SIP CUBE 3941 PVDM and Voice Card Question
jason-nguyen
I recently installed 2 pvdm modules into my cube.
Show diag confirms theres a pvdm slot 1 and 2.
I have a voice-card 0 configured for dspfarm.
How can I tell if the cube is using both pvdm slot 1 and 2?
Thank you
2 Accepted Solutions
If I'm not all wrong you'd need this as well as you have two PVDM slots.
voice-card 1
 dspfarm
 dsp services dspfarm
On the media resources that you have configured you'd be able to figure out if it would use both PVDMs based on the max number of available maximum session that you have possible to set. Looking at your configuration you do not have that set at all on your two media resources where you'd likely want to use the hardware resources.
You also do not have any SCCP configuration present, so the media resources would not have any way to know where they should register. There are plenty of documentation available around this if you search on internet with your favorite search engine. One example that is pretty good is this document, Basic Hardware-Base IOS Media Resources configuration and registration with Call Manager
One additional advice, if you do not intend to use VAD, and you'll likely won't as VAD=BAD, with this you should remove any codec under your media resources that has a "b" in the name as that means that it supports VAD. Please note that some codecs are auto added at the time of creating the media resource, so the best thing is to remove them prior to adding the max session command and un-shutting it. Otherwise you'd need to shut it, temporary remove the max session to be able to do a no codec .... command and then add the max session command back again and un-shut the media resource.
Response Signature
Jason,
Your original question was, "How can I tell if the cube is using both pvdm slot 1 and 2?"
Did you confirm both are being used with the "show dspfarm dsp all" command?   Would you mind posting the output if you get a chance?  Just curious.
11 Replies 11
That would depend on your configuration in IOS. If you want help verifying this please post your running configuration.
Response Signature
I am providing the hardware output and the cli i used for dspfarm
#show diag
Platform mid-plane:
PCB Serial Number : FOC19039SBL
Hardware Revision : 1.0
Part Number : 73-12222-02
Top Assy. Part Number : 800-31577-02
Board Revision : E0
Deviation Number : 0
Fab Version : 02
Product (FRU) Number : CISCO3945-CHASSIS
Version Identifier : V02
CLEI Code : IPMN310DRA
Chassis Serial Number : FJC1931D06F
Manufacturing Test Data : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 39 30 33 39 53 42 4C 40
0x10: 06 1B 41 01 00 82 49 2F BE 02 C0 46 03 20 00 7B
0x20: 59 02 42 45 30 88 00 00 00 00 02 02 CB 91 43 49
0x30: 53 43 4F 33 39 34 35 2D 43 48 41 53 53 49 53 89
0x40: 56 30 32 00 C6 8A 49 50 4D 4E 33 31 30 44 52 41
0x50: C2 8B 46 4A 43 31 39 33 31 44 30 36 46 C4 08 00
0x60: 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 0:
Cisco Services Performance Engine 150 for Cisco 3900 ISR Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time 04:55:10 ago
Hardware Crypto Engine Details:
The CHIP id is 0x0
The SEC revision no is 0x1
EEPROM contents at hardware discovery:
PCB Serial Number : FOC19271FQX
Hardware Revision : 1.1
Part Number : 73-11838-09
Top Assy. Part Number : 800-32329-05
Board Revision : B1
Fab Version : 04
Product (FRU) Number : C3900-SPE150/K9
Version Identifier : V06
CLEI Code : IPUCBDXBAA
Processor type : C3
Chassis MAC Address : 188b.9dbf.7700
MAC Address block size : 128
0x00: 04 FF C1 8B 46 4F 43 31 39 32 37 31 46 51 58 40
0x10: 06 13 41 01 01 82 49 2E 3E 09 C0 46 03 20 00 7E
0x20: 49 05 42 42 31 88 00 00 00 00 02 04 CB 8F 43 33
0x30: 39 30 30 2D 53 50 45 31 35 30 2F 4B 39 89 56 30
