11-16-2012 02:26 PM - edited 03-16-2019 02:14 PM
I am having a problem where my inbound SIP calls are not getting routed to the phone. I can make outgoing calls without a problem. Below are my dial-peers and translations and a copy of debug voip dialpeer when I make an inbound call. My phone's extension is 1001. The call seems to make it to dial-peer 100 then to voice translation rule 1 but not to the extension. Any ideas?
dial-peer voice 1 voip
description *** 10 Digit Calls ***
destination-pattern [2-9]..[2-9]......
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2 voip
description *** 11 Digit Calls ***
destination-pattern 1[2-9]..[2-9]......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 100 voip
description *** Incoming Dial-Peer ***
incoming called-number ..........
dtmf-relay rtp-nte
codec g711ulaw
no vad
voice translation-rule 1
rule 1 /6069487364/ /1001/
voice translation-profile Incoming_Called_Numbers
translate called 1
*Nov 16 22:25:55.680: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=6069487364, Called Number=6069487364, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=6069487364
Result=Success(0) after DP_MATCH_DEST
*Nov 16 22:25:55.680: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=6069487364, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
*Nov 16 22:25:55.680: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=1
*Nov 16 22:25:55.684: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=13525381577, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2
*Nov 16 22:25:55.684: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Nov 16 22:25:55.684: //-1/6C27637E823C/DPM/dpAssociateIncomingPeerCore:
Calling Number=13525381577, Called Number=6069487364, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=100
*Nov 16 22:25:55.684: //-1/6C27637E823C/DPM/dpMatchSafModulePlugin:
*Nov 16 22:25:55.688: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=6069487364, Peer Info Type=DIALPEER_INFO_SPEECH
CME_Router#Match Rule=DP_MATCH_DEST; Called Number=6069487364
*Nov 16 22:25:55.692: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Nov 16 22:25:55.692: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=6069487364, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Nov 16 22:25:55.692: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=1
11-16-2012 03:23 PM
The first thing that stands out at me is that you never applied the translation pattern to one of the dial-peers.
translation-profile incoming Incoming_Called_Numbers
After that the debug output shows the call matching dial-peer 1 for incoming, not 100 which is what I suspect you intended. This happened for two reasons: 1) the pattern is a better match in 1 than 100; and, 2) it occures first in the configuration. In reality you don't need dial-peer 100 and can just add incoming called-number to dial-peer 1 as well as the translation profile.
Please remember to rate helpful responses and identify helpful or correct answers.
11-16-2012 03:46 PM
Here is what I did, it still does not work.
voice translation-profile Incoming_calls
translate called 1
translation-profile incoming Incoming_calls
destination-pattern [2-9].........
translate-outgoing called 2
dtmf-relay rtp-nte
codec g711ulaw
no vad
DEBUG RESULTS
*Nov 16 23:48:53.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Nov 16 23:48:53.191: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=6069487364, Expanded String=6069487364, Calling Number=6069487364T
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
*Nov 16 23:48:53.191: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=1 Is Matched
*Nov 16 23:48:53.191: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Nov 16 23:48:53.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=1
*Nov 16 23:48:53.195: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=13525381577
*Nov 16 23:48:53.195: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
*Nov 16 23:48:53.195: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=13525381577T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Result=-1
*Nov 16 23:48:53.195: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
Match Rule=DP_MATCH_ORIGINATE; Calling Number=13525381577
*Nov 16 23:48:53.195: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=2 Is Matched
*Nov 16 23:48:53.195: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Nov 16 23:48:53.195: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
Result=-1
*Nov 16 23:48:53.195: //-1/02FB659B8349/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_VIA_URI; URI=sip:72.9.149.69:5010
*Nov 16 23:48:53.195: //-1/02FB659B8349/DPM/dpMatchPeertype:
*Nov 16 23:48:53.195: //-1/02FB659B8349/DPM/dpMatchCore:
*Nov 16 23:48:53.199: //-1/02FB659B8349/DPM/dpMatchCore:
Result=-1
*Nov 16 23:48:53.199: //-1/02FB659B8349/DPM/dpMatchPeertype:exit@5985
*Nov 16 23:48:53.199: //-1/02FB659B8349/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_REQUEST_URI; URI=sip:6069487364@172.16.1.1:5060
Result=-1
Match Rule=DP_MATCH_TO_URI; URI=sip:6069487364@sip.anveo.com:5010
Result=-1
Match Rule=DP_MATCH_FROM_URI; URI=sip:13525381577@72.9.149.69:9119
Result=-1
Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=6069487364
*Nov 16 23:48:53.199: //-1/02FB659B8349/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=1 Is Matched
*Nov 16 23:48:53.199: //-1/02FB659B8349/DPM/dpMatchSafModulePlugin:
*Nov 16 23:48:53.199: //-1/02FB659B8349/DPM/dpAssociateIncomingPeerSPI:exit@6564
*Nov 16 23:48:53.203: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Nov 16 23:48:53.203: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
CME_Router#Dial String=6069487364, Expanded String=6069487364, Calling Number=
*Nov 16 23:48:53.203: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Nov 16 23:48:53.203: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Nov 16 23:48:53.203: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=1
11-20-2012 12:24 PM
After lots of digging around, we found a solution.
I am running IOS 15.1-4 and there seems to be a new command in it called TRUSTED IP LIST that is turned on by defualt. I am not sure if the command is new or that is is on by defualt. Anyways, once I added the IP address (it will NOT accept a DNS address), my calls started ccoming in.
Thanks so much to Soct B at Net Cert Labs for taking the time to work with me on the phone to get this resulved!
Michael
11-20-2012 02:07 PM
Yeah - it's pretty new and a definite gotcha. I think there's an intended security benefit to basically acl it off to statically defined addresses (like you did) and/or statically defined addresses by way of session targets on your voip dial-peers.
