08-05-2022 08:18 AM - edited 08-05-2022 09:14 AM
In the my current environment we are running Cisco 2921 routers for our CUBE. When we have a WAN failure whether that's a quick flap or fail over to DR the SIP trunks remain registered on the CUBE and the PSTN side but calls timeout until the CUBE is rebooted. I captured some CCSIP debugs during the issue and was looking for some insight to see if anyone can assist with determining the issue.
Edit: After reviewing the debugs I am thinking that the CUBE is sending the invite message to the SIP provider but no ACK is ever recieved before the timeout period so the call gets terminated. Leads me to believe an issue is on the SIP provider but trying to see what others thoughts are.
Debugs when WAN fails we start seeing timeouts in the logs:
%VOICE_IEC-3-GW: SIP: Internal Error (1xx wait timeout): IEC=1.1.129.7.59.0 on callID 319850 GUID=B852DF800001000001580E8A0201C90A
CCSIP Debug Logs For Outbound Call:
Received:
INVITE sip:19034311457@10.201.1.9:5060 SIP/2.0
Via: SIP/2.0/UDP 10.201.1.2:5060;branch=z9hG4bK12ddc8be51af00f1
From: <sip:9035343000@10.201.1.2>;tag=978282542~59ac3c89-20a4-488a-9bbb-a4a20b46bc80-43255605
To: <sip:19034311457@10.201.1.9>
Date: Fri, 05 Aug 2022 04:13:59 GMT
Call-ID: 667e300-2ec19907-aeb54d7-201c90a@10.201.1.2
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM10.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.201.1.2:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Cisco-Guid: 0107471616-0000065536-0022548114-0033671434
Session-Expires: 1800
P-Asserted-Identity: <sip:9035343000@10.201.1.2>
Remote-Party-ID: <sip:9035343000@10.201.1.2>;party=calling;screen=yes;privacy=off
Contact: <sip:9035343000@10.201.1.2:5060>;video;audio;+u.sip!devicename.ccm.cisco.com="CSFEBROOKS";bfcp
Max-Forwards: 69
Content-Type: application/sdp
Content-Length: 1349
v=0
o=CiscoSystemsCCM-SIP 978282542 1 IN IP4 10.201.1.2
s=SIP Call
c=IN IP4 10.80.9.21
b=TIAS:384000
b=AS:384
t=0 0
a=cisco-mari:v1
a=cisco-mari-rate
m=audio 17480 RTP/AVP 9 104 105 0 8 18 101
a=extmap:14/sendrecv http://protocols.cisco.com/timestamp#100us
a=rtpmap:9 G722/8000
a=rtpmap:104 G7221/16000
a=fmtp:104 bitrate=32000
a=rtpmap:105 G7221/16000
a=fmtp:105 bitrate=24000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
m=video 24832 RTP/AVP 126 97 111
b=TIAS:384000
a=label:11
a=rtpmap:126 H264/90000
a=fmtp:126 profile-level-id=42801F;packetization-mode=1;max-mbps=244800;max-fs=8161;max-rcmd-nalu-size=32000;level-asymmetry-allowed=1
a=imageattr:126 recv [x=[32:1:1920],y=[18:1:1080],par=1.7778,q=1.00]
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=42801F;packetization-mode=0;max-mbps=244800;max-fs=8161;level-asymmetry-allowed=1
a=imageattr:97 recv [x=[32:1:1920],y=[18:1:1080],par=1.7778,q=1.00]
a=rtpmap:111 X-ULPFECUC/90000
a=fmtp:111 max_esel=1420;m=8;max_n=32;FEC_ORDER=FEC_SRTP
a=content:main
a=recvonly
a=rtcp-fb:* ccm fir
a=rtcp-fb:* ccm tmmbr
a=rtcp-fb:* nack pli
m=application 32028 RTP/AVP 125
a=rtpmap:125 H224/4800
a=rtcp:32029
017571: Aug 4 23:13:59.632: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
017572: Aug 4 23:13:59.632: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x3F180B60) with key=[434061] to table
017573: Aug 4 23:13:59.632: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
017574: Aug 4 23:13:59.632: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
017575: Aug 4 23:13:59.632: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
017576: Aug 4 23:13:59.632: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 0, sip_vrfid 0, voice_vrfid 0
017577: Aug 4 23:13:59.632: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
017578: Aug 4 23:13:59.632: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
017579: Aug 4 23:13:59.632: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 10.201.1.9 for SIP
017580: Aug 4 23:13:59.632: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 10.201.1.9
017581: Aug 4 23:13:59.632: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone cdt to SIP default timezone = GMT
017582: Aug 4 23:13:59.632: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0xC2A579FC) counter, current msg->refCount = 2
017583: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x3F180B60)->last_request = 0xC2A579FC, refCount = 2
017584: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/8192/sipSPIProcessSessionID: SessionID header not present - create uuid
017585: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Generate uuid
017586: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Initial Invite SIP-TDM /MF case
017587: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/8192/sipSPIGenerateSessionUUID: generated uuid - ab39b636c93450778b87606070d9f662
017588: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/notify/8192/sipSPI_Add_SessionIDtoTDContainer: localUUID - ab39b636c93450778b87606070d9f662remoteUUID - 00000000000000000000000000000000
017589: Aug 4 23:13:59.632: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/sipSPICheckIpip: VOIP dialpeer (peer=0x3D849AF4) found for sip_user: 19034311457
017590: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/2048/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
017591: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/36864/sipSPIUpdateIdentity: MF: PAI url is present & make a copy..
017592: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/4096/sipSPIUpdateIdentity: PAI genUrl is present..