0x40: 36 20 D9 03 40 C1 CB C6 8A 49 50 55 43 42 44 58
0x50: 42 41 41 09 C3 C2 8B 46 4A 43 31 39 33 31 44 30
0x60: 36 46 C3 06 18 8B 9D BF 77 00 43 00 80 C4 08 00
0x70: 00 00 00 00 00 00 00 F3 00 03 40 01 99 FF FF FF
0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Internal Power Supply 1 information
Top Assy. Part Number : 341-0238-04
PCB Serial Number : QCS19051C3D
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Version Identifier : V04
Product (FRU) Number : PWR-3900-AC
CLEI Code : COUPAGSBAA
Board Revision : A0
0x00: 04 FF 40 05 E8 DF 45 01 55 00 EE 04 88 00 00 00
0x10: 00 C1 8B 51 43 53 31 39 30 35 31 43 33 44 03 00
0x20: 81 00 00 00 00 04 00 89 56 30 34 20 CB 8B 50 57
0x30: 52 2D 33 39 30 30 2D 41 43 C6 8A 43 4F 55 50 41
0x40: 47 53 42 41 41 F3 00 59 41 02 53 42 00 05 F8 00
0x50: 50 01 F4 17 DE 02 EE 1A AE 03 E8 1C 8E 04 E2 1E
0x60: 0A 05 DC 1E BE 06 D6 1F 72 07 D0 1F D6 08 CA 20
0x70: 30 09 C4 20 76 0A BE 20 9E 0B B8 20 E4 0D AC 21
0x80: AC 0F A0 21 DE 11 94 21 FC 13 88 22 10 17 70 22
0x90: 10 1B 58 21 CA 1F 40 21 F2 23 28 21 B6 27 10 21
0xA0: 7A 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
Internal Power Supply 2 information
Unknown or unpowered PSU is installed
PVDM Slot 0:
128-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
Part Number : 73-11810-03
Board Revision : D1
Fab Version : 03
PCB Serial Number : FOC19231PBR
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM3-128
Version Identifier : V01
0x00: 04 FF 40 05 DC 41 01 00 82 49 2E 22 03 42 44 31
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 39 32 33
0x20: 31 50 42 52 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 8F 50 56 44 4D 33 2D 31 32 38 20 20 20 20 20 20
0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 1:
Board Revision : C0
Fab Version : 03
PCB Serial Number : FOC1633520A
RMA History : 00
Processor type : 00
0x00: 04 FF 40 05 DC 41 01 00 82 49 2E 22 03 42 43 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 33 33
0x20: 35 32 30 41 03 00 81 00 00 00 00 04 00 09 00 CB
voice-card 0
dspfarm
I would like to know that i took advantage of all the pvdm3's installed 2 x 128 pvdm 3
voice-card 1
 dspfarm
Response Signature
Sorry forgot to mention ios 15.7
b.winter
As @Roger Kallberg wrote: post the running config ("sh run"). Leave out every sensitive data like username, passwords, enable secret, ...
jason-nguyen
heres the sh run
version 15.7
service timestamps log datetime msec localtime
service password-encryption
service internal
service sequence-numbers
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging queue-limit 1000
logging queue-limit trap 1000
logging buffered 3000000
no logging rate-limit
no logging console
no logging monitor
no aaa new-model
no process cpu autoprofile hog
clock timezone PST -8 0
clock summer-time PDT recurring
ip domain list mlkch.org
no ip domain lookup
ip domain name mlkch.org
ip name-server XX.XX0.100
ip name-server XX.XX0.101
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
voice-card 0
dspfarm
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 XX.XX2.200 255.255.255.255
ipv4 XX.XX2.201 255.255.255.255
ipv4 XX.XX2.202 255.255.255.255
ipv4 10.96.150.6 255.255.255.255
ipv4 8.33.176.100 255.255.255.255
ipv4 68.68.122.62 255.255.255.255
ipv4 68.68.122.80 255.255.255.255
ipv4 XX.XX.156.77 255.255.255.255
ipv4 XX.XX.28.125 255.255.255.255
ipv4 XX.XX.28.137 255.255.255.255
ipv4 XX.XX.152.21 255.255.255.255
ipv4 XX.XX.152.20 255.255.255.255
address-hiding
mode border-element license capacity 100
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
rel1xx disable
header-passing
asserted-id pai
early-offer forced
midcall-signaling passthru
g729 annexb-all
pass-thru content unsupp
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class codec 2
