properly. Everything is working fine now.