017593: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/4096/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Number to 9035343000
017594: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/4096/sipSPIUpdateIdentity: PAI host = 10.201.1.2
017595: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/4096/sipSPISetCallingInfo: calling host comes from From: 10.201.1.2
017596: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/2048/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
017597: Aug 4 23:13:59.632: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentGTD: No GTD found in inbound container
017598: Aug 4 23:13:59.632: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentCSTA: No CSTA found in inbound container
017599: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x3F180B60 key=667e300-2ec19907-aeb54d7-201c90a@10.201.1.219034311457 balance 1
017600: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/8192/sipSPIMatchSrcIpGroup: Match not found on carrier id
017601: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/critical/8192/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 19034311457
017602: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/critical/8192/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 9035343000
017603: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/info/12288/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name , number 9035343000, Calling oct3 0x00, oct_3a 0x81, Called number 19034311457
017604: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/verbose/1024/sipSPIGetViaHostInURLFormat: VIA URL:sip:10.201.1.2:5060, Host:10.201.1.2
017605: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/verbose/67584/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 9035343000
017606: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/critical/1024/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
017607: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/critical/1024/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
017608: Aug 4 23:13:59.632: //-1/0667E3000158/SIP/Info/critical/10240/sipSPIGetCallConfig: No match found for P-Called-Party-ID
017609: Aug 4 23:13:59.636: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 4, sip_vrfid 0, voice_vrfid 0
017610: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/notify/131072/sipSPIGetCallConfig: vrfID[0]
017611: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/2048/sipSPIGetCallConfig: Peer tag 4 matched for incoming call
017612: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/verbose/1024/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
017613: Aug 4 23:13:59.636: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 0, sip_vrfid 0, voice_vrfid 0
017614: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
017615: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
017616: Aug 4 23:13:59.636: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 10.201.1.9 for SIP
017617: Aug 4 23:13:59.636: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 10.201.1.9
017618: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/8192/sipSPIGetCallConfig: This call is being treated for E911
017619: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/2048/sipSPISetAudioForcedConfig: audio forced config is set to FALSE
017620: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/verbose/1024/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
017621: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/verbose/2048/sipSPIGetCallConfig: Media Antitrombone disabled
017622: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/8192/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
017623: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/2304/sipSPISetMediaFlowMode: xcoder high-density disabled
017624: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/8192/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
017625: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/1/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1 and offer-all is = FALSE
017626: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/verbose/12288/sipSPIGetModemInfoPerCall: peer_callID=0
017627: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/critical/32768/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
017628: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/8704/sipSPIGetCallConfig: Incoming: No defer BYE for last
call stats
017629: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/verbose/1/ccsip_set_srtp_config: No Srtp configure for this leg.
017630: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/8192/sipSPIGetCallConfig: Media forking disabled
017631: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/34816/ccsip_ipip_media_forking_anchor_leg_config: MF: en_p->encap_s.voIP.voipPeerCfgMediaClass = 0
017632: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/34816/ccsip_ipip_media_forking_anchor_leg_config: MF: Dial-peer has no media class recorder.
017633: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/36864/sipSPIMFChangeState: MF: Prev state = 0 & New state = -1
017634: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/32768/ccsip_ipip_media_forking_anchor_leg_reset: MF: Anchor leg config reset done...
017635: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/32768/ccsip_ipip_media_forking_intra_frame_request_config: MF: FIR en_p->encap_s.voIP.voipPeerCfgMediaClass = 0
017636: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/32768/ccsip_ipip_media_forking_get_forked_leg_config: MF: This leg is not forked call leg.
017637: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/critical/11264/ccsipInitDSCPPolicyInfo: No DSCP Profile configured, No RPH 2 DSCP Mapping and DSCP policing
017638: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/verbose/8192/sipSPIGetCallConfig: Initilise the DSCP policy
017639: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/verbose/8192/sipSPICheckFAAnatAssymetricOrDO2EO: Not a SIP-SIP call or not in FA mode
017640: Aug 4 23:13:59.636: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sipSPISetSipProfilesTag: voice class SIP Profiles tag is set : 1
017641: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/notify/2049/populate_vcc_data: Using Voice Class Codec, tag = 1 and offer-all is = FALSE
017642: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/notify/8192/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
017643: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/verbose/10240/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
017644: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/verbose/2048/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
017645: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
017646: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/notify/10240/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
017647: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Calling name , number 9035343000, Calling oct3 0x00, oct_3a 0x81, ext_priv 0x00, Called number 19034311457, oct3 0x00
017648: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
017649: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/4096/sipSPIContinueNewMsgInvite: Requires reliable-provisional support
017650: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/critical/10240/sipSPIValidateRequestUri: Not Enabled
017651: Aug 4 23:13:59.636: //-1/0667E3000158/SIP/Info/info/131072/sipSPIRscmsmAvail: Value returned by check is = 0
017652: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/critical/4096/sipSPICheckOutBoundDpProvisioning: Cannot obtain the the header bitmap
017653: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/critical/8192/sipSPI_ipip_IsSDPPassthruEnabled: - 0
017654: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/info/8192/sipSPIProcessSessionID: SessionID header not present - create uuid
017655: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Generate uuid
017656: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/info/8192/sipSPIGenerateSessionUUID: Initial Invite SIP-TDM /MF case
017657: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/info/8192/sipSPIGenerateSessionUUID: generated uuid - 587ad63a2eda5f559b2d43228cec6125
017658: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/notify/8192/sipSPI_Add_SessionIDtoTDContainer: localUUID - 587ad63a2eda5f559b2d43228cec6125remoteUUID - 00000000000000000000000000000000
017659: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/info/8192/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Session-Expires value: 1800 refresher: none
017660: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/info/8192/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 1800
017661: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/info/8192/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
017662: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/verbose/8192/Session-Timer/sipSTSLInitialSRReqPeerEventGen: sending received session expires to the peer leg
017663: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
SE: 1800;refresher:none peer refresher:none, flags:2011, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Configured SE:1800, Configured Min-SE:1800
017664: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/critical/1024/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
017665: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/critical/1024/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
017666: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/verbose/1024/sipSPIProcessNotifyCallInfoHeader: Callinfo parsed - Destination url = <sip:10.201.1.2:5060>, duration = 500
017667: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/critical/16384/sipSPIProcessReplacesHeader: No replaces hdr found
017668: Aug 4 23:13:59.636: //-1/xxxxxxxxxxxx/SIP/Info/verbose/1024/sipSPIGetContentCPA: No CPA found in inbound container
017669: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/verbose/1024/sipSPIProcessCPA: No x-cisco-cpa content found
SIP: Warning: Unrecognized attribute (cisco-mari)
SIP: Warning: Unrecognized attribute (cisco-mari-rate)
SIP: Warning: Unrecognized attribute (extmap)
SIP: Trying to parse unsupported attribute at media level
017670: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/verbose/1/sipSPIDoMediaNegotiation: Number of m-lines = 3