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice class sip-profiles 100
request ANY sip-header Allow-Header modify ", UPDATE" ""
request ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
response 200 sip-header Require remove
voice iec syslog
vxml logging-tag
license udi pid C3900-SPE150/K9 sn FOC19271FQX
license accept end user agreement
license boot module c3900 technology-package securityk9
license boot module c3900 technology-package uck9
license boot module c3900 technology-package datak9
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
notification-timer 120000
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description CUBE
ip address 10.96.150.6 255.255.255.224
duplex auto
speed auto
interface GigabitEthernet0/1
description SIP Trunk Outside to Lumen
ip address XX.XX.28.125 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
ip route XX.XX.152.20 255.255.255.255 XX.XX.28.138
ip route XX.XX.152.21 255.255.255.255 XX.XX.28.138
ip route XX.XX.156.76 255.255.255.255 XX.XX.28.126
ip route XX.XX.156.77 255.255.255.255 XX.XX.28.126
ip route 10.0.0.0 255.0.0.0 10.96.150.1 250
ip route 10.80.10.0 255.255.255.0 10.64.1.1
ip route 10.96.0.0 255.255.0.0 10.96.150.1
ip route 10.96.5.0 255.255.255.0 10.96.150.1
ip route 10.96.16.0 255.255.255.0 10.96.150.1
ip route XX.XX1.16 255.255.255.255 10.96.150.1
ip route XX.XX2.192 255.255.255.192 10.96.150.1
ip route XX.XX2.200 255.255.255.255 10.96.150.1
ip route XX.XX3.200 255.255.255.255 10.96.150.1
ip route XX.XX3.209 255.255.255.255 10.96.150.1
ip route XX.XX.9.0 255.255.255.0 10.96.150.1
ip route XX.XX.10.0 255.255.255.0 10.96.150.1
ip route XX.XX.11.0 255.255.255.0 10.96.150.1
ip route XX.XX.12.0 255.255.252.0 10.96.150.1
ip route XX.XX.30.0 255.255.255.0 10.96.150.1
ip route 172.16.24.0 255.255.248.0 10.64.1.1
ip ssh time-out 90
ip ssh authentication-retries 2
ip ssh rsa keypair-name SSH-KEY
ip ssh version 2
logging trap debugging
logging host XX.XX2.215
ipv6 ioam timestamp
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
associate application SCCP
dspfarm profile 3 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions software 500
dial-peer voice 1 voip
description Ingress CUCM to PSTN - LAN Interface
session protocol sipv2
session target ipv4:XX.XX2.201
session transport udp
incoming called-number .T
voice-class codec 1
dtmf-relay rtp-nte sip-kpml sip-notify
no vad
dial-peer voice 20 voip
description Outgoing Intelepeer
destination-pattern [0-9]T
session target ipv4:XX.XX2.200
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 10 voip
description Incoming dialpeer and 1+10 digits to Level 3
preference 1
destination-pattern ^1[2-9]..[2-9]......$
session target ipv4:XX.XX.156.77
voice-class codec 1
voice-class sip early-offer forced
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate 14400
fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback pass-through g711ulaw
sip-ua
retry invite 2
retry bye 2
retry cancel 2
retry refer 3
retry register 10
connection-reuse
gatekeeper
shutdown
vstack
line con 0
exec-timeout 0 0
stopbits 1
line aux 0
stopbits 1
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input ssh
line vty 5 15
login local
transport input ssh
scheduler allocate 20000 1000
ntp server XX.XX2.193
end
Daniel Bosch
As Roger mentioned, you probably need to add sccp config for your media resources to be functional.
However, you're also missing the "maximum sessions" command under your transcode and conf dspfarm profiles.  I'm pretty sure you need this to tell the router how many DSPs to allocate for each media resource type.  It's been a while, but I think the more complex the profile (determined by how many supported codecs configured) the more DSPs each session will consume.
