Hi Guys,
My Customer have the solution with 06 sites, all working with SIP and CUCM 10.5.2. Today in all sites the call outgoing with main number. My Customer is needing that 01 site have a one group the IP Phones where the call need outgoing as direct dial extension. Is possible to do this for this group or only all IP Phones this sites? Are there any template with configuration type? I know that the Carrier too need change on their side.
Wilson
Hi Mohammed al Baqari,
Thanks a lot for Your contact.
Today I send 10 digits to Carrier and them mask the number and all calls outgoing with main number. The new scenario, the Carrier told me that they need to do change in the on their side, but, told me that is need to change on their our side.
Wilson
Today work of follow way (example)
11-81819500
11-81819501
. >> all calls outgoing use Caller ID 11-81819500
11-818195xx
What is need of Site (Extension HR)
11-81819500 >> Caller ID 11-81819500
11-81819501 >> Caller ID 11-81819500
11-81819502 >> Caller ID 11-81819500
11-81819540 >> Caller ID 11-81819540
11-81819541 >> Caller ID 11-81819541
11-81819542 >> Caller ID 11-81819542
11-81819544 .
11-81819545 .
11-81819546 . >> only this range need outgoing with specific number
11-81819547 .
11-81819548 .
11-81819549 .
11-81819550 >> Caller ID 11-81819550
11-81819551 >> Caller ID 11-81819500
11-81819552 >> Caller ID 11-81819500
11-818195xx >> Caller ID 11-81819500
What configuration is need to do in the gateway to support this demand?
Wilson