017671: Aug 4 23:13:59.636: //319889/0667E3000158/SIP/Info/verbose/1/sipSPIValidateConnectionAddress: Dest port = 17480
017672: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
017673: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: peer_tag=4
017674: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_media_ip_address_to_bind: VRF id = 0
017675: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/ccsip_get_ifaddress: ip_address IPv4 10.201.1.9 for SIP
017676: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 10.201.1.9 for SIP
017677: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(104) reserved for codec No Codec
017678: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
017679: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(104) reserved for codec No Codec
017680: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
017681: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(105) reserved for codec No Codec
017682: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
017683: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(105) reserved for codec No Codec
017684: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
017685: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
017686: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
017687: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved as its in use by other codec
017688: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPIUpdateDynamicPT: Requested payload-Type (101) is reserved by another application
017689: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
017690: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
017691: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
017692: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/rtpAvpCodec_to_voipCodec: Dynamic Payload :104 in SDP Body
017693: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/rtpAvpCodec_to_voipCodec: Dynamic Payload :105 in SDP Body
017694: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/1/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
017695: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/1/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
017696: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/info/8/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
017697: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/info/1/sipSPIDoDTMFRelayNegotiation: m-line index 1
017698: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
017699: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
017700: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
017701: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/1/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
017702: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/info/32/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
017703: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/info/1/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
017704: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 9
017705: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 104
017706: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is G7221
017707: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 105
017708: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is G7221
017709: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 0
017710: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 8
017711: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 18
017712: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: ptype is 101
017713: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8193/sip_sdp_get_modem_relay_cap_params: encname is telephone-event
017714: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8209/sip_sdp_get_modem_relay_cap_params: mer_dtmf_found 0
017715: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/8209/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
017716: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/critical/8193/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
017717: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/info/1/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
017718: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/1/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=10.80.9.21, dest_port=17480
017719: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/verbose/1/sipSPIValidateConnectionAddress: Dest port = 24832
017720: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:2, Mode : 1
017721: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
017722: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/rtpAvpCodec_to_voipCodec: Dynamic Payload :126 in SDP Body
017723: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/verbose/1/sipSPIDoVideoNegotiation: updated stream with negotiated codec h264 payload type 126
017724: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/rtpAvpCodec_to_voipCodec: Dynamic Payload :126 in SDP Body
017725: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/1/sipSPIDoVideoNegotiation: dynamic payload type:126, set stream->negotiated_codec to codec_type:30
017726: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(126) reserved for codec h264
017727: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(126) reserved for codec h264
017728: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/rtpAvpCodec_to_voipCodec: Dynamic Payload :97 in SDP Body
017729: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/verbose/1/sipSPIDoVideoNegotiation: updated stream with negotiated codec h264 payload type 97
017730: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/rtpAvpCodec_to_voipCodec: Dynamic Payload :97 in SDP Body
017731: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/1/sipSPIDoVideoNegotiation: dynamic payload type:97, set stream->negotiated_codec to codec_type:30
017732: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(97) reserved for codec h264
017733: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPICheckDynPayloadUse: Dynamic payload(97) could not be reserved as its in use by other codec
017734: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPIUpdateDynamicPT: Requested payload-Type (97) is reserved by another application
017735: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 97
017736: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
017737: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/rtpAvpCodec_to_voipCodec: Dynamic Payload :111 in SDP Body
017738: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/verbose/1/sipSPIDoVideoNegotiation: updated stream with negotiated codec payload type 111
017739: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/rtpAvpCodec_to_voipCodec: Dynamic Payload :111 in SDP Body
017740: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/1/sipSPIDoVideoNegotiation: dynamic payload type:111, set stream->negotiated_codec to codec_type:52
017741: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(111) reserved for codec
017742: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPICheckDynPayloadUse: Dynamic payload(111) could not be reserved as its in use by other codec mp4a-latm
017743: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPIUpdateDynamicPT: Requested payload-Type (111) is reserved by another application
017744: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 111
017745: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 99 for Codec: mp4a-latm
017746: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/info/1/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:2 and num-a-lines:0
017747: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/1/sipSPIDoVideoNegotiation: Codec negotiation successful for media line 2
codec=, dtmf_relay=inband-voice, payload_type=111,
pktPeriod=0, stream_type=video (7), dest_ip_address=10.80.9.21, dest_port=24832
017748: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/verbose/1/sipSPIValidateConnectionAddress: Dest port = 32028
017749: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:3, Mode : 1
017750: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
017751: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/rtpAvpCodec_to_voipCodec: Dynamic Payload :125 in SDP Body
017752: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/1/sipSPICheckDynPayloadUse: Dynamic payload(125) reserved for codec H.224
017753: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPICheckDynPayloadUse: Dynamic payload(125) could not be reserved as its in use by other codec clear-channel
017754: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/critical/1/sipSPIUpdateDynamicPT: Requested payload-Type (125) is reserved by another application
017755: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 125
017756: Aug 4 23:13:59.640: //-1/xxxxxxxxxxxx/SIP/Info/info/1/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 102 for Codec: clear-channel
017757: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/info/1/sipSPIDoApplicationNegotiation: updated stream with negotiated codec H.224 payload type 125
017758: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/info/1/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:3 and num-a-lines:0
017759: Aug 4 23:13:59.640: //319889/0667E3000158/SIP/Info/notify/1/sipSPIDoApplicationNegotiation: Codec negotiation successful for media line 3
codec=H.224, payload_type=125,
pktPeriod=0, stream_type=application (10), dest_ip_address=10.80.9.21, dest_port=32028
m=audio 16822 RTP/AVP 0 101
c=IN IP4 65.115.57.161
a=fmtp:101 0-15
a=ptime:20
m=video 32496 RTP/AVP 119 98
b=TIAS:384000
a=rtpmap:119 H264/90000
a=fmtp:119 profile-level-id=42801F;packetization-mode=1;max-mbps=245000;max-fs=8192
a=rtpmap:98 H264/90000
a=fmtp:98 profile-level-id=42801F;packetization-mode=0;max-mbps=245000;max-fs=8192
a=recvonly
a=label:11
a=content:main
m=application 20010 RTP/AVP 125
018366: Aug 4 23:14:00.196: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3DEAEBCC
018367: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone cdt to SIP default timezone = GMT
018368: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3DEAEBCC with refCount = 1
018369: Aug 4 23:14:01.196: //319892/0667E3000158/SIP/Info/critical/4096/ccsip_ipip_media_forking_get_forked_recording_data: MF: Not a Forked leg..