Once you add that, the command -- show dspfarm dsp all -- should show you exactly how DSPs are allocated among xcode and conf.  The example below is from a 4331, but this command has been around for years.  0/4 references the PVDM slot on my router (voice-card 0/4)
Router#sh dspfarm dsp all
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0/4 1 46.2.8 UP N/A FREE xcode 1 - - -
0/4 1 46.2.8 UP N/A FREE conf 2 - - -
jason-nguyen
Here is an updated config.
version 15.7
service internal
hostname intelepeer02
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging console
no logging monitor
no aaa new-model
no ip domain lookup
ip name-server XX.XX.0.100
ip name-server XX.XX.0.101
ip cef
no ipv6 cef
voice-card 0
dspfarm
voice rtp send-recv
voice service voip
ipv4 XX.XX.2.200 255.255.255.255
ipv4 XX.XX.2.201 255.255.255.255
ipv4 XX.XX.2.202 255.255.255.255
ipv4 XX.XX.176.100 255.255.255.255
ipv4 XX.XX.122.62 255.255.255.255
ipv4 XX.XX.122.80 255.255.255.255
address-hiding
redirect ip2ip
sip
rel1xx disable
header-passing
asserted-id pai
early-offer forced
g729 annexb-all
voice class codec 1
voice class codec 2
voice class h323 1
voice iec syslog
vxml logging-tag
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
no ip address
shutdown
description CUBE
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip http server
ip route XX.XX.173.57 255.255.255.255 XX.XX.28.6
ip route XX.XX.173.60 255.255.255.255 XX.XX.28.6
ip route XX.XX.175.42 255.255.255.255 XX.XX.28.118
ip route XX.XX.175.49 255.255.255.255 XX.XX.28.118
ip route XX.XX.175.52 255.255.255.255 XX.XX.28.118
ip route XX.XX.1.16 255.255.255.255 10.96.150.1
ip route XX.XX.2.192 255.255.255.192 10.96.150.1
ip route XX.XX.2.200 255.255.255.255 10.96.150.1
ip route XX.XX.3.200 255.255.255.255 10.96.150.1
ip route XX.XX.3.209 255.255.255.255 10.96.150.1
ip ssh time-out 90
ip ssh version 2
logging host XX.XX.2.215
ipv6 ioam timestamp
nls resp-timeout 1
cpd cr-id 1
control-plane
sccp local GigabitEthernet0/1
sccp ccm XX.XX.2.200 identifier 1 version 7.0
sccp ccm XX.XX.2.201 identifier 2 version 7.0
sccp ccm XX.XX.2.202 identifier 3 version 7.0
sccp
sccp ccm group 1
associate ccm 2 priority 1
associate ccm 3 priority 2
associate ccm 1 priority 3
associate profile 1 register srt03_xcode
associate profile 2 register srt03_mtp
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 103
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 3
codec g711ulaw
maximum sessions hardware 100
session target ipv4:XX.XX.2.201
voice-class codec 1
no vad
session target ipv4:XX.XX.2.200
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
sip-ua
retry invite 2
retry bye 2
retry cancel 2
retry refer 3
retry register 10
connection-reuse
gatekeeper
shutdown
vstack
line con 0
exec-timeout 0 0
stopbits 1
line aux 0
stopbits 1
line 2
no exec
stopbits 1
line vty 0 4
privilege level 15
login local
transport input ssh
line vty 5 15
login local
transport input ssh
ntp server XX.XX.2.193
Jason,
Here you go.
login as: jnguyen
Keyboard-interactive authentication prompts from server:
| Password:
End of keyboard-interactive prompts from server
intelepeer02#show voice ds
intelepeer02#show dspfarm
intelepeer02#show dspfarm dsp
intelepeer02#show dspfarm dsp all
intelepeer02#term leng 0
0 1 46.2.4 UP N/A FREE xcode 1 - - -
0 2 46.2.4 UP N/A FREE xcode 1 - - -
0 3 46.2.4 UP N/A FREE xcode 1 - - -
0 7 46.2.4 UP N/A FREE mtp 3 - - -
0 7 46.2.4 UP N/A FREE xcode 1 - - -
0 8 46.2.4 UP N/A FREE mtp 3 - - -
0 9 46.2.4 UP N/A FREE mtp 3 - - -
0 9 46.2.4 UP N/A FREE conf 2 - - -
0 9 46.2.4 UP N/A FREE xcode 1 - - -
Total number of DSPFARM DSP channel(s) 206
Daniel Bosch
Very cool!
