341
Highlighted
SIP Client Phone and Voicemail
I am running CUCME 4.1.
I have voicemail running on an asterisk box (through mwi-server in sip-ua).
I have added a SIP phone to CUCME, with the following below.
When the client is connected to CUCME, it sends the call to voicemail with
no problem.. When it is not connected, it does not and returns 408 which
results in a congestion tone to the SIP trunk and invalid number to SCCP clients
calling it.
How can I get CUCME to treat the call in the same way it does if calling a SCCP
phone whilst disconnected, sending it to voicemail as busy?
voice service voip
allow-connections sip to sip
no supplementary-service sip refer
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server expires max 3600 min 300
voice register global
mode cme
source-address 10.0.0.5 port 5060
max-dn 10
max-pool 10
authenticate register
authenticate realm all
date-format D/M/Y
mwi stutter
voicemail 1571
tftp-path flash:
create profile sync 0022182970291169
network-locale GB
ntp-server 10.0.0.10 mode directedbroadcast
voice register dn  1
number 2006
call-forward b2bua busy 1572
call-forward b2bua mailbox 2006
call-forward b2bua noan 1571 timeout 20
allow watch
no-reg
mwi
voice register pool  1
id mac 0000.0000.0000
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username 2006 password #####
codec g711alaw
no vad
Everyone's tags (4)
2 REPLIES 2
VIP Mentor
Try this..
voice register dn 1
call forward b2bua unreachable XXXX where xxxx=voice mail pilot number
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
That seems to work (though documentation says the commands been removed).
It only seems to work after the sip registration has expired and only sip-to-sip.
sccp-to-sip still gives an "Unknown number" message.
Content for Community-Ad
August's Community Spotlight Awards