018370: Aug 4 23:14:01.196: //319892/0667E3000158/SIP/Info/critical/1024/sipSPICreateRecParticipantHeaders: X-Cisco-Recording-Participant header not added.
018371: Aug 4 23:14:01.196: //319892/0667E3000158/SIP/Info/info/34816/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
018372: Aug 4 23:14:01.196: //319892/0667E3000158/SIP/Info/info/4096/sipSPISendInvite: Associated container=0x4005828C to Invite
018373: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 658
018374: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Cisco-Guid is removed from the SIP message
018375: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: User-Agent is removed from the SIP message
018376: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header before modification : P-Asserted-Identity: <sip:9035343000@65.115.57.161>
018377: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header after modification : P-Asserted-Identity: <sip:9037054833@voip.centurylink.com>
018378: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/critical/1024/httpish_msg_get_complete_header: No holder for this header
018379: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/critical/64/sip_profiles_application_modify_remove_header: Unable to get header from stack
018380: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header before modification : From: "9035343000" <sip:9035343000@67.14.92.85>;tag=DB7748C-173C
018381: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header after modification : From: "9035343000" <sip:9035343000@voip.centurylink.com>;tag=DB7748C-173C
018382: Aug 4 23:14:01.196: //319892/0667E3000158/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
018383: Aug 4 23:14:01.196: //319892/0667E3000158/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:19034311457@67.14.92.85:5100 SIP/2.0
Via: SIP/2.0/UDP 65.115.57.161:5060;branch=z9hG4bK8263C70F
To: <sip:19034311457@67.14.92.85>
Date: Fri, 05 Aug 2022 04:14:01 GMT
Call-ID: DDA0646B-13AB11ED-B3458DDE-9443C8E2@65.115.57.161
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1659672841
Contact: <sip:9035343000@65.115.57.161:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 68
Session-ID: 587ad63a2eda5f559b2d43228cec6125;remote=00000000000000000000000000000000
Content-Disposition: session;handling=required
Content-Length: 658
v=0
o=CiscoSystemsSIP-GW-UserAgent 9716 6601 IN IP4 65.115.57.161
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
b=TIAS:384000
a=recvonly
a=label:11
a=content:main
018384: Aug 4 23:14:01.196: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3DEAEBCC
DC1-VoiceGW-1#
018385: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/critical/4096/sipSPIGetNextDestHost: No more entries, return FALSE
018386: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/critical/1024/sipSPIInitInvTryOtherIP: no more destinations in list
018387: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/critical/4096/ccsip_set_cc_cause_for_spi_err: Categorized cause:102, category:129
018388: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/4096/ccsip_set_release_source_for_peer: ownCallId[319892], src[6]
018389: Aug 4 23:14:03.196: %VOICE_IEC-3-GW: SIP: Internal Error (1xx wait timeout): IEC=1.1.129.7.59.0 on callID 319892 GUID=0667E3000001000001580E920201C90A
018390: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/critical/4096/sipSPIInitiateDisconnect: Initiate call disconnect(102) for outgoing call
018391: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 33
018392: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
018393: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/info/1024/sipAddSipContainerToCallEntry: Unable to add passthru hdrs to container
018394: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/8192/ccsip_call_statistics: Requesting stats for callid=319892
018395: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/critical/8192/ccsip_call_statistics: Stats request failed for callid=319892, dstCallID=-1, rc=-7
018396: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 33
018397: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/critical/4096/ccsip_ipip_mf_create_xml_metadata_for_disconnect: MF: Not a Forked leg..
018398: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
018399: Aug 4 23:14:03.196: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
018400: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
SE: 1800;refresher:none peer refresher:none, flags:2010, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
018401: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/info/133120/sipSPIBwCacReleaseDialPeerBw: bwcac dial-peer bw 522 Kbps released for tag 100 active bw 0 Kbps
018402: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/info/131072/sipSPIBwCacReleaseInterfaceBw: bwcac releasing interface Loopback0 bw 522 Kbps
018403: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/info/131072/sipSPIBwCacReleaseAccountedBw: bwcac released accounted bw 521600 bps
018404: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/info/4096/act_disconnecting_disconnect: Disconnect now.. no defer BYE..
