SIP inbound call fails error code 407
Turbo727
The senarios is:
ITSP ---SIP----CUBE (CISCO 2921) ---------SIP----------CUCM9.1
inbound call works fine. outbound call gets fast busy tone and error code 407. debug attached.
Please help identifing the issue.
Ayodeji Okanlawon
You need to configure the correct authentication credentials to your sip provider. Your provider must have given you authentication credentials.. It looks like the credentials you have used are incorrect.
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP y.y.y.y:5060;branch=z9hG4bK1D411319
To: <>12059704000@gw1.sip.us>;tag=2484f1a5f06b7307c34ab1dd8d74150a.e1d2
Call-ID: FC743AA8-146911E3-A1F7F8E5-9EEF885B@y.y.y.y
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="gw1.sip.us", nonce="Uibit1Im4F+SfrJQ8PUdoHsjdA+FSRx51sdrI4G+IrmYSJo+O/gqinpPnUTC", qop="auth"
Content-Length: 0
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
