01-18-2017 02:31 PM - edited 03-17-2019 09:14 AM
Experts,
I am experiencing an issue with incoming SIP calls that me and Google can't resolve.
I have SIP service setup to have one incoming number XXX-660-5634. Using a translation rule just for testing, I've removed the area code from the number and created a parellel hunt-group with this as it's pilot.
When calls come in, they randomly come in using other dial-peers as the called number.
Example (debug ccsip calls):
Jan 18 22:02:19.251: //13116/9D66B0448800/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4B780EC0
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : XXX-6605015 <--------(**This number is not associated with the SIP service, or anything else, it's a cell phone)
Called Number : 104 <-----------(**This is one of my extensions, the translation rule should make this 660-5634
Source IP Address (Sig ): 192.168.3.1
Destn SIP Req Addr:Port : 162.243.210.200:5060
Destn SIP Resp Addr:Port : 162.243.210.200:5060
Destination Name : 162.243.210.200
What gives? It randomly chooses dial peers, sometimes the called number is my 9911 dial-peer, sometimes it's a dial-peer with the incoming line from a POTS line. I can't figure out what it's doing that.
01-18-2017 05:42 PM
Can you add a debug ccsip message output of a 'failed' call to this port so we can see what the INVITE from google contains?
cheers
01-18-2017 07:11 PM
Thanks for taking an interest.
I have attached the output during an incoming call. I have tried looking at the output from messages, but I don't have the experience to interpret the output.
I see that the 'to:' specifies one of the other numbers I have. The 8109324 number is a POTS line. It's one of the dial-peers that gets randomly selected when the SIP line '660-5634' gets a call.
I don't know how to determine why it's selecting these other numbers.
I have seen it said that when the CME doesn't have a matching rule, it uses rule 0 or selects one for you, but I thought I did the translation rule correct to say any number coming in from the SIP service, change it to 660-5634?
Any ideas?
01-18-2017 09:31 PM
the SIP invite shows a call for: XXX8109324 coming from your SIP provider
what needs to happen is that dial peer 2 needs to get hit:
dial-peer voice 2 voip
description INCOMING CALLS FROM GVGW
translation-profile incoming INCOMING-GVGW
session protocol sipv2
session target sip-server
incoming called-number .%
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
codec g711ulaw
you would need to apply
voice translation-profile INCOMING-GVGW
translate called 1
to that dial peer 2 so that inbound calls get translated into 6605634
you can use debug dial peer, whilst making a inbound test call to see if you are hitting the correct dial peer.
also take the % off of the incoming called-number .% statement. I never use it
Please rate if useful
01-19-2017 03:55 PM
For some reason, debug dialpeer doesn't show any output when I have a call coming in.
I check that I already have the translation rule applied, at least I think.
I'm looking at the dial-peer:
dtmf-relay rtp-nte
codec g711ulaw
no vad
Now looking at the translation profile and rule:
voice translation-rule 1
rule 1 /.*/ /6605634/
translate called 1
I believe what you have recommended is already set.
I reviewed sip messages when a call is inbound and attached that. It looks like the translation rule is still being ignored, so maybe I screwed that part up. It's also weird that the called number is always a dial-peer entry. The provider isn't trying to send the call to a particular end point right?
I included the output of sip-us register status, which I am still researching and trying to understand.
01-19-2017 04:22 PM
While reviewing Cisco's CME example config again, I noticed they added:
no-reg both
or
no-reg primary
to ephone-dns. I wonder if that's what I'm screwing up? They are registering on the service provider proxy and it's randomly choosing them instead of one main number for the DID (XXX-660-5634)?
01-19-2017 05:03 PM
I think I found this issue might be related and the cause of all my life's problems. Being rookie in any subject sucks.
https://supportforums.cisco.com/discussion/11337566/pots-dial-peer-trying-register-sip-registrar
I started adding no sip-register to those dial-peers and they started disappearing from the results of show sip-ua register status
Then, there was nothing. I added an ephone-dn with the number XXX6605634 and then that finally became the called number on the show ccsip calls.
I'm not sure why it doesn't show up as 660-5634 since the translation rule should be changing it.