018405: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/info/4096/sipSPISetCommonTimer: Started generic timer type 2 for 240000 millisecs
018406: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/8192/sipSPIDeferCallClose: Not split dataplane, bail
018407: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/8192/sipSPIWaitForStatsBforeCallClose: Not split dataplane, bail
018408: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/4096/sipSPICallCloseAfterFinalStat:
018409: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/info/12288/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:23013023 ConnTime 0
018410: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 4E194
018411: Aug 4 23:14:03.196: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[434062] removed.
018412: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/info/4096/sipSPIStopCommonTimer: Stopping Generic Timer 2
018413: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x3F228BF0 key=DDA0646B-13AB11ED-B3458DDE-9443C8E2@65.115.57.161
018414: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
018415: Aug 4 23:14:03.196: //-1/xxxxxxxxxxxx/SIP/Info/critical/512/sipConnectionManagerUnregisterCtxtInConnection: Could not find conn holder for addr=67.14.92.85
018416: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
018417: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
018418: Aug 4 23:14:03.196: //319892/0667E3000158/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x3F228BF0
018419: Aug 4 23:14:03.196: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[434062]
018420: Aug 4 23:14:03.196: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x3F228BF0) with key=[434063] to table
018421: Aug 4 23:14:03.196: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
018422: Aug 4 23:14:03.196: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
018423: Aug 4 23:14:03.196: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
018424: Aug 4 23:14:03.196: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 101, sip_vrfid 0, voice_vrfid 0
018425: Aug 4 23:14:03.196: //319895/000000000000/SIP/Info/notify/131072/ccsip_call_setup_request: vrfID[0]
018426: Aug 4 23:14:03.196: //319889/0667E3000158/SIP/Info/info/8192/sipSPIGetTDSessionID: Get peer leg session-ID local uuid - remote uuid -
018427: Aug 4 23:14:03.196: //319895/000000000000/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
018428: Aug 4 23:14:03.196: //319895/000000000000/SIP/Info/critical/32768/ccsip_ipip_media_forking_read_from_TDContainer: MF: Unable to read data from TD Container..
018429: Aug 4 23:14:03.196: //319895/000000000000/SIP/Info/critical/32768/ccsip_ipip_media_forking_forked_leg_config: MF: TD container cannot be read/container is NULL. Setting of forked call leg failed..
018430: Aug 4 23:14:03.196: //319895/000000000000/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: EV_UNDEFINED
018431: Aug 4 23:14:03.196: //319895/000000000000/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_SET_MODE
018432: Aug 4 23:14:03.196: //319895/000000000000/SIP/Info/info/4096/ccsip_get_int_type_frm_set_mode_ev:
018433: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/is_mode_sip_sip_md_snr:
018434: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_get_int_type_frm_set_mode_ev:
018435: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/is_mode_sip_sip_ed_snr:
018436: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_get_int_type_frm_set_mode_ev:
018437: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/is_mode_sip_sip_md:
018438: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_get_int_type_frm_set_mode_ev:
018439: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/is_mode_sip_sip_ed:
018440: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/verbose/8192/sip_iwf_sip_ed_set_mode_hdlr: Setting SPI mode to SIP-SIP
018441: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_iwf_handle_peer_event: Return value: SIP_IWF_SUCCESS
018442: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: CC_EV_IF_DIAG_DONE
018443: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_SET_FLOW_MODE
018444: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/is_fa2fa_flow_mode_transition:
018445: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_get_flow_mode_frm_set_flow_mode_ev:
018446: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/is_ft2fa_flow_mode_transition:
018447: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_get_flow_mode_frm_set_flow_mode_ev:
018448: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/is_fa2ft_md_flow_mode_transition:
018449: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/is_fa2ft_flow_mode_transition:
018450: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_get_flow_mode_frm_set_flow_mode_ev:
018451: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/is_fa2ft_flow_mode_transition:
018452: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_get_flow_mode_frm_set_flow_mode_ev:
018453: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/verbose/4096/ccsip_iwf_process_event: IWF - cnfsm ret 2
018454: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_iwf_handle_peer_event: Return value: SIP_IWF_SUCCESS
018455: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 400000
018456: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_call_setup_request:
This a IPIP call: Chan 0, codec 5 channel 17480, ip 10.80.9.21:17480 params 0x4275CF34 caps 0x228E5594
018457: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_call_setup_request:
This a IPIP call: Chan 1, codec -1 channel 17480, ip 10.80.9.21:17480 params 0x4275CF34 caps 0x228E5594
018458: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_call_setup_request:
This a IPIP call: Chan 2, codec -1 channel 17480, ip 10.80.9.21:17480 params 0x4275CF34 caps 0x228E5594
018459: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_call_setup_request:
This a IPIP call: Chan 3, codec -1 channel 17480, ip 10.80.9.21:17480 params 0x4275CF34 caps 0x228E5594
018460: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_call_setup_request:
This a IPIP call: Chan 4, codec -1 channel 17480, ip 10.80.9.21:17480 params 0x4275CF34 caps 0x228E5594
018461: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_call_setup_request:
This a IPIP call: Chan 5, codec -1 channel 17480, ip 10.80.9.21:17480 params 0x4275CF34 caps 0x228E5594
018462: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_call_setup_request:
This a IPIP call: Chan 6, codec -1 channel 17480, ip 10.80.9.21:17480 params 0x4275CF34 caps 0x228E5594
018463: Aug 4 23:14:03.200: //319895/000000000000/SIP/Info/info/4096/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 400000
018464: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
018465: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/5120/ccsip_call_setup_request: Session target or outbound proxy configured
018466: Aug 4 23:14:03.200: //-1/xxxxxxxxxxxx/SIP/Info/verbose/5120/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 67.14.90.85 target_port : 5100
018467: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/4096/sipSPIUaddccCallIdToTable: Adding call id 4E197 to table
018468: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/notify/131072/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [101]
018469: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/4096/ccsip_call_setup_request: Posting PRE_SETUP event to IWF.
