11-27-2017 10:12 AM - edited 03-17-2019 11:41 AM
I have a problem with 2 IP Phones 8845 connected to 2 routers with cme using SIP. There is definitely something missing from the dial-peer configuration, but I can not figure out what is missing. Previously it worked, but I made some changes and I do not remember exactly the correct configuration.
Although I turned on debug voice ccapi all or inout, the destination doesn't seem to receive any calls from outside. I do not receive any message on the destination cme when I call the internal number. I get only busy signal for a phone and nothing for the other.
I attached the two configurations and the logs from both cmes...
Thanks so much,
Vali
11-28-2017 04:26 AM
I was able to figure out the mistake. There is no need for incoming peer.
Thanks!
