SIP Call on CUBE - DNIS issue
atrishkapil
I am facing some issues with incoming calls on my CUBE and would like to see if someone has seen it before and may have any suggestions for me.
Topology
SIP Provider ---Internet---Cisco CUBE---SIP PBX---IP Phones
SIP Authentication Username: 999999999
Calling Number: 4444444444
DID Number: 2222222222
When I place an incoming call to the DID number, I see the call hitting the CUBE and I see original DID number in the SIP invite however, the  "debug voice ccapi inout" output shows my Authentication Username as DNIS / dest. My outgoing calls work fine, FYI.
See below debug output for more information about the issue.
Called Number: 2222222222
Received:
INVITE sip:999999999@162.255.135.135:5060 SIP/2.0Via: SIP/2.0/UDP 208.73.146.93:5060;branch=z9hG4bKrmbj4k1008sgkotti2v0.1Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay,  multipart/mixedCall-Id: pcst14394069410216855257110@192.168.201.116Contact: <sip:4444444444@208.73.146.93:5060;transport=udp>Content-Disposition: session; handling=requiredContent-Length: 238Content-Type: application/sdpCSeq: 1 INVITEFrom: "TORONTO      ON"  <sip:4444444444@192.168.101.116:5060;otg=TG_CORE_GSX;pstn-params=808282808882>;tag=gK0e586c3dIn-Reply-To: 1091449023_102126645@207.155.147.62Session-Expires: 1800;refresher=uasSupported: timerTo: <sip:2222222222@192.168.101.100>Max-Forwards: 70v=0o=Sonus_UAC 26856 17247 IN IP4 208.73.146.93s=SIP Media Capabilitiesc=IN IP4 208.73.146.93t=0 0m=audio 18248 RTP/AVP 0 101a=rtpmap:0 PCMU/8000a=rtpmap:101 telephone-event/8000a=fmtp:101 0-15a=sendrecva=maxptime:20
Aug 12 19:15:41.046: //-1/5B2C1EDE8838/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=4444444444
   ----- ccCallInfo IE subfields -----
   cisco-ani=4444444444
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=999999999
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Aug 12 19:15:41.046: //-1/5B2C1EDE8838/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2263D9AC, Call Info(
   Calling Number=4444444444,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=999999999(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=577
Aug 12 19:15:41.046: //-1/5B2C1EDE8838/CCAPI/ccCheckClipClir:
   In: Calling Number=4444444444(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=4444444444(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Aug 12 19:15:41.046: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 12 19:15:41.046: :cc_get_feature_vsa malloc success
Aug 12 19:15:41.046:  cc_get_feature_vsa count is 1
Aug 12 19:15:41.046: :FEATURE_VSA attributes are: feature_name:0,feature_time:1073352592,feature_id:520
Aug 12 19:15:41.046: //577/5B2C1EDE8838/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=4444444444(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=999999999(TON=Unknown, NPI=Unknown))
Aug 12 19:15:41.046: //577/5B2C1EDE8838/CCAPI/cc_process_call_setup_ind:
   Event=0x22BA0808
Aug 12 19:15:41.046: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 999999999
Aug 12 19:15:41.050: //577/5B2C1EDE8838/CCAPI/ccCallSetContext:
   Context=0x2106053C
Aug 12 19:15:41.050: //577/5B2C1EDE8838/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 577 with tag 10 to app "_ManagedAppProcess_Default"
Aug 12 19:15:41.050: //577/5B2C1EDE8838/CCAPI/ccCallProceeding:
Aug 12 19:15:41.050: //577/5B2C1EDE8838/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=101, Params=0x2105C494, Progress Indication=NULL(0)
Aug 12 19:15:41.050: //577/5B2C1EDE8838/CCAPI/ccCheckClipClir:
   Destination Pattern=999999999, Called Number=999999999, Digit Strip=FALSE
   Redirect Number=, Display Info=TORONTO      ON
   Account Number=4444444444, Final Destination Flag=TRUE,
   Guid=5B2C1EDE-405D-11E5-8838-F2DF6208B46A, Outgoing Dial-peer=101
Aug 12 19:15:41.050: //577/5B2C1EDE8838/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=999999999
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug 12 19:15:41.050: //577/5B2C1EDE8838/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2263D9AC, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=4444444444,(Calling Name=TORONTO      ON)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=999999999(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=101, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Aug 12 19:15:41.050: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Here are the relevant sections from my CUBE configuration:
IOS: "c2900-universalk9-mz.SPA.154-3.M2.bin"
Model: 2911
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 5 hs-redundancy 2 fallback none
 h323
 sip
  bind control source-interface GigabitEthernet0/2
  bind media source-interface GigabitEthernet0/2
  rel1xx disable
  registrar server
  early-offer forced
  no call service stop
dial-peer voice 1 voip
 destination-pattern [2-9]..[2-9]......
 session protocol sipv2
 session target sip-server
 dtmf-relay rtp-nte
 codec g711ulaw
 ip qos dscp cs5 media
 no vad
sip-ua
 credentials username 999999999 password 7 11343414124142 realm voip.aaa.com
 authentication username 999999999 password 7 11343414124142 realm voip.aaa.com
 retry invite 3
 retry response 5
 retry bye 5
 retry cancel 5
 retry prack 5
 retry rel1xx 5
 retry notify 5
 retry refer 5
 retry info 5
 retry register 5
 retry subscribe 5
 timers trying 1000
 timers expires 60000
 timers connect 250
 timers disconnect 250
 timers prack 250
 timers rel1xx 250
 timers notify 250
 timers refer 250
 timers info 250
 timers register 250
 registrar dns:trunking.voipdnsservers.com expires 3600
 sip-server dns:trunking.voipdnsservers.com
 no suspend-resume
 reason-header override
 g729-annexb override
 handle-replaces
Please let me know if you have any suggestions.
thanks in advance,
Kapil
Nadeem Ahmed
Can you please post show run from CUBE and show sip-ua status
Br,
Nadeem
Br, Nadeem Please rate all useful post.
The CUBE is working properly. Based on the RFC the call routing should be done based on request-URI instead of TO header.
Your ITSP is supposed to send you the proper request-URI which represents the called number instead of sending the pilot number.
From CUBE perspective, the are two ways to fix this problem:
1. If you are running IOS 15.1(3) and later you can use SIP normalization to copy contents from header to another and assign to your in/out dialpeer. Example.
voice class sip-profiles 107
 request INVITE sip-header To copy "<sip:(.*)@>;" u01
 request INVITE sip-header SIP-Req-URI modify "<sip:(.*)@" "\u01"
2. Using TCL script to copy the content of TO header and paste in the request-URI for the outgoing call leg.
I prefer method one