018470: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 0, Event Id: CC_EV_SIP_PRE_SETUP
018471: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_PRE_SETUP
018472: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/1/sip_iwf_sip_ed_pre_setup_hdlr: Deferring SETUP till peer channel event.
018473: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/2049/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec bytes: 0
018474: Aug 4 23:14:03.200: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 101, sip_vrfid 0, voice_vrfid 0
018475: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/notify/131072/sipSPIGetCallConfig: vrfID[0]
018476: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/verbose/4096/sipSPI_set_mid_call_sig_not_supported: ReSetting mid call sig not supported
018477: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/verbose/16384/sipSPI_reset_block_chan_ind: Resetting the block channel id flags
018478: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/2048/sipSPISetAudioForcedConfig: audio forced config is set to FALSE
018479: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/2048/sipSPI_ipip_store_config_info: Setting mid_call_config_info = 0x2 for callid = 319895
018480: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/8192/sipSPIGetCallConfig: Media forking disabled
018481: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/32768/sipSPIGetCallConfig: Media Antitrombone disabled
018482: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/notify/131072/sipSPICanSetFallbackFlag: Local Fallback is not active
018483: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/8192/sipSPIGetCallConfig: VRF id = 0
018484: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/6144/sipSPI_ipip_read_peer_config_info: Mid-call Config info for peer leg is 0x2
018485: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/6144/sipSPI_ipip_read_peer_config_info: Config info for peer leg is 0x0
018486: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/8192/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
018487: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/2304/sipSPISetMediaFlowMode: xcoder high-density disabled
018488: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/8192/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
018489: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/1/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1 and offer-all is = FALSE
018490: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/12288/sipSPIGetModemInfoPerCall: peer_callID=319889
018491: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/critical/32768/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
018492: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/8704/sipSPIGetCallConfig: Incoming: No defer BYE for last
call stats
018493: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/1/ccsip_set_srtp_config: No Srtp configure for this leg.
018494: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/8192/sipSPIGetCallConfig: Media forking disabled
018495: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/34816/ccsip_ipip_media_forking_anchor_leg_config: MF: en_p->encap_s.voIP.voipPeerCfgMediaClass = 0
018496: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/34816/ccsip_ipip_media_forking_anchor_leg_config: MF: Dial-peer has no media class recorder.
018497: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/36864/sipSPIMFChangeState: MF: Prev state = 0 & New state = -1
018498: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/32768/ccsip_ipip_media_forking_anchor_leg_reset: MF: Anchor leg config reset done...
018499: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/32768/ccsip_ipip_media_forking_intra_frame_request_config: MF: FIR en_p->encap_s.voIP.voipPeerCfgMediaClass = 0
018500: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/32768/ccsip_ipip_media_forking_get_forked_leg_config: MF: This leg is not forked call leg.
018501: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/critical/11264/ccsipInitDSCPPolicyInfo: No DSCP Profile configured, No RPH 2 DSCP Mapping and DSCP policing
018502: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/8192/sipSPIGetCallConfig: Initilise the DSCP policy
018503: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/8192/sipSPICheckFAAnatAssymetricOrDO2EO: Not a SIP-SIP call or not in FA mode
018504: Aug 4 23:14:03.200: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sipSPISetSipProfilesTag: voice class SIP Profiles tag is set : 200
018505: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/notify/2049/populate_vcc_data: Using Voice Class Codec, tag = 1 and offer-all is = FALSE
018506: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/notify/8192/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
018507: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/10240/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
018508: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/verbose/2048/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
018509: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
018510: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/notify/10240/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
018511: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/info/4096/ccsip_iwf_handle_peer_event: Return value: SIP_IWF_SUCCESS
018512: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/verbose/4096/ccsip_event_handler: Received event : 196)
018513: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: EV_UNDEFINED
018514: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_SET_MODE
018515: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/4096/ccsip_get_int_type_frm_set_mode_ev:
018516: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/4096/is_mode_sip_sip_md_snr:
018517: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/4096/ccsip_get_int_type_frm_set_mode_ev:
018518: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/4096/is_mode_sip_sip_ed_snr:
018519: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/4096/ccsip_get_int_type_frm_set_mode_ev:
018520: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/4096/is_mode_sip_sip_md:
018521: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/4096/ccsip_get_int_type_frm_set_mode_ev:
018522: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/4096/is_mode_sip_sip_ed:
018523: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/verbose/8192/sip_iwf_sip_ed_set_mode_hdlr: Setting SPI mode to SIP-SIP
018524: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/verbose/4097/sipSPI_ipip_update_rtcp_session_for_streams: Updating RTCP session for stream 319889
018525: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/1/sipSPIAssignStreamCallId: Assigning streamid 319889 to stream 1. Old streamid = 319889
018526: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/8192/sipSPIUpdateRtcpSession: ccb->flags != LOOPBACK
018527: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/critical/4096/ccsip_update_peer_caps: Stream is NULL
018528: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/critical/4096/ccsip_update_peer_caps: gccb/stream is NULL, not updating now !!
018529: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/critical/1/sipSPIUpdateGccb: Failure from the peer leg so no updations now!!
018530: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/critical/1/sipSPIUpdateMediapolicy: media policy block does not exist
018531: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/critical/131072/sipSPIUpdateRtcpSession: Not able to Associate DSCP Profile with GCCB dscp_policy = 0x0, IS_SIPSPI_MODE_IN_SIP_SIP = 1 dscpPolicySeviceBlock = 0x0 , stream->qos_info = 0x0
018532: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/notify/8193/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
018533: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/notify/2080/sipSPIUpdateRtcpSession: DTMF inb/oob disabled
018534: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/verbose/4097/sipSPI_ipip_update_rtcp_session_for_streams: Updating RTCP session for stream 319890
018535: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/1/sipSPIAssignStreamCallId: Assigning streamid 319890 to stream 2. Old streamid = 319890
018536: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/critical/4096/sipSPIUpdateRtcpSession: No peer stream callID
018537: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/info/8192/sipSPIUpdateRtcpSession: ccb->flags != LOOPBACK
018538: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/critical/4096/ccsip_update_peer_caps: Stream is NULL
018539: Aug 4 23:14:03.200: //319895/0667E3000158/SIP/Info/critical/4096/ccsip_update_peer_caps: gccb/stream is NULL, not updating now !!
018540: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/critical/1/sipSPIUpdateGccb: Failure from the peer leg so no updations now!!
018541: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/critical/1/sipSPIUpdateMediapolicy: media policy block does not exist
018542: Aug 4 23:14:03.200: //319889/0667E3000158/SIP/Info/critical/131072/sipSPIUpdateRtcpSession: Not able to Associate DSCP Profile with GCCB dscp_policy = 0x0, IS_SIPSPI_MODE_IN_SIP_SIP = 1 dscpPolicySeviceBlock = 0x0 , stream->qos_info = 0x0
018543: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/notify/2080/sipSPIUpdateRtcpSession: DTMF inb/oob disabled
018544: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/verbose/1/sipSPI_ipip_post_multimedia_channel_event: Media Trigger = 12, peer_callID = 319895
018545: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/verbose/8193/sipSPI_ipip_post_multimedia_channel_event: callID2 319895
018546: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/verbose/1/sipSPI_ipip_build_stream_channel_array: Channel array created for 3 channels
018547: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/4096/ccsip_event_handler: Received event : 101)
018548: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 0, Event Id: CC_EV_SIP_MULTIMEDIA_CHANNEL_IND
018549: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_PEER_MULTIMEDIA_CHANNEL_IND
018550: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/4096/ccsip_iwf_handle_peer_event: Return value: SIP_IWF_SUCCESS
018551: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_map_cc_return_code: Mapping SIP_IWF_SUCCESS
018552: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/ccsip_iwf_handle_peer_event: Return value: SIP_IWF_SUCCESS
018553: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_map_cc_return_code: Mapping SIP_IWF_SUCCESS
018554: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: CC_EV_IF_DIAG_DONE
018555: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_SET_FLOW_MODE
018556: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/is_fa2fa_flow_mode_transition:
018557: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/ccsip_get_flow_mode_frm_set_flow_mode_ev:
018558: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/is_ft2fa_flow_mode_transition:
018559: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/ccsip_get_flow_mode_frm_set_flow_mode_ev:
018560: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/is_fa2ft_md_flow_mode_transition:
018561: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/is_fa2ft_flow_mode_transition:
018562: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/ccsip_get_flow_mode_frm_set_flow_mode_ev:
018563: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/is_fa2ft_flow_mode_transition:
018564: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/ccsip_get_flow_mode_frm_set_flow_mode_ev:
018565: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/verbose/4096/ccsip_iwf_process_event: IWF - cnfsm ret 2
018566: Aug 4 23:14:03.204: //319889/0667E3000158/SIP/Info/info/4096/ccsip_iwf_handle_peer_event: Return value: SIP_IWF_SUCCESS
018567: Aug 4 23:14:03.204: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 13 for event 70
018568: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/4096/is_trigger_session_timer_update:
018569: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/6144/sipSPI_ipip_read_peer_config_info: Mid-call Config info for peer leg is 0x2
018570: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/6144/sipSPI_ipip_read_peer_config_info: Config info for peer leg is 0x0
018571: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/1/sip_iwf_sip_copy_multimedia_channelInfo_to_stream: Creating SDP_INFO
018572: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/6144/sipSPI_ipip_read_peer_config_info: Mid-call Config info for peer leg is 0x2
018573: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/6144/sipSPI_ipip_read_peer_config_info: Config info for peer leg is 0x0
018574: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/notify/7/ccsip_is_audio_forced_configured: audio forced config: local = FALSE, peer = FALSE
018575: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
018576: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: peer_tag=101
018577: Aug 4 23:14:03.204: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_media_ip_address_to_bind: VRF id = 0
018578: Aug 4 23:14:03.204: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/ccsip_get_ifaddress: ip_address IPv4 65.115.57.161 for SIP
018579: Aug 4 23:14:03.204: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 65.115.57.161 for SIP
018580: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/1/sip_iwf_sip_copy_multimedia_channelInfo_to_stream: Stream Mapping 1: local=-1, peer=319889
018581: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/32/sipSPI_ipip_set_pld_flags_from_ex_caps: Peer cap provided: dtmf = 6, t38 version = 0 t38 maxBitRate = 0
018582: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/1/sipSPIAssignStreamCallId: Assigning streamid 319895 to stream 1. Old streamid = -1
018583: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
018584: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
018585: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/1/sip_iwf_sip_copy_audio_channelInfo_to_stream: Processing m-line 1
018586: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/1/sip_iwf_sip_copy_audio_channelInfo_to_stream: Number of payloads = 7
018587: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/1/sipSPI_get_stream_from_channelInfo: Creating new stream
018588: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/1/sip_iwf_sip_copy_multimedia_channelInfo_to_stream: Stream Mapping 2: local=-1, peer=319890
018589: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/1/sipSPIAssignStreamCallId: Assigning streamid 319896 to stream 2. Old streamid = -1
018590: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:2, Mode : 1
018591: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
018592: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/1/sip_iwf_sip_copy_video_channelInfo_to_stream: Reserving rtp port for stream 2, src_port=20344
018593: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/4/sip_iwf_sip_copy_video_channelInfo_to_stream: Setting ip_tos for video packet to 0x88
018594: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/1/sipSPI_get_stream_from_channelInfo: Creating new stream
018595: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/1/sip_iwf_sip_copy_multimedia_channelInfo_to_stream: Stream Mapping 3: local=-1, peer=319891
018596: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/1/sipSPIAssignStreamCallId: Assigning streamid 319897 to stream 3. Old streamid = -1
018597: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:3, Mode : 1
018598: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
018599: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/verbose/1/sip_iwf_sip_copy_app_channelInfo_to_stream: Reserving rtp port for stream 3, src_port=27592
018600: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/1/sip_iwf_sip_asymmetric_payload_processing_app: Setting stream tx/rx val = 255/0
018601: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/1/sipSPI_ipip_update_stream_direction_from_peer: Stream 1: peer_media_dir=3, RTCP dir=3
018602: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/1/sipSPI_ipip_update_stream_direction_from_peer: Stream 2: peer_media_dir=2, RTCP dir=2
018603: Aug 4 23:14:03.204: //319895/0667E3000158/SIP/Info/info/1/sipSPI_ipip_update_stream_direction_from_peer: Stream 3: peer_media_dir=3, RTCP dir=3
DC1-VoiceGW-1#sdp-anat
Content-Type: application/sdp
Content-Length: 161
v=0
o=CiscoSystemsSIP-GW-UserAgent 1357 5792 IN IP4 10.201.1.9
s=SIP Call
c=IN IP4 10.201.1.9
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
c=IN IP4 10.201.1.9
018928: Aug 4 23:14:03.548: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3DF17EA4
018929: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone cdt to SIP default timezone = GMT
018930: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3DF17EA4 with refCount = 1
018931: Aug 4 23:14:03.716: //319895/0667E3000158/SIP/Info/critical/4096/ccsip_ipip_media_forking_get_forked_recording_data: MF: Not a Forked leg..
018932: Aug 4 23:14:03.716: //319895/0667E3000158/SIP/Info/critical/1024/sipSPICreateRecParticipantHeaders: X-Cisco-Recording-Participant header not added.
018933: Aug 4 23:14:03.716: //319895/0667E3000158/SIP/Info/info/34816/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
018934: Aug 4 23:14:03.716: //319895/0667E3000158/SIP/Info/info/4096/sipSPISendInvite: Associated container=0x40057054 to Invite
018935: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 658
018936: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Cisco-Guid is removed from the SIP message
018937: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: User-Agent is removed from the SIP message
018938: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header before modification : P-Asserted-Identity: <sip:9035343000@65.115.57.161>
018939: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header after modification : P-Asserted-Identity: <sip:9034054289@voip.centurylink.com>
018940: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/critical/1024/httpish_msg_get_complete_header: No holder for this header
018941: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/critical/64/sip_profiles_application_modify_remove_header: Unable to get header from stack
018942: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header before modification : From: "9035343000" <sip:9035343000@67.14.90.85>;tag=DB78248-68A
018943: Aug 4 23:14:03.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header after modification : From: "9035343000" <sip:9035343000@voip.centurylink.com>;tag=DB78248-68A
018944: Aug 4 23:14:03.716: //319895/0667E3000158/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
018945: Aug 4 23:14:03.720: //319895/0667E3000158/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:19034311457@67.14.90.85:5100 SIP/2.0
Via: SIP/2.0/UDP 65.115.57.161:5060;branch=z9hG4bK8263D6D1
To: <sip:19034311457@67.14.90.85>
Date: Fri, 05 Aug 2022 04:14:03 GMT
Call-ID: DFB8E4CE-13AB11ED-B3478DDE-9443C8E2@65.115.57.161
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1659672843
Expires: 180
Max-Forwards: 68
Session-Expires: 1800
Content-Length: 658
v=0
o=CiscoSystemsSIP-GW-UserAgent 3208 9276 IN IP4 65.115.57.161
s=SIP Call
t=0 0
m=audio 21444 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
m=video 20344 RTP/AVP 119 98
b=TIAS:384000
a=recvonly
a=label:11
a=content:main
m=application 27592 RTP/AVP 125
a=rtpmap:125 H224/4800
018946: Aug 4 23:14:03.720: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x3DF17EA4
018947: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone cdt to SIP default timezone = GMT
018948: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x3DF17EA4 with refCount = 1
018949: Aug 4 23:14:04.716: //319895/0667E3000158/SIP/Info/critical/4096/ccsip_ipip_media_forking_get_forked_recording_data: MF: Not a Forked leg..
018950: Aug 4 23:14:04.716: //319895/0667E3000158/SIP/Info/critical/1024/sipSPICreateRecParticipantHeaders: X-Cisco-Recording-Participant header not added.
018951: Aug 4 23:14:04.716: //319895/0667E3000158/SIP/Info/info/34816/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
018952: Aug 4 23:14:04.716: //319895/0667E3000158/SIP/Info/info/4096/sipSPISendInvite: Associated container=0x40057054 to Invite
018953: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 658
018954: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Cisco-Guid is removed from the SIP message
018955: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: User-Agent is removed from the SIP message
018956: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header before modification : P-Asserted-Identity: <sip:9035343000@65.115.57.161>
018957: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header after modification : P-Asserted-Identity: <sip:9034054289@voip.centurylink.com>
018958: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/critical/1024/httpish_msg_get_complete_header: No holder for this header
018959: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/critical/64/sip_profiles_application_modify_remove_header: Unable to get header from stack
018960: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header before modification : From: "9035343000" <sip:9035343000@67.14.90.85>;tag=DB78248-68A
018961: Aug 4 23:14:04.716: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sip_profiles_application_modify_remove_header: Header after modification : From: "9035343000" <sip:9035343000@voip.centurylink.com>;tag=DB78248-68A
018962: Aug 4 23:14:04.716: //319895/0667E3000158/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
018963: Aug 4 23:14:04.716: //319895/0667E3000158/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 05 Aug 2022 04:14:04 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1659672844
Expires: 180
Max-Forwards: 68
Content-Length: 658
v=0
s=SIP Call
t=0 0
m
a=fmtp:101 0-15
a=ptime:20
b=TIAS:384000
a=recvonly
a=label:11
a=content:main
